Question about Canon Office Equipment & Supplies
The printer felt down and a part had broken - Canon Office Equipment & Supplies
    Master:
  • Canon Master
  • 641 Answers
Its hard to find parts for small injet printer, better buy a new one
Posted on Jun 23, 2014
Error light flashes and cartridge won't center
Canon printers are well known for this as it could be caused by the ink tank being full. Check the manual.
The ink tank is a thick pad of felt in the bottom of the printer and every time you clean the cartridges a small amount of ink is squirted in to the tank. It soon gets full.
Have a look at http://canonhelp.freehttp.com/
I have stripped my BJC 1000 printer down, washed out and dried the felt pad, replaced it, re-set the electrics as described on the above site and all is well now.
You may need help stripping the printer down as it may be held together by only two or three screws and plastic spring clips.
A firm could charge you £40 plus carriage for the repair but it can be done at home if you take your time and get some mechanical help.
Best of luck.
Feb 15, 2011 | Canon BJC 85 InkJet Printer
I have a 1999 explorer. I felt a little bump while I was driving slowly through a parking lot & all of a sudden it felt like I had no power steering. I pulled over a little further down the road &...
Check to see if the serpentine belt is broken or has come off the pulleys. One belt runs the power steering and water pump. If the belt is broken or has fallen off, it will need to be replaced.
Oct 06, 2010 | 1999 Ford Explorer
Printer will not feed. Using plain paper, as I have for a long time. Turned off printer and tried again, nothing. Makes the feeding noise. Ink is full.
Check and see if a pen or pencil has fallen down into the paper tray. That's what happened to me, and my paper wouldn't feed. The pen had rolled way down inside and was hard to see and hard to get it out of there. I actually found it by feeling around and then I felt something that felt oddly like a pen cap! I could barely see it in there, so check it good.
Jan 29, 2010 | Canon i9100 InkJet Photo Printer
My Madza died while driving down th highway, felt
If you dont have much money, guessing what parts to change gets expensive. First, you need to verify if it has fuel pressure and spark, that will lead you in the direction to start looking for the problem. Pull 1 spark plug wire off and see if it will jump a 1/2" gap, If so, thats good. If no spark, make sure the cam is turning, you may have a broken timing belt.
Nov 10, 2009 | 1998 Mazda 626
Black ink cartrage leaked at the bottom of the printer. Cleaned printerhead several times but it still won't print in black.
the black ink did not leak! WHAT HAS HAPPENED IS THE THE MACHINE HAS REACHED ITS CAPACITY TO HOLD INK IN THE WASTE ABSORBER PART ON THE BOTTOM OPF THE MACHINE.THERE ARE USUALLY 3 FELT PAPDS THE ABSORB THE WASTE INK DOWN THERE .IF YOU ARE GOOD WITH YOUR HANDS AND YOU CAN FIND THE FELT OR CUT SOME TO SIZE YOU MAY GET LUCKY. OTHER WISE YOU WILL HAVE TO TAKE IT IN FOR SERVICE GOOD LUCK
Jan 29, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
How to clean konica bizhub c252 imaging unit
look inside the area where the felt rod is inserted
ithe felt side must go up against the roller or imaging unit
I do not know if this is up or down but wen you look inside the lslot you can tell I would think up
these are usually keyed so they only go in one way
Look at the rod and see if the sots are a certain way
Dec 31, 2008 | Office Equipment & Supplies
Service Call 15H
FATAL ERROR CODE 15H / SERVICE CALL 15 XFER BELT: Incorrect pressure
by or separation from the transfer belt cleaner
something wrong with the transfer belt
Aug 21, 2008 | Konica Minolta magicolor 2300DL Laser...
Paper jam
Don't know if it's the same problem i had but its maybe worth a try. Mine is a Canon MP160 but again its maybe worth a try.
My paper went in a little, the wheels were turning but it didn't take the rest of the paper or print.
Someone replied to my problem, i tried it and it fixed 1st time. Also seems to of worked for others
Solution:- Use a piece of thin card, a magazine cover is what i used, make sure its A4 size then try to print something, as the paper starts moving push it through! and hey presto it worked for me, everything printing fine now
Feb 28, 2008 | Canon PIXMA MP780 All-In-One InkJet...
I have a problem with me zebra 105 se, the problem is the ribbons is tense and then the ribbon is broken
Your supply spindle is "too tight".
Procure a "Washer Felt w/lube kit" (Zebra part number 01688-140) and rework the supply spindle. Use only the supplied silicone oil to service the felt washers.
Adjust the tension on the spindle in accordance with the service manual procedure.
Steve
Dec 14, 2007 | Zebra 105Se Thermal Printer
Frigidaire dryer gets clothes caught in between the drum, and body of dryer
Just did this today! The brown marks are the felt that is around the part that suspends the drum. It has probably been making a rubbing noise for awhile? The mechanism that supports the drum and allows it is spin is called a bushing This is no longer balancing the drum properly so it is rubbing against the felt and wearing the felt down. The brown marks are burnt felt rubbing off onto the clothes. Get a new bushing assembly and either a top and or bottom felt replacement kit. Replace all worn felt! The top felt has either two or three plastic gliders on it as well. It has been an all afternoon job for me. A second pair of hands is also helpful so long as you are not married to them! Good luck...(I paid $90.00 for a top felt, bottom felt, and a whole brand new bushing unit.)
Feb 18, 2007 | Frigidaire FER231A Electric Dryer
13 people viewed this question
old marine
old marine
