F1 error on sf 130LJ. What does it mean? - Washing Machines
2 Suggested Answers
  • 1249 Answers
SOURCE: Model SF 130lj Indicate C 4 when I try to spin.
c4 error code refers to the load being unbalanced. The easiest hing to do is not wash so many clothes at once. If the unit faults out with this code even with small loads, make sure the unit is level and the feet are not out of whack. If the feet are not adjusted correctly, the washer will clang and bang against the floor when it is trying to spin.
Please find this helpful by clicking the button. model-sf-130lj-indicate-c-4-when-try-u40lsvyytnuesyuv3fbafhtd-3-0.jpg
Posted on Jan 05, 2015
I have sf p120lj washing machine its showing F1 message what should i do advice
I have sf p120lj hitachi washing machine its showing C1 message what should i do advice
Jan 26, 2015 | Washing Machines
Model SF 130lj Indicate C 4 when I try to spin. What is the problem?
Jan 04, 2015 | Washing Machines
Hitachi SF-P95FJ WASHING MACHINE ERROR CODE F9
if you have Hitachi nw-d8ax f1 error check water sensor f3 error check rinse filter f9 error do not know where the error but I did repaired, remove back panel and right hand side inside polithine cover find blue connector its with 2 wires remove it and switch machine it will give f3 error with sound reconnect the socket its started working
mail me if yours working I will give you more tips nava@netintec.com cheers
Oct 29, 2010 | Washing Machines
Error f1 en sharp sf 2530
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} F1 00-sorter communication trouble detected
01-paper jog malfunction detected
02-transport motor malfunction detected
04-indexer lower limit detected
05- indexer upper limit detected
06-shift motor malfunction detected
Aug 01, 2010 | Sharp SF 2020 Copier
Error f1
How do you do. You should check join from the main of the charge to device сортера.If connections is checked and where are no mistakes in join no pay attention to mechanical possible damages, findings scrap papers and stranger subject in sorter device. Recall, pr what circumstance appeared the fault.Error code F1 for sharp copiers sf 2020.2030 Sub code 00: Communication error between main board and sorter. Sub code 02: Sorter transport motor drive.
Sep 23, 2009 | Sharp SF 2020 Copier
Sharp sf 2040 error code F1-02
If the sorter has a problem, disable that option by command 26 print 01 print and enter 0 enter.
Apr 05, 2009 | Sharp SF 2040 Copier
I have a Sharp SF-2030 copier and it is diplaying a F1 code.
F1 FIRST OF ALL CHECK WHAT IS THE SUB CODE .IF SUB CODE IS 00 ITS COMMUNICATION ERROR BETWEEN MAIN BOARD AND FINISHER.IF 01 FINISHER SHIFT PROBLEM.IF 06 FINISHER MOTOR PROBLEM.IF 10 THAT IS STAPLER PROBLEM.DO NOT FORGET TO RATE THE SOLUTION.MIAN JEE
Feb 21, 2009 | Sharp SF 2020 Copier
Sharp sf 2540 code F1
The F1 error code -- lost communication with the sorter. Are there secondary numbers after the F1?
Check connector cables on sorter and machine, check power to sorter. If those are fine then you are looking at a board problem. Also make sure that all covers are close properly. *** check cover between the sorter and machine*** ( you may have to pull sorter away from machine).
Jan 24, 2009 | Toshiba e-Studio65 Copier
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
