Question about Kenwood Kdc-Bt92sd Cd/Usb Ipod Reciever With Built-In Bluetooth Sd Card Reader
Kdc-Bt92sd no sound - Kenwood Kdc-Bt92sd Cd/Usb Ipod Reciever With Built-In Bluetooth Sd Card Reader
No sound on kdc - 138 and i know everything is hooked up right got power in everything i got a little sound but not for long
Im in the same boat... im searching for a reset... mine worked for 30 mins.. once i moved it from my van to 4runner... then I got back in teh car everything turned on but no sound.. i thought a speaker had shorted but nope.. im wondering if there is a reset
Jan 20, 2011 | Kenwood KDC-138 FM / AM Receiver
Kenwood kdc mp242, no sound, ford explorer, 94
if that ford had premium sound you have either not hooked up the factory amp or you have blown a fuse to it. you won't get sound unless that amp is hooked up.
Jan 03, 2010 | Kenwood Car Audio & Video
No sound on Kenwood KDC-MP242
the sound producer needs re soldering,take the lid of and look for malted solder
Dec 26, 2009 | Kenwood KDC-MP242
Kenwood KDC-MP438U reciever installed. No sound in any mode.
if its a newer truck it will most likely have a factory amp u either have to utilize or bypass
Apr 21, 2009 | Kenwood KDC-MP438U Car CD/ MP3 Player
Kenwood kdc 3011 cd player
Have you tried the balance and fader control?
Also make sure the ground or - negative wire has a good connection for that speaker from the back of the unit. Or it could be the internal amplifier it self.
Dan
Aug 17, 2008 | Kenwood KDC-2011S CD Player
Kenwood KDC-322 volume cutting out
there buggers rewire the earth/ground
Jun 19, 2008 | Kenwood KDC-322 CD Player
No sound on cd, (kenwood kdc-x469)
did you try another cd maybe your player needs a little cleaning and is your cd new or older
reason i ask is cause newer cd's have a different format then older cd's from a year ago its getting hard to play new stuff on old stuff
May 06, 2008 | Kenwood eXcelon KDC-X469 CD Player
KDC-mp-338
is the cd store bought or home recorded-
Apr 16, 2008 | Kenwood KDC-519 CD Player
Kenwood KDC-W6527 audio trubles
check all the wire connections in the back, you have a short somewhere
Nov 14, 2007 | Kenwood KDC-MP528 CD Player
Kenwood Kdc-Bt92sd Cd/Usb Ipod Reciever With Built-In Bluetooth Sd Card Reader Logo
48 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
