Question about Raymarine EV-100 Wheel Evolution Autopilot
Ev 100 auto pilot will not hold a steady heading , keep swinging
When a way point is selected the vessel sways and rocks, helm over corrects and caused the vessel to rock. this happens even in calm seas. how to you set pu teh halm to respond correctly
2 Suggested Answers
TechnoMarine
  • 132 Answers
SOURCE: sea talk failure
Remove all wiring from 4000 head, hook up only 12V, if seatalk fail continues, it is the head. if seatalk fail goes away, hook in instruments one by one until the bad head is found. Seatalk is 12V red, Ground Screen(bare wire) and Data yellow (pulsing voltage). good luck 847-746-0100 John Barry
Posted on Jan 26, 2010
What inline fuse should be used for 12V power supply from vessel to EV-200 ?
First, type-1 is not an hydraulic system. It's electro-mecanic.
The EV-200 needs 2 power supplies. 1 for the calculation unit ( thru the Seatalk OR by a connection in the ACU ) AND a feed for the pilot motor/pump.
The calculator power ( NMEA ) needs only a 5 amp fuse. The 'high' power needs an eventual 25amp fuse. In fact, the power output to the motor is totally protected from overloads and/or shorts. Have those cables between power distribution and ACU thick enough to handle 20amps on his length ( twice the cable distance between battery and Acu is the lengt to calculate with )
Sep 20, 2017 | Boating
What fuse to be used for power supply from vessel to EV-200 ?
Go by what the manual says. That spec is for the input current , not the output current.
Sep 19, 2017 | Boating
St4000 auto pilot makes 180 degree turn for no good reasonn
It has been a while since I set up my auto pilot, but Raymarine has a very good set of on-line manuals and it would be a good idea to go through the setup procedure again. There is a sensitivity setting that adjusts the responsiveness of the AP in relation to changes in the helm. If it is set too sensitive, the AP will make big changes when the helm slightly moves.
Jan 09, 2014 | Raymarine Boating
I can't figure out how to switch from position 1 to position 2.
U have to grab the bar and like pull out and move it back and forth between positions. If your sitting in front of the swing(chid facing you) grab bar and pull away from you and move seat. Might have to hold the little side thing that says one and two to keep it still.
Mar 31, 2012 | Cosco Juvenile Cosco Sway n Play Swing...
I ned a manual for the boppy rock in comfort travel swing. i am working off an apple computer and do not have a flash player
I cannot locate the manual on their website, links to it from elsewhere on the web show an error on their site. I recommending contacting the company:
Kids II, Inc. 555 North Point Center East Suite 600 Alpharetta, Georgia USA, 30022-8234 tel (770) 751-0442
Jul 24, 2011 | Kids II Boppy Rock In Comfort Travel Swing
How do I light the pilot on my Modine PA105AB?
Look on the side or bottom there will be a little circular door held on with one screw it will swing from side to side there should be a long wire with a hook on the end that looks like a key ring this is used for holding the match if you can't find the match holder in the bottom of you unit find some way to get the match up to the pilot head then turn your gas valve to pilot position and push in on the button while holding the button in light the match hold it to the pilot head once the fire lights continue to hold the button down for 10 seconds then instantly let off the button and turn the knob to the on position and your set .
Hope this helps......
Nov 18, 2010 | Heating & Cooling
What is EV on the menu
Hi cute_chic24,
EV is Exposure value refers to the amount of light for a given exposure. It is denoted as a single number. Its value is subsequently used to calculate the correct combination of shutter speed and aperture at a given ISO speed of the sensor.
Starting point is a shutter speed of 1 second at f1, which is denoted as EV 0. Further up the scale a single exposure of EV13 could be ISO 100, f8 - 1/125s, or f11 - 1/60s.
It doesn't make any difference which combination you choose, as all variations at the same EV will ensure a correct exposure. Remember though, you are always balancing camera or subject movement against depth of field. This is because a change in aperture will require a change in shutter speed for an equal amount of light to reach the sensor or CCD. If you set the shutter speed one stop slower and aperture one stop smaller, exposure doesn't change, but you increase depth of field slightly and the possibility of blur.
ERNZ
Feb 03, 2010 | Sony Cyber-Shot DSC-L1 Digital Camera
Steps to reset 2007 honda pilot oil gauge
From page 232 in the 2007 Honda Pilot Owners Manual.
1. Turn the ignition ON.
2. Press the Select/Reset knob until the engine oil life indicator is displayed.
3. Press the Select/Reset knob for more than 10 seconds. The engine oil life and maintenance item code(s) will blink.
4. Press the Select/Reset knob for another 5 seconds. The maintenance item code(s) will disappear, and the engine oil life will reset to "100".
Feb 27, 2009 | 2007 Honda Pilot
Clunking noise while normally drivin an hitting bumbs or turning right
I don't think that there is a part on your car called the rocking arm. But there is set of bars in the front end called the sway bar. The sway bar helps the car handle correctly and it is critical. I am no expert so I would visit your local dealer or mechanic.
Aug 30, 2008 | 1998 Pontiac Grand Prix
Blury pictures
this probably comes because there is movement of the camera while pressing the shutter full down, especially in night or low light conditions it takes a very long time to take a picture , during that time you have to hold the camera steady . it dos not have a stabilizer (as far as i know) so there is no correction of movement (how little it may be) . you could try to intensivate the settings from standard iso to 400 ( 800 = 3 megapixel max) and the ev to plus 2 (in "bad"light) and the A mode switch to the lowest F size (i believe it is f2.8) than press the shutter halfway , than full (hold it steady)
Apr 02, 2008 | Fuji FinePix S7000 Digital Camera
Raymarine EV-100 Wheel Evolution Autopilot Logo
20 people viewed this question
Top Raymarine GPS Experts
Shehu Pro
Shehu Pro
Steve
Steve
Are you a Raymarine GPS Expert? Answer questions, earn points and help others
