Question about Hoshizaki Kitchen Appliances - Others
Replace flow control valve - Hoshizaki Kitchen Appliances - Others
  • Hoshizaki Master
  • 1,253 Answers
What specifically is your question? more detail and a model and serial would help.
Posted on Aug 14, 2014
Nissan altama 2005 3.5 l v6 problems are running smooth when engine is cold 5-10 min there us a problem with engine vibrations on the stop i get the trouble code which is po0011
Here is the definition. You may want to do some research on the code and the valve that controls cam timing.
P0011 NISSAN Description This valve mechanism hydraulically controls cam phases continuously with the fixed operating angle of the intake valve.
The ECM receives signals such as crankshaft position, camshaft position, engine speed, and engine coolant temperature. Then, the ECM sends ON/OFF pulse duty signals to the intake valve timing control solenoid valve depending on driving status. This makes it possible to control the shut/open timing of the intake valve to increase engine torque in low/mid speed range and output in high-speed range.
The intake valve timing control solenoid valve changes the oil amount and direction of flow through intake valve timing control unit or stops oil flow. The longer pulse width advances valve angle. The shorter pulse width retards valve angle. When ON and OFF pulse widths become equal, the solenoid valve stops oil pressure flow to fix the intake valve angle at the control position.
Read more: http://engine-codes.com/p0011_nissan.html#ixzz26Hjx6ned
Sep 12, 2012 | 2006 Nissan Xterra
P0011 code. My car started jurking in the middle of traffic about a month ago. The first week, I replaced the cam sensor and it drove smooth for 2 weeks but the jurking came back. I got the cam sensor from...
PLEASE READ ALL THIS INFO.
MAKE SURE THE ENGINE OIL IS CLEAN AND CHANGED AT PROPER INTERVALS
P0011 NISSAN - Intake Valve Timing Control Performance Bank 1
Symptoms - Engine Light ON (or Service Engine Soon Warning Light)
- Possible engine lack/loss of power
- Posssible engine rough idle
Possible causes - Harness or connectors
- Intake valve timing control solenoid valve circuit is open or shorted
- Intake valve timing control solenoid valve may be faulty
- Crankshaft position sensor (POS) may be faulty
- Camshaft position sensor
Tech notes Since the Intake valve timing control solenoid valve uses oil flow to control timing, dirty oil can cause the valve to stuck open or close. Before replacing the valve, change engine oil and filter and reset engine code. When is the code detected? When there is a gap between angle of target and phase-control angle degree, the valve will stop working and the ECM will trigger the P0011 code. P0011 NISSAN Description This mechanism hydraulically controls cam phases continuously with the fixed operating angle of the intake valve.
MAKE SURE YOUR OIL IS CLEAN AND CHANGED AT PROPER INTERVALS.
Sep 07, 2011 | 2006 Nissan Altima
What does the check engine code p0406 mean on my dodge caravan with a 3.3L engine?
P0406 - Exhaust Gas Recirculation Sensor A Circuit High
An improper voltage signal is sent to ECM through the valve
Early Models : The EGR valve control the amount of exhaust gas routed to the intake manifold. Vacuum is applied to the EGR valve in response to the throttle opening. The vacuum control the movement of the taper valve connected to the vacuum diaphragm in the EGR valve.
Late Models : The EGR volume control valve uses a step motor to control the flow rate of EGR from exhaust manifold. This motor has four winding phases. It operates according to the output pulse signal of the ECM. Two windings are turned ON and OFF in sequence. Each time an ON pulse is issued, the valve opens or closes, changing the flow rate. When no change in the flow rate is needed, the ECM does not issue the pulse signal. A certain voltage signal is issued so that the valve remains at that particular opening.
Symptoms
- Engine hesitation
Possible causes
- Harness or connectors (EGR volume control valve circuit is open or shorted.)
- EGR volume control solenoid valve
- EGR temperature sensor and circuit
Possible solution
- Repair EGR harness or connector
- Replaced EGR volume control solenoid valve
- Replaced EGR volume control valve
Hope helps (remember to rate and comment this answer).
Mar 31, 2011 | Dodge Caravan Cars & Trucks
I have a code P0401. What is this and how can I fix it?
P0401 - Exhaust Gas Recirculation Flow Insufficient Detected
Possible causes - Harness or connectors (EGR volume control valve circuit is open or shorted.)
- EGR volume control valve stuck closed
- Dead (Weak) battery
- EGR passage clogged
- Exhaust gas leaks Possible solution - Clean EGR Valve
Mar 20, 2011 | 1998 Ford Taurus
Ford Explorer : How to Troubleshoot the EGR P0401 Trouble Code
Possible Causes:
- Exhaust gas leaks
- Faulty EGR valve
Possible Solutions:
- Clean EGR Valve
- Replace EGR Valve
- Replace EGR volume control solenoid valve
- Replace EGR volume control valve
Jan 24, 2011 | Ford Explorer Cars & Trucks
I have a 2003 a4/b6 1.8 turbo and the engine light is on. The DTC codes says random misfire, misfire on cylinder #2 and #3 also, Oxygen (Lambda) Sensor Regulation: Bank 1: System too Lean : P1111. Any...
