Question about Electrolux Epic 6500 Vacuum
Beam central vaccuum repair manual - Electrolux Epic 6500 Vacuum
On my M&S Air Vac AV425 central vaccuum system, the system usually turns on by inserting the vaccuum hose into one of the vaccuum outlets. However, it now runs continuously. I am able to turn it off...
we are a central vacuum service company and we service all of new jersey. sounds like you have a short some where that keeps your unit running or it could be your relay module thats stuck our number is 908-721-7595 its j&j central vacuum services
Dec 28, 2010 | Vacuums
I have a Beam Rugmaster Plus power head Model BM1 393 Type AB and the connection were the metal pipe meets the plastic swivel broke close to the unit. It appears like a manufacture defect in that is broke...
This is most likely repairable. Lots of the Beam parts are available. I would recommend checking out any local vacuum shop or searching online for a central vacuum store that sells beam products.
Sep 29, 2009 | Beam Industries 750 Classic Bagless...
I have to reset my Beam Central vac quite often!!!
Check to see if there is a clog in the system. Something is causing stress on your motor causing it to switch off. Or it could be the motor itself failing.
First check for a clog, if you can't find anything wrong, call Beam for assistance
Aug 21, 2009 | Vacuums
Central vacuum power head no work
Looks like a Beam central vacuum www.beamvac.com, and a Kenmore vacuum head.
Reply what problems you are experiencing and I will try to help.
Jan 23, 2009 | Vacuums
Do you know what a filter bag looks like in a central air vac system?
The unit displayed is a Beam Electrolux central vacuum power unit. It has a 15litre dust bucket which does not need any dust bags.
If you take the bucket off you will notice a white shiny weighted bag hanging down. This is the filter. The good news is, it is a self cleaning filter.
Dec 03, 2008 | Beam Industries 2775 Serenity Plus Central...
Beam Central Vac Breaker Pops
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=797869
Generic problem for all Vacuums
Posted by tinateggart1 on Jul 17, 2008
The breaker on our beam model 167 central vac popped while in use. Every time I try and restart it, it immediately pops again. What's the problem? Circuit board? Motor? Overheating?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Chances are it is the relay switch on the inside of the Beam Central Vac, if it was a motor, it would not turn on @ all. If it was a circuit board, it may or may not be turned on, but if it will turn on and then pop your circuit breaker than it probably is the relay switch. Please, check with your local Beam vacuum cleaner dealer in your area or contact the Beam website or cust serv @ the phone number listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.beamvac.com/usa/ Owner Support
Customer Service 1-800-369-2326 Phone #
Email: beam.dir-support@beamvac.com
Technical Support: beam.tech-info@beasmvac.com
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 17, 2008 | Vacuums
I have a one year old Beam central vac. It has supervalves. The handle (connected to the hose stopped turning on the unit. The handle still powers the brush but no longer turns on the suction?
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=566201
I have a one year
posted by jon89 on May 02, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The Beam Central Vac may have more than a one year factory warranty and it sounds to me that you may have a bad relay switch the Central Vac, if you do it should be covered under the factory warranty. Otherwise, you may have a bad supervalves or a wire came loose, if the hose switch turns on the power nozzle then it may be a bad supervalve or a bad relay and to contact the installer or the manufacturer of Beam. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Go Ahead. Use Us.
May 02, 2008 | Vacuums
No suction beam serenity plus
You may need a new filter bag part #110346. They can cause suction problems at the unit. Either that are there is a problem with the motor, does it sound alright when running? If not, take it to a beam repair shop, with proof of purchase, the motor would be under warranty for the part only, not labor. The filter bag is not covered by warranty.
Mar 26, 2008 | Beam Industries 2775 Serenity Plus Central...
Vacuums Logo
19 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
