Question about Mossberg Optics
Mossberg 817 magazine
Spent round will not eject from chamber
  • 143 Answers
Not much can go wrong. Have you checked your extractor? If it's intact and not broken, try moving it with your thumbnail. Is it loose? That's a spring problem. If it's tight and intact, WITH THE BOLT OUT, try slipping a small diam wooden dowel down the barrel to see how hard it is to push a spent shell out. If it's tight, you've got a burr in the chamber or dirt/varnish buildup. Examine the shell for scratches. If the shell's good and no scratches, clean the chamber with a brass brush mounted in a drill.
Posted on Aug 18, 2016
3 Suggested Answers
  • 190 Answers
SOURCE: My Remington model 7400 semiautomatic 308 rifle
All Remingtons of this type have this problem burnt powder and oil mix to stop everything up but it is an easy fix, Remove the two push pins that hold the trigger group in and pull trigger and all out. put it in a container of kerosene and let it set over night take it out and clean it up good and put it back in. It should be good as new
Posted on Nov 01, 2009
  • 425 Answers
SOURCE: Convert fixed SKS fixed magazine to removable 20
I think if you watch this video you may be enlightened:
Posted on Feb 13, 2010
How to Install a magazine plug on a mossberg 9200
Read the text here
mossberg manual -
  1. Cached
  2. Similar
To install the barrel, unscrew the forend cap and remove the forend (Fig. ... MAGAZINE PLUG - You are responsible for complying with all laws regarding magazine ... Model 9200 is designed to fire 12 ga. shells ranging from 2-3/4" target and.
There are videos on this here
Install magazine plug on mossberg 9200 Google Search
Oct 28, 2016 | Mossberg Optics
I have a 11-87 that I can only feed one round into the magazine. I can chamber it from there and put another round in the chamber, but no more. Why?
there could be a deer plug in the magazine many states only allow so many in the gun while deer hunting
Mar 19, 2015 | Optics
Where can i find a magazine loading chamber for a mossberg 835 12 ga. pump? and how much?
I'm sorry but I don't quite know what you mean, sir. Can you explain a bit?
The 835 is a tube mag pump action. You load it by slipping a shell into that open area on the bottom of the gun, slip the shell forward into the tube until it's thumb knuckle into the tube. That gets it past both shell stops.
Apr 09, 2014 | Mossberg Model 835 Ulti-mag Turkey/deer...
Mossberg 500, shell will not eject
did you check the elevator to make sure its not applying the pressure on the cartridge interrupter and cartridge stop? or that one or both aren't damaged and over bent. the ejector slot on the bolt isn't damaged, or the action slide bars.
Dec 28, 2012 | Mossberg 500 AllPurpose Field Shotgun 20...
My Mossberg 500 12 gauge shotgun double feeds cartridges and jams
There should be a catch on the magazine tube of the shotgun, is it ejecting two shells into the chamber when you try to cycle the action? If so check to see that the catch is not damaged. I have the same shotgun and I can take a look at it when I get home.
Nov 23, 2012 | Office Equipment & Supplies
How to load a mossberg model 283tb
WRONG!!! A 283TB doesn't have tube magazine, it has a box magazine that's loaded through the breach. Put on the safety, load a shell fully into the barrel. Then press the second shell into the magazine-back end first. Then press the second shell down in the magazine with the third shell, back side first again. Then press both shells in the magazine down until the bolt can be slipped back forward and close the breach.
Mar 06, 2012 | Mossberg Optics
After 1st is fired it seems to not eject the empty casing or next round misfires. Several times it will misfire. I'm using Federal Long Rifle, High Velocity, 36 Grain Hollow Points. My email address is...
First, listing a gun problem in the Toys section is kinda confusing. 36 grain, so i assume .22 caliber. Is this by chance a P22 or P99?
Next: ejecting vs extracting. Extracting is the act of the spent brass being pulled from the chamber as the slide moves backwards. Ejecting is when the spent casing is thrown from the gun, leaving a clear path for the next round to slide into the chamber.
The most common problems with .22 pistols is that they are dirty. Hands down, and I know this from working at a range. Strip that gun down, and clean the hell out of it. If you're not comfortable, have a gunsmith do it for you. Next, check for burrs (rough edges of metal) on the extractor. Also check for burrs or rough spots on the feeding ramp into the chamber.
If everything looks good, try different ammo. I've seen all different types of ammo fired through different weapons systems, some worked and some didn't. Wolf ammo hates American rifles, its just true. .22 LR is cheap, buy a few boxes of different brands, and see what your weapon likes to fire.
If this is still giving you problems, let me know, and i'll walk you through it step by step
Mar 29, 2011 | Walthers Toys
My model 742 lever action missfires every 3 or 4 rounds.dimple on spent cartraige is much deeper than missfired shells
This may be an indication of a broken firing pin, dirt in the firing pin channel, or an over oiled firing pin/channel. All will exhibit this behavior. A through cleaning is called for, with dis-assembly to follow for parts inspection.
I have also experienced this behavior from a weak hammer spring.
Oct 10, 2010 | Mossberg Marlin Rifle 992m,989,mossberg...
How do you load a 12 gauge pump action Mossberg (500)? There is no magazine for it, but, is mag ready. How do you manually load?
The loading port is on the bottom of the reciever. You mention that it is "magazine ready"? Mossberg shotguns have a tublular magazine underneath the barrel, surrounded by the action bar and front grip.
Loading the magazine entails holding the shotgun in one hand, taking the shell in the other with the folded end facing the front end of the barrel. Place the shell in the magazine opening (on the bottom) and push it up with your fingers and forward with the thumb of the same hand. It will go completely forward of the silver/blue lifter and stay there when you let go. (the action must be closed to load the magazine).
Alternately, you can open the action and pop a shell into the ejection port on the right side, close it back up, and shoot!
Sep 17, 2010 | Mossberg Optics
Optics Logo
75 people viewed this question
Top Mossberg Optics Experts
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Mossberg Optic Expert? Answer questions, earn points and help others