If you can supply me with all the codes your vehicle is showing, I can assist you. As far as the P1111 DTC goes I have listed the info below with some possible solutions.
P1111- Intake Valve Timing Control Solenoid Valve Circuit Bank 1
Intake valve timing control solenoid valve is activated by ON/OFF pulse duty (ratio) signals from the ECM. The intake valve timing control solenoid valve changes the oil amount and direction of flow through intake valve timing control unit or stops oil flow. The longer pulse width advances valve angle. The shorter pulse width retards valve angle. When ON and OFF pulse widths become equal, the solenoid valve stops oil pressure flow to fix the intake valve angle at the control position. The code is triggered when an improper voltage is sent to the ECM through intake valve timing control solenoid valve. Since the Intake valve timing control solenoid valve uses oil flow to control timing, dirty oil can cause the valve to stuck open or close. Before replacing the valve, change engine oil and filter and reset engine code.
Possible Causes:
- Intake valve timing control solenoid valve bank 1 circuit is open or shorted.
- Intake valve timing control solenoid valve bank 1 circuit connectors
- Dirty Oil
Possible Solutions:
- Change Oil
- Replace Intake valve timing control solenoid valve
Jan 20, 2011 | 2003 Audi A4 Cabriolet
OBDII SETS CODES P0401, P0171 & P0174 . 1998 Mercury Sable
P0401- Exhaust Gas Recirculation Flow Insufficient Dectected
Code P0171- Fuel Injection System Too Lean Bank 1 Possible causes - Intake air leaks
- Front Heated oxygen sensor may be faulty
- Injectors may be faulty
- Exhaust gas leaks
- Incorrect fuel pressure
- Lack of fuel
- Mass air flow sensor may be faulty
- Incorrect PCV hose connection Possible solution Dirty air filter of faulty air flow sensor are common causes of the problem P0174- Fuel Injection System Too Lean Bank 2 Possible causes - Intake air leaks
- Exhaust gas leaks
- Lack of fuel
- Incorrect PCV hose connection Possible solution Dirty air filter of faulty air flow sensor are common causes of the problem.
Jun 28, 2010 | 1998 Mercury Sable
I have 1 and 1/2 horsepower sprinkler pump that wont prime. As soon as the end piece fills, it will empty if I open the end to the sprinkler.
I don't know what is your system set up. However, the system set up should be the following;
1. Your 1-1/2HP sprinkler pump must be installed at
a fix location nearest the water source. (Complete
with power and plumbing lines.)
2. At the end of the suction line is a vertical check
valve with strainer.
3. The suction pipeline must be connected to the
suction port of the pump.
4. At the discharge port, a flow control valve tee must
be installed. The flow control valve tee top is
covered with a plug, which serves as the priming
port when opened.
5. After the flow control valve, connect a short nipple
so that you can put a gate valve to stop the water
flow or allow the water to flow. You may connect
a pressure tank at this point or you may connect
the pressure hose going to the sprinkler.
6. To prime the pump, open the plug at the flow
control top. Fill it full with water, replace the
priming port plug.
7. Turn the flow control valve to full closed position.
8. From full close position, switch the power on.
9. The pump now run on and off due the pressure
switch setting. Slowly open the flow control valve
such that the water pressure remains steady.
10. Take note of the pressure.
11. Shut the power off, and connect the sprinkler
pump hose.
12. Put the power back on, and allow the pump to
run with the sprinkler.
Under this set up, you can run the sprinklers when your pump is running. Hope this will solve problem.
Dec 08, 2009 | Plumbing
Water cannot be stopped running through shower
depending on the type of diverter you can replace or repair the divert-er valve. if it is a faucet mounted then replace the faucet. if it is an internal control valve then you can probably replace the core to fix the problem.
Jul 31, 2009 | Home
1996 crown victoria has no heat
the temp blend door may not be rotating from the a/c evaporator to the heater core opening.
Could be the motor on the blend door or the temp control knob.
Do you have manual a/c or electronic temp control?
If it's the a/c door electronic actuator motor, it's on top of the plenum. Have to remove the instrument panel for access.
Hope it's the temp knob on the control head.
top one is the circuit you are looking at
Apr 23, 2009 | 1996 Ford Crown Victoria
Open Questions:
Kitchen Appliances - Others Logo
26 people viewed this question
Top Hoshizaki Kitchen Appliances - Others Experts
Dennis Boxerman
Mike Squire
Are you a Hoshizaki Kitchen Appliances - Other Expert? Answer questions, earn points and help others
