Question about Ovens
GRCR3960ZSS-3 oven control board
Replacement contol board
2 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Pro: top oven element has one hot leg.
It appears your ERC/CLOCK has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Oct 01, 2010
Where can i buy a replacement control display
Hello Friends!
This dimming vacuum display is either caused by a power supply failure with the control board, or a the filaments of the display themselves have started to wear-- similar to that of a bad light bulb. Either way, FixYourBoard.com can solve this problem- This control board is no longer available to buy new. Contact FixYourBoard.com at 512-355-1108 for more information. The photo below is from a double oven, but they repair single oven displays too.
Apr 13, 2017 | DCS Ovens
Tip
Repairing an (F2 E0 or F2 E1 error code) Failed Whirlpool Builtin Oven Keypad...
A replacement touchpad is now available from Ledgestone Technologies to replace various membrane keypad switches that are not available from the OEM.
These are in stock and can be shipped today from fixyourboard.
Find the full list of applicable models here:
Introducing the Ledgestone Technologies Touchpad
Step 1. Remove Original Plastic Bezel
BE SURE TO REMOVE POWER TO OVEN FIRST!
You are going to re-use the original plastic bezel. Remove the panel from your oven that contains the keypad and control board. Uplug the keypad from the control board. Remove the control board from the panel (4 screws).
Step 2. Remove Original Touchpad Membrane
With a heat gun, lightly heat the original keypad from the back of the panel. This will soften the adhesive. Gently but firmly push the old keypad off the bezel by pushing from the back of the panel on the keypad window. Carefully remove the original keypad membrane element. Most of the original adhesive should pull off with the keypad. Rub off any remaining adhesive.
Step 3. Install New Ledgestone Touchpad
Remove adhesive backing paper from the Ledgestone Technologies KP1308A1 Replacement Touchpad Membrane. Align and adhere new touchpad to recess in plastic bezel. Below are examples of black on black and gray on white. Gray also looks good on bisque or almond.
Step 4. Re-install Bezel on Oven
Re-attach control board to bezel, plug-in new keypad. Re-attach bezel to oven frame. Done!
Applicable Models
RBD276PDB10 RBD276PDB11 RBD276PDB12 RBD276PDB7 RBD276PDB8 RBD276PDB9 RBD276PDQ10 RBD276PDQ11 RBD276PDQ12 RBD276PDQ7 RBD276PDQ8 RBD276PDQ9 RBD306PDB10 RBD306PDB11 RBD306PDB12 RBD306PDB13 RBD306PDB14 RBD306PDB15 RBD306PDB7 RBD306PDB8 RBD306PDB9 RBD306PDQ10 RBD306PDQ11 RBD306PDQ12 RBD306PDQ13 RBD306PDQ14 RBD306PDQ15 RBD306PDQ7 RBD306PDQ8 RBD306PDQ9 RBD306PDT11 RBD306PDT12 RBD306PDT13 RBD306PDT14 RBD306PDT15 RBD306PDZ10 RBD306PDZ7 RBD306PDZ8 RBD306PDZ9
Original Whirlpool Touchpad Part Numbers
4451969 4451970 4451975 4451976 4451977 8300431 8300432 8300437 8300438 8300439 8300640
on Aug 17, 2015 | Ovens
Oven turns on starts to heat then shuts off, no error code given just sais fault
Sounds like your control board is failing. I would suggest having it fixed before the damage becomes beyond repair. Many companies like to discontinue their parts in 3 years or less so if the control board becomes non-repairable you might be stuck buying a new oven. Therepairshack.com offers a repair service for whirlpool control boards. Do you have a model number? I can check to see if there is a replacement available also.
Dec 02, 2015 | Whirlpool WOS51EC7AW Single Wall Oven...
Displaying E6 & F2 code
F2/E6 fault code implies a Cancel key drive line open. This means the key pad ribbon connector could be loose or dirty where it connects to the oven control board or a faulty oven control board.
Press Cancel. If the error code returns after 60 seconds, replace the key pad. If it continues to display F2/E6 after replacing the key pad, replace the oven control board. The parts can be ordered from Sears PartsDirect
NOTE: Disconnect the power supply from the oven before servicing.
Check additional details in THIS IMAGE LINK.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Nov 13, 2011 | Ovens
I walked by my stove and noticed heat coming from it and I opened the oven door and heat was coming from it. I did not turn on the stove top burners or the oven when I noticed it. The switch was OFF. I...
You most likely have a problem with the temprature contol knob and the thermostat.
This is all contained in one unit. The controller has a long metal "wire" that sends the temp info to the controller. The "wire" ends inside the oven.
This whole assemblage needs to be replaced.
I would need the type of stove, gas or electric age and model to give you replacement directions
Jul 01, 2011 | Ovens
The oven has power and nly the oven light works. The display does not work and the ovens will not work.
Hello & Welcome to FixYa
This indicates a open/shorted oven temperature sensor or a bad control board and to solve this problem the sensor/board needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Jan 09, 2011 | Whirlpool RBD245PDS Electric Double Oven
The clock on my Cambridge oven wont work, I cannot set. Therefore the oven wont light unless the clock is set. How do I fix this problem? All the buttons have stopped working so therefore unable to set the...
bad digital control board if tis just a clock and all the settings can be done with a knob and not the board then the replacement wont be too expensive but if that board controls eveything which i suspect it does then its going to be at least 150 more to repair than if it was just a clock display
Mar 30, 2010 | Ovens
Had the element replaced at the back of the fan, but there is still no heat? Is there another element that may need replacing?
No there should only be one heating element but the oven thermostat could also require replacement as this contols the element in the same circuit .
Jan 24, 2010 | Neff B1641 Single circotherm super...
My whirlpool oven is displaying E6 and F2. It
Your cancel key is defective at this point. follow these steps below?
1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Aug 08, 2009 | Whirlpool RBS305PDS Electric Single Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
