Question about Panasonic AM/FM MP3/CD Player/Receiver CQCP137U
Panasonic CQCP137U speakers distort above volume 19.
This is a brand new stereo. When connected with the factory harness in my 2007 Freightliner truck, the sound is great below 19. Above 19, the sound distorts.
2 Suggested Answers
pmeneide
  • 382 Answers
SOURCE: My panasonic dvd stereo system sa-pm91d when the volume is turned above 25, it plays distorted sound, it sounds like I have incorrectly tuned a radio channel even when using the auxiliary input
Hi Gusma,
If you have Distorted sound.
    These may be the causes of the problem:
  • Make sure the speakers wires are properly connected.Check the color codes, be sure they are rightfully followed.
  • - Shorting (bare wires touching) of positive and negative speaker wires.
  • - Using speakers with an impedance lower than that rated for this unit.
  • - Straining of the speakers through excessive volume or power.
  • - Using the unit in a hot environment without proper ventilation.
I am also including a link to the User Manual. Read it thoroughly.
Best of Luck,
JP
Panasonic SC PM91D Operating Instructions Manual
Posted on Jun 26, 2015
Trying to hook up aftermarket stereo with no factory harness. How can I go about wiring my new stereo wires or my replacement harness (with module) to my car's already existing loose stereo wiring??
Hi Daniel
You need to test & label all the loose wires.
Use a multimeter in Ohms mode to place a tickle of electricity to each speaker wire. you should hear each speaker crackle. (Multimeters only use a 9v battery internally)
Label each pair of wires for speakers.
Their color coding may help. Keep the negative & positive wires to the speakers correct so that the speakers all travel in a forward motion together or you will have distortion from one speaker that is out of phase with the others.
You will also have a permanent +12v line and a Ignition Key +12 volt line.
One keeps the station memory etc when the ignition key is off.
Cheers
Car Stereo Wiring Explained In Detail
Car Stereo Wiring Basics
How to Install Replacement Car Stereo
Mar 01, 2016 | Cars & Trucks
When i turn the volume up to(17-20) my sound cuts out and my speakers make a cracklin noise.i have bought new speakers and rechecked all wires.my speakers are rated at 50 watts rms and my stereo pumps out...
It seems you needs more power to maintain the level of good sound.Maybe the maximum volume is 30 - then the mininum is 15 and you can't hear any cracking sound. If you exceed 15 the minimum, as you said starting 17 - 20 you hear crackling sound .Then you reach ,what they called the "cliping level"so much distortion and crackling sound,your stereo too small to accomodate .You must add a power amplifier so crackling will gone and to fit your listening pressure...
Hope it may help you;
Regards,
VOTIT
Sep 21, 2008 | Car Audio & Video
Tip
ALARM, CRUISE CONTROL, and STEREO Wiring Color Codes for 1993 Honda Civic This...
This FixYa Tip is for the purpose of installing an Alarm, Remote Starter, Cruise Control, and / or Car Stereo into the vehicle listed in the subject line.
The wires listed are the ones you will need to successfully complete the task.
Some vehicles require additional relays and / or modules to bypass factory security. If they are required - it will be in the NOTES section below the wiring colors.
The following FixYa TIP is good for all Honda Civics for the following production years:
1993
STEREO WIRING COLOR CHART:
Constant 12V+: White/Blue
Switched 12V+: Yellow/Red
Ground: Black
Illumination: Red/Black
Dimmer: n/a
Antenna: Driver's Pillar
Front Speakers:
Left Front (+) Blue/Green
Left Front (-) Gray/Black
Right Front (+) Red/Green
Right Front (-) Brown/Black
Rear Speakers:
Left Rear (+) Blue/Yellow
Left Rear (-) Gray/White
Right Rear (+) Red/Yellow
Right Rear (-) Brown/White
NOTES: - none -
Additional Accessories:
Metra Brand Dash Kit: n/a
Metra Brand Wiring Harness: 70-1720
Metra Brand Antenna Adapter: n/a
ALARM / REMOTE START WIRING CHART:
Constant 12V+: White - Ignition Switch Harness
Starter: Black/White - Ignition Switch Harness
Ignition: Black/Yellow - Ignition Switch Harness
Accessory: Yellow - Ignition Switch Harness
Tach: Blue - Distributor
Brake Switch: Green/White - Brake Switch
Trunk Pin: Green/Black - (-) Above Fuse Panel (Blue Connector)
Parking Lights: Red/Black - (+) Above Fus Panel (White Connector)
Head Lamp: Red/White - Steering Column
Hood Pin: n/a
Factory Disarm: Disarms with Unlock
Door Trigger: Green/Red - (-) Driver's Running board
Door Lock: Green/White - (-) Driver's Door at Door Lock Module
Door Unlock: Green/Red - (-) Driver's Door at Door Lock Module
Horn: Blue/Red - Steering Column (Relay Required)
Windows UP: LF=Red/Blue RF=Orange/White
NOTES: - none -
CRUISE CONTROL:
Constant 12V+: White - Ignition Switch Harness or Use Hot Side of Brake
Switched 12V+: Black/Yellow - Ignition Switch Harness
Ground: Use Chassis Near Cruise Control Module
Hot Side of Brake: n/a - Brake Switch
Cold Side of Brake: Green/White - Brake Switch
VSS Wire : Yellow/Blue - Driver's Side Dash Footwell, Grey connector.
