Question about Kodak i4200
U7 ERRRO CODE - Kodak i4200
My sharp photocopier AR-M276 is showing error code U7-00. so what is the cause and remedy to it
Hi
U7-00 is pc/modem trouble, would you know whether you have a network port on the side of the machine, and whether it is connected to the network?. If you have and it is not connected to the network, that is what the error is, it is expecting an connection of some description.
if you go into settings on the machine, you can switch off the nic/tcp option, which should get rid of the error code.
Cheers
Andy
May 27, 2015 | Sharp Office Equipment & Supplies
CALL FOR SERVICE.CODE:U7-00
According to the error code manual, it means "U7 00 PC/Modem communication trouble" - You can download the entire list of all codes at the link below. It includes your machine specifically. Hope this helps. http://olsonbros.com/sharp/support/pdf_trbl/trbl-arm550n_m550u_m620n_m620u_m700n_m700u.pdf
May 27, 2014 | Sharp AR-M550U Copier
Xerox 5016 error code u70
Error U7, U7-1 (Photoreceptor Belt Drive)
Appears when the Copy Cartridge has Not Been Replaced.
Apr 27, 2011 | Xerox Office Equipment & Supplies
I have a r-410a daikin. in side i have code u7 i have the service manual i says bad transmission. i cant seem to fix it. tips on fixing or let me know some one close by that can. im in granby colorado
U7 System transmission between outdoor units(could also be between boards).Check for loose wiring or UN clipped control wire (any)/ high pressure sensor misplacing.
Dec 13, 2010 | Heating & Cooling
U7-45 xerox dc 440st
replace the drum unit
Mar 23, 2010 | Xerox DC440ST Copier
The keys are playing u7p on my compu7ter as you7 can tell that everytine i u7se the u7 or u7 key it comes ou7t like this u7 u7 calso when i press sift and exclamation this happens @! cant even u7se the...
Try to check your keyboard in any other computer if you face the same issue in another computer as well and try to check other keyboard in your computer if it works fine, if this is the case then you need to chang the keyboard.
2). You may check the on screen keuboar by clickin on start>Programs>Accessories>Accessbility and then select on-screen keyboard and check if you still face the same issue, if not then you can check with other keyboard.
Mar 22, 2010 | ASUS Computers & Internet
Hp photosmart error code 0xc05d2381
I think there is no troubleshooting steps for that errro. The best I suggest you is to replace the printer if it is under warranty
Sep 22, 2009 | HP Photosmart 3310 Printer
SHARP SF 2540 How to troubleshoot U3-20 and u7-00 ROMBLON
U3,20 - Mirror motor lock detection
U7 00 - Communication trouble between PC/Modem and the copier.
Seems to me the U3 error is something similar to the L6 errors in the slightly newer machines. It seems as though the laser moter in your machine has seized.
As for the U7, i have had this error out on the field before. Especially when the machine has had IP setting put into the machine but the network cable isn't plugged in. Throws up that bad boy =]
Aug 10, 2009 | Sharp Office Equipment & Supplies
Kodak i4200 Logo
74 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
