Question about Sector Watches
Sector watch glass repair in Pretoria
The glass of my Sector watch has cracked during a fall. Please advise how I should go about getting it fixed.
SOURCE: sector 255 need to contact sector
need help in setting time on sector 550 2653955025.
Posted on Dec 25, 2007
  • 203 Answers
SOURCE: broken glass of my cartier watch
search for horoligsts on the web some of them can cut new glasses. if this helps please rate joe
Posted on Dec 16, 2008
SOURCE: cracked glass (plastic) in SKAGEN 170LTTM
Found a skagen watch repairer in Melbourne , thank you
Posted on Dec 29, 2008
escapement
  • 2334 Answers
SOURCE: Cracked glass on the dial
I have no idea how the things work in India, but any Kenneth Cole dealer shop must be able to sort your problem ( at least it is worldwide experience ). So, visit your nearest Kenneth Cole store and ask for help.
Do not forget to rate, please.
Posted on Feb 06, 2009
dmbgo
  • 58 Answers
SOURCE: skagen watch glasses keep cracking
Yes I would speak to Skagen in stron terms, this should not happen and wa probably aused by the glass being stressed when fitting it
Posted on Jun 22, 2009
I DROP MY WATCH CODE REF IS 1142 I BROKE THE GLASS WHERE CAN I BUY A REPLACEMENT GLASS FROM
Getting a glass shouldn't be a problem, but as it sounds as though you intend to fix it yourself, then please be aware of the following.
It is essential to get the correct size glass - even 0.5mm difference in the diameter means either it won't fit or it's too small and falls out again. As you say that the glass is broken, I would be surprised if you could remove it and still determine the correct diameter.
You need to think not only about how to remove the broken glass, but also about how you are going to fix the replacement one. Many watches have a very fine plastic ring around the glass that holds it in place and this may have also been damaged.
Also, with many watches it's necessary to remove the back, crown and movement to effectively replace the glass.
If your watch has any sort of water-resistance rating then it would need to be retested afterwards.
Bearing all this in mind, I strongly advise you to take your watch to a reputable watch repairer and let them sort it out.
If the glass is anything other than round, then the cost tends to go up. Get an estimate from them first, and decide if what they will charge you is reasonable - if it isn't then spend the money on a new watch.
Hope this is helpful.
Oct 22, 2017 | The Watches
Sector model 31723 broken stem
An independent watch repairman (used to be one at every jewelry store) can probably replace the stem of your watch for far less money, depending the damage you describe. I suspect that the high repair price given to you by Sector means that they would simply drop a brand new movement into your watch and give it back to you. In most cases, though, a replacement stem wholesales for $7-20, and you might be looking at $30-75 in labor, depending on where you live and the type of watch repair shop you're able to find.
When looking for a repair place, I would stay away from the big chain jewelry stores--and also the "while you wait" watch battery shops. Neither of those operations typically has an in-house person with the right expertise to fix your watch.
When all is said and done, it is possible that the nature of the stem break will require more expensive repairs to your watch. A good repairman will tell you if that's the case. Even then, $400 seems very high to fix this problem. In the old days of even 10 years ago, this would be a $25 repair!
Best of luck with your quest.
Dec 02, 2012 | Sector 2653940025 Wrist Watch
The glass face of this watch has cracked-please advise how to get it replaced and estimated cost--thnak you located eastern massachusetts, usa
Good luck finding a crystal, took me 2 years to find one for my bedat 384 women's watch! Finally took a shot and got one on eBay by luck. I haven't had mine fixed yet but hopefully soon. The crystal alone was 100$ and I have no clue what they will charge me to put in the new crystal. I was given a quote of 200$ over 2 years ago when it first happened.
Aug 25, 2011 | Bedat & Co. Automatic No. 7 Swiss...
I have Skagen watch 433LSL1 and a few days ago I
mcdevito75 here, Look for a small watch repair shop in your area, for the replacement glass.
Jul 21, 2010 | Skagen 355LGSC Wrist Watch
The glass face has cracked diametrically from side to side
mcdevito75 here, If it is a crack and not just a scratch almost ant watch repair shop could replace the crystal (glass) a crack means replacement and a scratch might be able to be buffed out, Expect to spend $30.00----$60.00 either way.
Jun 22, 2010 | Skagen 355LGSC Wrist Watch
I have a Sector 600. Inside the face there is a
It is likely that a repair is possible. I suggest that the sooner it is attended to the better, since is might be something like a screw falling out and if this sort of thing did happen then it may be serious.
A local watch repairer may be able to sort it out for you.
Apr 10, 2010 | Sector 600 2653917025 Watch
Skagen watch glasses keep cracking
Jun 18, 2009 | Skagen 170LTTM Wrist Watch
Cracked glass (plastic) in SKAGEN 170LTTM
Dec 28, 2008 | Skagen 170LTTM Wrist Watch
Sector 255 need to contact sector
Nov 16, 2007 | Sector 2653940025 Wrist Watch
Watches Logo
21 people viewed this question
Top Sector Watches Experts
staicuma
Level 1 Expert
aravind shet
aravind shet
Are you a Sector Watch Expert? Answer questions, earn points and help others