NOTES: 4000PPM
Vehicles with Manual Transmission require Clutch Switch.
Some vehicles may require a speed signal generator and/or other parts/adapters not listed above.
Rostra® Cruise Control module switch settings may differ if you use a speed signal generator or magnets and a pick up coil.
Thanks for using FixYa!! Please see my other tips on GPS, Car Audio, Large Appliances, and more.
on Apr 01, 2010 | Honda Civic Cars & Trucks
Put a pioneer premiere deck in my 03 chev impala. Every thing is working. But no sound what so ever. Car does have a factory amp in the trunk. Hooked up many car stereo's never had this problem.
Was the system working properly with the factory radio?
If it was working with the stock radio but not with the new one, then it probably means you didn't connect the amplifier activation wire. This is a white wire in the vehicle plug, and it's usually pinned with a blue or a blue/white wire in most adapter harnesses. This needs to be connected to the blue/white wire in your Pioneer harness.
If the factory radio wasn't producing sound either, there's a common problem with the power wiring leading to the factory amp in these vehicles. The power wire runs in a thick harness below the passenger side door sills, and at a spot below the rear door there's a junction point in the wire. This connection tends to get wet and corrode until it breaks apart. (In some of these cars, this connection is constantly immersed in water because there's a leak that leads to standing water under the carpet in front of the passenger-side rear seat).
Aug 25, 2015 | Pioneer Car Audio & Video
How do i get my speaker to work at high volume with out them cracking,popping destort
If you are using the factory installed speakers they aren't made for the wattage output of your receiver. Factory stereos only put out about 5 to 10 watts. If you want to play it really loud you need to replace them with speakers that have a higher wattage that what your receiver puts out, which is a maximum of 50 watts
Aug 23, 2015 | Kenwood KDC-248U In-Dash CD, MP3, WMA Car...
Hi Gusma,
Best of Luck,
JP
Jun 26, 2015 | Panasonic Audio Players & Recorders
I Hooked up my new stereo and cant get any sound. I put the factory Bose back in and the sound works. Hooked up my new stereo to another car and it has sound. Can anyone tell me Why im not getting sound...
If you had a "Bose" sound system - Factory installed - it should have and Amplified System - which means the original stereo will supply power to the Speaker Amps - that is the circuit that didn't get connected and why there is no sound.
I hope that resolves your issue
Thanks
Feb 22, 2015 | 2002 Nissan Pathfinder
On a 2007 freightliner Columbia which side is the cb and which side is the stereo
Most newer trucks have a matching box that both are connected too.
they connect the stereo and the cb together on the anntennas.
Mar 30, 2014 | Radio Communications
I just bought some Performance teknique ICBM 500W and installed them and have a panasonic CQ-RX100U 50w x 4 stereo, its on a 91' ford explorer with a factory amp but not sure if connected. when i higher...
I had a 97 explorer came factory with a JBL system, and had a factory amplifier, I had to get rid of the factory amplifier and by pass it to get my new radio to work... my factory amp was in the very rear passenger under the plastic...... mine worked fine until I installed a new stereo (replaced stock one) and because my stereo didnt contain whatever it was to make the amplifier turn on, had to go bypass the amplifier and I unplugged everything I could find on it. Hope this may provide some clues if any
Nov 01, 2013 | Car Audio & Video
Panasonic AM/FM MP3/CD Player/Receiver CQCP137U Logo
42 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
