Question about Frigidaire Washing Machines
Water runs slow - Frigidaire Washing Machines
  • Frigidaire Master
  • 5,323 Answers
WATER INLET VALVE
Posted on Mar 31, 2015
Have a slow drip in water dispenser GSS201EPWW Gen Electric fridge
Most likely you need to replace the water valve first try running at least a gallon water through it to flush it out if that doesn't work new valve is needed
Jan 23, 2015 | GE GSS20IEP Side by Side Refrigerator
Change water filter. now water is running slow. put old filter back in, still running slow. ICE2O
Hello, Thank You for using FixYa. I will be helping you today.The only thing that can cause slow water is low water pressure from the house line a bad filter or a frozen water line or tank. Most of the time its the house water supply it should be at least 35psi.
Thank You and please rate my answer if it was helpful..
Jun 10, 2011 | Maytag (MFI2568AEW) Bottom Freezer French...
Runs slow
There is a quick and inexpensive solution to the problem. Household vinegar. Pour about one cup vinegar into water reservoir, replace filter basket without filter allow it to cycle through. After it has finished brewing, you may repeat with another cup of vinegar. Once you are finished running the cycle with vinegar, fill water reservoir with water and cycle through. Be sure to run water through machine at least twice to rinse out all the sediment and or vinegar. Works everytime my coffee maker starts running slow.
Jun 17, 2010 | Cuisinart DCC-1200 Coffee Maker
Coffee maker is not pumping water fast enough. takes over a minute to brew a 8 oz. cup. pumps water real slow.
have you tried cleaning it? Minerals from the water build up inside the tubing and make it run slow. Take a pot full of white vinegar and run it through a brew cycle. follow this by a couple of pots of cold water and you should be good to go.
Nov 04, 2009 | Keurig B60 Coffee Maker
Slow running water dispenser
the inlet water valve should be replaced but first go to where the water is connected to the pipe and close than open the valve all the way
Aug 09, 2009 | Refrigerators
Water in door runs slow even with a new filter
Check for inline filters on the water source.
Jul 31, 2009 | GE Refrigerators
GE WATER DISPENSER RUNS SLOW AND GIVE WARM WATER
With the refrig , you should have gotten a small bypass piece which fits in place of the inside filter . Install this to see if the filter is good or not . Water faster , replace filter , still slow , possible water valve problem . Also use a connector usually a 1/4 x 1/4 compression fitting , to bypass the outside filter for test purposes only .
Jul 19, 2009 | GE Refrigerators
Kenmore wash macine
its in your cold water line valve to the washer if it works good with hot water the valve are incoming line being blocked when you turn it on the pressure comes in fast then when pressure is gone water slows down so when its off the pressure builds back up it runs fast then slow
Feb 27, 2008 | Washing Machines
Slow water run for cold water
slow water run could be caused by the filter on the cold water hose is clogged by granite or mineral deposits
1. turn off the water to the cold hose
2. drain water out of hose and detach from washer
3. get a water spray bottle and set to strong stream not spray,
spray the filter that goes into the machine, this should clean out the debris that is clogging the line hold a small container to catch water when you spray if you see black specks it granite
4. after it runs clear reattach hose and turn the cold water back on that should solve your problem, it did the trick for me
Dec 21, 2007 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
13 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
