Question about Fisher and Paykel Washing Machines
Fisher and Paykel loose rotor bolt - Fisher and Paykel Washing Machines
2 Suggested Answers
  • 30 Answers
SOURCE: Fisher Paykel Intuitive Eco Washer - IWL15: what is error code 136 on a fisher & paykel IW...
fault code 136 is a hard one possible causes are faulty rotor speed sensor on motor,siezed bearings or rotor,motor windings ,or motor control module, would suggest you get a tech for this one to diagonse correctty ,without proper tools to test eg: rss tester you could cot yourself more money... hope this was some help....:)
Posted on Jun 08, 2010
Rotor cover stuck
the cover is probably twisted or stuck on the sline get it even and just keep pulling at it
Sep 03, 2015 | Fisher and Paykel Washing Machines
Fisher and paykel error 136
Hi Error 136 is rather complicated to solve...in hindsight it could be a number of reasons this came about.. Unless you have abilities to test the windings one will end up spending too much to get it fixed. I guess I'm saying it could be one these... open or short in the motor windings, loose wiring, rotor sensor.
Jun 08, 2014 | Fisher and Paykel Fisher Paykel Intuitive...
How do i get to the rotor position sensor on a fisher paykel gwl11
This is a common issue and is due to corrosion inside the RPS, You need to lean the machine back and remove the rotor cover (round with a nut in the middle), Then remove the 4 x 3/8" bolts and drop the stator down. you can then remove and replace the RPS, I have repaired a lot of these and have not yet found one that was fixable by cleaning the connections.
May 04, 2014 | Fisher and Paykel GWL11 Top Load Washer
Rotor position sensor on a fisher and paykel GWL11
this is a very common fault you need to remove the big plastic cover over the motor from the bottom there is what is called a stator loosen the four bolts to remove the plastic sensore and replace it
Dec 18, 2017 | Fisher Washing Machines
Intuitive ECO Model IW811 display error codes 240 and 130. what does this mean?
The fault codes 130 and 240 are pertaining to a Rotor Position Sensor problem. It is the part located wedged into the motor stator and it's sole function is the detection of motor functions particularly the rotor as the name suggests. The problem can be a simple loose wire harness or a damaged Rotor Position Sensor.
Unplug the machine. Tape the lid closed then lay the machine's front on a padded floor. Remove the single bolt holding the "plate-like" rotor to the shaft to access the Rotor Position Sensor. Once the rotor is off, check the contacts on the Rotor Position Sensor end of the wire harness to see if any have been damaged. Each set of contacts in the socket has two wipers. If the distance between these wipers varies between different contacts, replace the Rotor Position Sensor harness. Consider replacing the Rotor Position Sensor if no issue is found with the harness and the connectors.
Jul 18, 2011 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher & Paykel Washing machine Intuitive Eco Error 130 then Error 136
Hi - Faults 130-136 means there are some serious comm problems - motor stalls etc. The most likely cause would be the RPS Senor - has failed or loose, corroded, bad wiring connections.
This is under the machine - tilt on its back, remove the center round rotor has magnets on the inside be careful it stays clean. there are 4 bolts in the middle - remove to get stator off with all the copper wounded contraption, remove the wiring - not to worry too much but note on the stator Y_B_R relates to colours on wire harness, note also the harness & RPS component. replace this assemble & should work fine unless the controller is a dud.
95% of the time this is your culprit.... Part # 438515P I think for these range - pays to check 1st - You need to quote the Product nuber as this is critical to the components under the hood if you get my drift.
May 31, 2011 | Fisher and Paykel Fisher Paykel Intuitive...
Need to get out old motor rotor assy so we can put new one in.
This video will wok you through your Fisher Paykel repair, how to fizz a f1 error code and how to replace the rotor.
http://www.appliancerepairlesson.com/shop/dishwasher-videos/fisher-paykel-dishwasher-repair/
Sep 29, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Hi my fisher and paykel model MW15 wont agitate or do anything really, and the starting from the left hand side, the cycle lights 1st and 7th come on. what does this mean?
This is fault code (130).the lights that are on are added together,il explain how below
0 0 0 0 0 0 0 0
128 64 32 16 8 4 2 1 This is The Rotor Position Sensor located in the motor underneath the machine.from underneath undo the pig plastic nut & take off the big round cover with the magnets in it.undo 4 bolts in centre of motor.The rotor Position Sensor has the plug with about 5 wires on it.
May 31, 2010 | Fisher and Paykel Fisher & Paykel Washer
May 18, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
IW712- fisher paykel intuitive eco.
I BELIEVE THAT IS A ROTOR SENSOR ERROR
REPLACE THE ROTOR SENSOR
Feb 15, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
