Question about Hyundai W220D 22 inch LCD Monitor
Hyundai w220d inverter - Hyundai W220D 22 inch LCD Monitor
Nothing on screen but there is sound
chek power inverter board. and find inverter driver
Feb 17, 2014 | Hyundai Electronics E320D 32 in. LCD...
My hyundai tv has a perodic vertical black line
1st resolder inverter board, if the problem still exist chek the flex cable.
Feb 15, 2014 | Hyundai Electronics Televison & Video
My monitor has flipped the display so the picture is sideways. how do i correct this
there should be a menu or setup button on the monitor, what you're looking for is a setting called display orientation, the two options for which are landscape and portrait. you want landscape.
Jun 26, 2011 | Hyundai W220D 22 inch LCD Monitor
Which type of the frequancy refferance source is given to toshiba make inverter VFA3N-8075PY-A70 ? which is used in teijin seiki winder in textile machinery.
Replace VFA3N-8075PY-A70 with CIMR-AT2A0040 & PROTOCOL CONVERTER!
Yaskawa inverter can replace the inverter with communication converter.
We have the solution on it, also TORAY T3 spindle inverter.
Fell free to contact us.
James park hyundai-sys@hanmail.net
Jan 17, 2011 | Toshiba Satellite U400/U405 Power Inverter...
Where can I purchase a new base... as the one that I dropped while moving got ran over by a truck... and I don't have enough fingers to hold all the pieces in place to glue same back together
Chances are slim to none that you will be able to get new base for your unit. Better off trying to "fab" one from quarter-inch plexi-glass sheet and attaching with screws to back of unit.
12fixlouie
Sep 07, 2010 | Hyundai W220D 22 inch LCD Monitor
Backlight of Hyundai X93W dead
The fault is most likely a faulty inverter board.
For service, parts and DIY info check out LCD Parts - click on this link to their WEB site :-
www.lcdparts.net
Jan 09, 2010 | Hyundai Electronics Hyundai LCD 19"...
My back light flashes for around an hour thens fine. I trying to find a back light inverter. can you help? Hyundai e370d
Your best bet is to take the numbers off the inverter board and google those numbers. Hyundai does not make a set to my knowledge. A lot of sets are what we call a Heinz 57 set. They can have any number of manufacturers boards in them.
Dec 12, 2009 | Hyundai Electronics E370D 37 in. LCD...
Hyundai Monitor Starts up with pink shade color than goes normal
It may be the inverter and it can also be your speakers, if they are kept close to your monitor.
May 13, 2009 | Hyundai Electronics ImageQuest N91S 19"...
Hyundai HLT-3210 POWER SUPPLY FAULT LOW OUTPUT FROM SUPPLY PCB
Hello! My name is Ivica,and I am from Croatia.I have same LCD which have problem with motherboard.Try to disconect power supply from inverters and then measure all volt line.Maybe failure is on inverters board!Write me if you solve the problem,and maybe you know where can I find new motherboard for my LCD.Thanks.
Jan 18, 2009 | Hyundai ImageQuest HQL320WR 32 in....
Hyundai W220D 22 inch LCD Monitor Logo
42 people viewed this question
Top Hyundai Computers & Internet Experts
Tom Stevenson
Level 1 Expert
Randy Schumann
Randy Schumann
Are you a Hyundai Computer and Internet Expert? Answer questions, earn points and help others
