Question about Panasonic KX TG6511 Cordless Phone
I CAN GET DIAL TONE
BUT WHEN I TRY TO MAKE CALL IT DOESN'T GO THRU..
No dial tone when I plug into netgear wgr614
I'm not sure why you think you should be getting dial tone out of a wireless router? If you have bundled service thru your ISP and they are providing phone service then they will provide another device that plugs into your router and connects to your phone jack. This device provides the dial tone.
Dec 03, 2012 | NetGear WGR614 Wireless Router
No dial tone
Your computer shouldn't have a dial-tone. If it's your phone that you're talking about, ensure that there's a correct connection. If that doesn't work, try using a different phone. If the issue remains, call your phone provider and they will come and fix it.
Nov 05, 2012 | Computers & Internet
My phone doesn't have dial tone. Each time I dial a number and try to call,it wont work. I call my phone but it wont ring. I need help on this. What happen to the phone? Or what should I do?
If you have another phone connect it to the wall outlet to see if you get a dial tone. This will indicate if your base unit is faulty.
Check the power adapter to the base unit, make sure it is getting mains power.
If the base unit has dual phone lines and if line 1 is only connected and the line 2 has beed selected then you cannot get a dial tone. In the chase press the line 1 to get a dial tone.
If your base unit has only one line then check the phone line at the wall socket make sure it is plugged in tight, also check the the connection at the base unit.
If this does not work then ring the phone company and get the to test your phone line, you may have a faulty line to your home.
Feb 03, 2012 | AT&T E2116 2.4 GHz Cordless Phone
No dial tone
  • First, try to check every telephone line is properly plugged into its phone jack. If you have a problem with just one phone, plug a different phone into that jack. If the second phone works, the problem lies in the first phone.
  • Then unplug each phone and answering machine in your house, one at a time. Wait 30 seconds after unplugging the first device. Pick up another phone to see if there's a dial tone -- if there is, then the first phone may be faulty. If not, continue unplugging phones in the same way and check for dial tone. If you find a phone that doesn't work, plug all your other phones back in and see if they work properly. The faulty phone should be replaced.
  • or disconnect the plug from the test jack inside the exterior box. This disconnects your inside wiring from phone company's line. If you have more than one line, select the test jack for the line that is causing the problem. Plug your phone into the jack; this plugs you directly into the phone company's line. If you have a cable modem, plug the phone directly into the jack on the modem.
  • Then pick up the phone receiver to see if there's a dial tone. If there's no dial tone, the problem is with your outside wiring. If there is a dial tone, the trouble is caused by your inside wiring, equipment or jacks.
  • Hope it will help you. Thanks for using FixYa.
  • Oct 19, 2011 | Lands Phones
    Handset doesn't have dial tone. says check TEL line.
    For this type of problem, you need to isolate the issue. It could be the phone, the inside wiring, or the outside wiring. I like to use an old rotary phone for testing but any basic corded phone should work. Get a new RJ-11 phone cable as well.
    Unplug the base unit and plug in the test phone to that jack. Check if you get a dial tone. (Try a new cable if the initial one doesn't work.) If your test phone has a dial tone, then the problem is isolated to the cordless phone. (If the test phone works with the new cable, do check if Uniden works with that cable.) Modern phones are not designed to be fixed by the consumer. If the phone is under warranty, contact Uniden Customer Service. (Otherwise decide if the costs are worthwhile for you; there will be a significant delay before the phone is returned/replaced.)
    If you do not get the dial tone, you need to track down the wiring issue. Next move to another jack on the phone line and check if there is a dial tone on your test phone. If there is a dial tone, you have isolated the problem to the jack or the wiring to the jack.
    If there is still no dial tone, find where your telephone service comes in to your building. If you can, open the box. Determine the type of connection used there. If you are lucky, you will find a RJ-11 jack for your phone line. Plug in your test phone and check for a dial tone. If there is no dial tone, contact your telephone provider. They will fix this outside problem for free.
    If the connection is not a RJ-11 jack, you will need to call the telephone company so that they can determine if the problem is inside or outside.
    If you do have a dial tone, then the problem is with the inside wiring. Inspect the visible wires for damage. Open the faceplates for the jacks and check for loose wires. There are two types of connectors. Screw type connectors need the wire stripped back a little then wrap around the screw and tighten. The other type is a punchdown jack. To repair a loose wire in this, you will need a punchdown tool. These are often available in hardware/home improvement stores in the wiring section. http://www.lanshack.com/wire_phone_jack.aspx has clear pictures of the wire color to pin pattern.
    You may want a professional to check the wires inside the walls. Your telephone provider will do this for a fee.
    I hope this helps.
    Jun 21, 2011 | Uniden Cordless Phone
    Mitel 5212 no dial tone and goes straight to voicemail
    Not too sure about the no dial tone issue, but you can check to see if the DND is turned on...
    Press the Blue Superkey and scroll thru till you see DND (Do Not Disturb) is on and shut it off.
    Jul 20, 2009 | Mitel 5212 IP Phone
    No dial tone in Clarity C4230 setup
    if you can get dial tone with another phone, look into manual for any instructions, usually a toll free number for help. ( BEST ) otherwise take phone back for exchange. may be problem in the board.
    Apr 16, 2009 | Clarity C4230 Cordless Phone
    Panasonic KX TG6511 Cordless Phone Logo
    18 people viewed this question
    Top Panasonic Lands Phones Experts
    guyvstewart
    Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
