Question about Panasonic Projector Lamp for PT-LB60, PT-LB30 Series
Replace lamp message even after replacing - Panasonic Projector Lamp for PT-LB60, PT-LB30 Series
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 729 Answers
Turn on the projector
MENU-
OPTION-
LAMP RUNTIME-
Press and hold the ENTER button for 3 seconds.
Turn off the power.
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Posted on Jan 15, 2015
I have a Sony VPL-CX61 Multimedia Projector. I just changed the lamp and I cannot get the "please replace lamp" message to go off.
When you use a projector it automatically keeps a timer of how long the lamp has been used for. The message that comes up on screen saying "please replace the lamp" comes up not because it's some how sensing that the lamp is getting old, but because the lamp hours gets to a certain number (usually up around 1500 hours). Because of this when you replace the lamp you need to reset the lamp hours counter, or the projector doesn't even know you've changed it. Every projector does it this way, and they all do it a different way, I googled the model you gave us and found this set of instructions on how to do it, so give it a go.
Reset the lamp counter hours of operation for the projector SONY VPL-CX61
Using the remote commander while the unit is powered up, press "ENTER", "ENTER", "LEFT"
and "ENTER" in sequence. A prompt will appear on the screen asking if you wish to enter the factory mode.
Press the "UP" key on the remote and the unit is now in service mode. This sequence will add two new groups
to the customer setup menu. Press the "MENU" button to view.
Whenever the lamp is replaced, the lamp timer should be reset. With the unit in the "factory" mode, press
"RESET", "LEFT", "RIGHT" and "ENTER" on the remote commander. Verify the lamp hours have been reset to
zero in the service menu.
Hope this worked for you,
Mar 23, 2011 | Sony VPL-CX61 LCD Projector
How long do I have after the lamp replacement warning comes up before I have to replace the lamp?
You can use the Lamp even if the TV displays the message to replace the lamp. However, the performance of the TV, i.e the picture may become dark, entire screen may display in black after some time. If you can view the videos normally even after displaying the message, you may continue using it.
Thanks for understanding.
Feb 02, 2011 | Sony KDF-50E2000 50" HDTV
Replace Lamp message remains on even after
It should automatically reset after replacing with a new RCI cell. If it doesn't then you can try resetting the reminder (the button's on the front). You can also try unplugging the purifier for a few minutes and plug it back in. If all else fails, review the user manual to make sure that you're installing the part correctly. It can be downloaded from the following link:
http://vollara-en.custhelp.com/ci/fattach/get/10/1262011627/redirect/1
If none of the above work then it's possible that the sensor may have gone bad. The manufacturer would probably be the best place to get answers and further help. I believe the company is now called Vollara. Their website is as follows:
http://www.vollara.com/
Jun 28, 2010 | Ecoquest Fresh Air Air Purifier
Replaced bulb but still getting "lamp will fail soon replace" warning
When you replace the lamp, you need to reset the lamp counter as well. The procedure for this should be in the owner's manual. This counter is a guide only. Lamps have an expected lifetime and the message indicates that the lamp is nearing that lifetime. Once reset, the counter will again trigger the message once this new lamp reaches that usage time.
Dan
May 06, 2010 | Optoma H30 Multimedia Projector
My mfc240c says to replace the yellow ink cartridge but I don't want to spend money on that if the 'light bulb' is ruined. When I turn on the machine, I don't see any light for scanning or copying. ...
By the "light bulb," do you mean the scanner lamp? That lamp should only turn on when you are actually scanning, faxing, or copying a document. You should be able to still use the machine to scan and fax, even with the yellow ink empty. Try scanning a document to see if the scanner lamp comes on.
As far as printing or copying goes, you won't be able to print or copy anything until you replace the yellow ink, even if you try printing in black and white only.
Apr 19, 2010 | Brother Multi-Function Center MFC-240C...
Mitsubishi WD-52525 52-inch DLP HDTV ywllow warning lamp light
that means your lamp it is getting to the end of its life.
sometimes even if the lamp still good the TV will send you that message because that timer is closed to 5000 hours
What you can do is open the lamp door, closed again and the tv will ask you if you replaced it the lamp, and just say yes and that sign will go away
or just simple replace the lamp. 915P020010
Apr 18, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Need instructions for lamp unit part number TY-LA2004
the projector will not know that u have replaced the lamp!u will have to tell it that a new lamp has been installed
to do this go to the menu & find reset lamp hours option & do a lampo reset.the lamp hours will reset to zero & then the replace lamp message will nt appear!
Jan 28, 2009 | Office Equipment & Supplies
Please replace the lamp
On your remote,push these 4 buttons in this order.
RESET < > ENTER
Jan 12, 2009 | Sony VPL-CS7 Multimedia Projector
Lamp Hour Meter
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Lamp hour reset to many popular projection TVs are given.
Mar 03, 2017 | Televison & Video
Panasonic  Projector Lamp for PT-LB60, PT-LB30 Series Logo
48 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
