Question about Morphy Richards Jet Stream 42271 Iron
Water is coming from the plate - Morphy Richards Jet Stream 42271 Iron
Why is my rowenta iron having something white coming out of it?
Do not use water softened by salt. It\'s all the salt coming out of your iron from the water you are using. Use bottled "Spring Water" do not use "Distilled Water". Your iron will spit and pop.
Jun 06, 2014 | Rowenta Irons
Philips steam iron no steam and red tap light is flashing even when filled up with water it's still getting hot and water is boiling but steam fiction not working as red light will not go out
It sounds like the flow holes are CLOGGED with scale inside. To clean it out:
1. Drain the water/steam out the pour-in shoot at the top of the handle, over the sink. Is any crap coming out?
2. Take some VINEGAR and pour it straight into the fill pour-in shoot. Don\'t dilute it. Fill up the IRON to full line. Let the vinegar SOAK the inside of the COLD iron for 15-20 minutes, by placing it FACE DOWN on an old bath towel, on a heat-resistant surface, such as a granite counter top, or metal cookie sheet. Don\'t put the towel on the ironing board!!! It may get stained badly. Let it sit, COLD for 20 minutes. You can swirell the vinegar around by shaking the iron.
Stand it up on its flat end, with the vinegar inside, still. Take some fresh vinegar and dip Q-tips into the vinegar and clean the slots and holes on the bottom plate. Any burn streaks or soil can be removed with wiping the plate with vinegar. After you clean all the holes and slots with vinegar from the outside, TURN ON THE IRON with the vinegar inside. The vinegar will heat up and should come out the holes. If any holes are not blowing vinegar/steam, clean them with q-tips again. Don\'t let all of the vinegar inside steam out!! Just heat it enough to make sure all of the holes are clean. Some white film may come out of the holes on to the face plate--it is calcium build-up from using tap water in the iron.
Now DUMP out vinegar inside the iron and reservoir through the pour-shoot You may see crud and crap coming out. Repeat the process of filling it up, steaming through the holes etc. until the vinegar comes out clear!!!
DON\'T use tap water in any IRON. Use distilled water, or even bottled drinking water (without flavoring, additives, of course). This will prevent corrosion and calcium build up in the iron.
ALWAYS completely drain the iron from the pour-in spout each time you are finished using it!! After pouring out the tank\'s water, you can set the iron to STEAM HIGH, and force any water inside to boil off and out of iron.! Never keep water in the reservoir or iron.
I set my iron, when hot, and done using it, with the pointed side DOWN in the sink drain to make sure it is dry.
So clean it with vinegar often, use bottled drinking water or better, distilled water and it will prevent this.
Oct 24, 2013 | Irons
Steam generator wetting clothes
Heating plate has come detached from the tank. You have to remove the base and tighten the bolts on the heat plate. This ensures that the necessary temperature can be reached and thus steam rather than water comes out. Unfortunately the base is secured with security screws (6 point star with centre hole) so you will need to get one of these to fix it. They are same as used to secure number plates and can be purchased on ebay or at car parts shop
Sep 01, 2012 | Tefal Pro Express GV 8120 Iron
TEFAL STEAM GENERATOR GV8460 NO STEAM IRON HEATS UP
The water is heated by a metal plate that is bolted to the metal water tank, operating in pretty much the same way as a domestic kettle, the plate being the element. The plate is fixed in place by 8 or so nuts onto studs that form part of the water tank and heated by passing electrical current into this plate. Over time the nuts come loose and consequently the plate is not in full contact with the water tank. This results in insufficient heat transfer and a failure to consistently reach the required temperature to create steam. Ultimately you will need to remove the plastic base of the unit to access the plate and re-tighten the nuts. You will need a small 6 star bit with the centre punched out to remove the base as it is secured with security screws. These are readily available on ebay as they are the same as those used to secure number plates.
Apr 27, 2012 | Tefal Pro Express GV 8120 Iron
Water is coming out the bottom of the iron
There is a rubber grommet that lives between the water tank and the heating plate chamber. If the iron was dropped, this grommet might have become disloged. Another possibility is that there is a problem with the chamber, and lastly with the heater plate. Irons are easy to disassemble if they don't have those special little screws that attempt to thwart the efforts from a standard screwdriver. (Please have the iron unplugged. Connectors in there love to hit stuff and you when disassembled.) Good luck.
Feb 26, 2010 | Rowenta Power Duo Iron
Water leaks
poly seal{white} perished where comes from tank to element plate
Nov 17, 2009 | Irons
Sole plate leaking
This IS a steam iron? The iron must be hot for the steam to form. If it's not hot enough, the water is leaking thru the steam holes. Also if the channels are calsified (boiler stone has formed into the steam channels) this may happen.
Nov 04, 2009 | Tefal Irons
BRown water and stuff coming out of iron
Hi, two problems:
DIA' s problem - the brown water is due to poor water quality and debris in the boiler and iron sytem. Rowenta is clear that they do not want anyone to cleaning solutions - only clear filtered drinking water to rinse out the boiler (via the water inlet screw hole) and I have found running the system dry, letting it cool, rinsing and draining the boiler several times before putting unit away works fine.
Guest' problem with brown/black tar substance is likely caused by too hot and iron setting (steam setting may also be too high) for ironing man-made synthetics (like Nylon, Rayon, Polyester or blends are basically petroleum based fabrics) that breakdown or melt, leaving deposits on the iron's stainless steel soleplate. A secondary cause could be bad water or debris in the boiler/iron in which the solution for DIA's problem might provide relief. Cleaning the soleplate is tricky, I use nothing stronger than an old fashioned wooden orange stick to gently scrap of all traces of the "stuff" and dry "Dutch" cleanser w/ a terry cloth or old cotton sock to polish without scratching the soft stainless soleplate...
Apr 01, 2008 | Rowenta DG-980 Iron
Tefal Pro Express Steam Generator doesn't.
OK... so I have fixed my problem of NO STEAM, just lots of water coming out of the iron press plate itself... I had already cleaned the boiler, so I tried adding 1/4 tsp - 1/2 tsp bicarbonate soda to the water and flushing it through. From what came out of the iron press plate, I would say the problem was caused by a build up of goop (technical term) inside the iron. Once cleared, the iron is steaming away again. Please note, u will need to have an old towel handy if this is ur problem, 'cos until it starts getting better, there is a fair amount of water coming out of the iron press plate. Just add the bicarb to the water reserve and use the steam buttons to bring the bicarb through. Do not attempt to iron clothing with the bicarb in the water!!! Carolyn ;)
Nov 12, 2007 | Tefal Ultraglide 1549 Iron
Morphy Richards Jet Stream 42271 Iron Logo
64 people viewed this question
Top Morphy Richards Irons Experts
Mack Baxter
Are you a Morphy Richards Iron Expert? Answer questions, earn points and help others
