Question about Schwinn Solution FS AL 26 Men Mountain Bike
Need new gear and attachment - Schwinn Solution FS AL 26 Men Mountain Bike
    Master:
  • 706 Answers
Contact your local bike shop for asistance
Posted on Dec 02, 2014
Professional 600 575 watts 6 qt. beater stem is loose and lets beater drop onto bowl.
b68be83b-c0cb-45d6-8d74-337f1cf098bd.jpgThe part you see is called the planetary, it has two shafts, the long one is called the center shaft and if it is falling off you need a new planetary, the second shaft (shorter) is called the agitator shaft (the beater attaches to it, if this is the culprit then1 you are not attaching the beater correctly2 the locking pin that the beater attaches to to hold it in place is missing3 you have way too much "gunk" build up on the agitator shaft and the beater is not attaching correctly4 if the beater falls into the bowl with the agitator shaft still attached you have three additional problems a) the snap ring a top the agitator shaft has broken off or come off which in turn means that
b) the gear at the top of the shaft has come off and may very well been knocked around and possibly damaged beyond future use which means that you will need a new one and also
c) the shaft pin that holds the agitator gear in place has come out or been broken also
the fix is easy and your parts cost $ will be from $30.00 to $80.00 dollars depending on which parts you need. Now before you get palpitations, cost are listed as a possible need
1 new planetary $30.00, you may not need
2 new agitator shaft and gear assembly $27.00, pretty sure that you need but maybe not
3 new gasket $6.00
4 new gear grease $6.00 KA says 2 oz. (don't buy a 2lb (26.00 bucks) can when you only need 2 oz).
Without more clarity or a picture I can't help further. but before you start tearing you machine apart go to the KA website and get a parts list for your mixer
http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=KAD
let us know how you fare on this or better yet get us a little more info and we can help more.
Apr 17, 2013 | KitchenAid KP2671 Professional 6 Series...
Gear shift stuck
Hi Ray, The advise above is good and should be checked out. If that does not solve the problem, before looking for a replacement transmission check and make sure the clutch is fully disengaging. If the clutch is mal adjusted that can also cause a problem with shifting gears. If the gears are stuck and wont shift at all the problem is most likely with the selector rods and/or forks. In that case you'll need major transmission work carried out. Regards John
Nov 19, 2011 | 1987 Chevrolet Spectrum
The pedals will turn but the wheel does not
The rear set of gears, called the "Freewheel" are shot, and need to be replaced. You can find another wheel, but this will probably prove to be difficult, or you can pay for a new freewheel or your bike shop may give you an old one for a discount.
Good luck
Joe
Aug 29, 2011 | Cycling
How to locate transmission speed sensor and replace it on 2002 xg350
Hi, to remove the sensor and gear assembly, remove the 10mm bolt attaching it to the transmission. Then, twist back and forth while lifting out of the transmission.
Once you remove the sensor, you'll have the sensor and gear out of the transmission. Check the plastic gear. If the teeth are damaged--usually, the center portion of the teeth is worn-- you'll need a new gear. To remove the gear from the sensor, simply remove the clip holding the gear onto the sensor...
Jul 24, 2011 | Hyundai XG350 Cars & Trucks
How do you change the oil pump in a 1995 Lumina van with a 3.8?
REMOVAL
  1. Remove front cover.
  2. Remove oil filter adapter, pressure regulator valve and spring.
Fig. 16 Oil Pump & Housing 42162079
  1. Remove oil pump cover attaching screws, then the cover and gears, Fig. 16 .
INSPECTION
  1. Check pump cover and housing for cracks, scoring, porous or damaged casting, damaged threads or excessive wear or galling. Replace as required.
  2. Check pressure regulator valve for scoring, burrs or sticking in valve bore. Replace as required.
  3. Check pressure regulator valve spring for tension loss or bending, replace spring as required.
  4. Check gears for chipping galling or excessive wear, replace as required.
Fig. 17 Oil Pump Inner Gear Tip Clearance Inspection 42162080
  1. Measure oil pump inner gear tip clearance, Fig. 17 . Maximum clearance should be 0.006 inch.
Fig. 18 Oil Pump Outer Gear Diameter Clearance Inspection 42162081
  1. Measure oil pump outer gear diameter clearance, Fig. 18 . Clearance should be 0.008-0.015 inch.
Fig. 19 Oil Pump Gear End Clearance Inspection 42162082
  1. Measure oil pump gear end clearance with gear dropped in housing, FIG 19. Clearance should be 0.0010-0.0035 inch.
  2. Measure pressure regulator valve for valve to bore clearance of 0.0015-0.003 inch.
INSTALLATION
  1. Lubricate all gears with clean motor oil, then install gears in housing.
  2. Pack pump cavity with suitable petroleum jelly.
  3. Install pump cover and cover attaching screws. Tighten cover attaching screws to specifications.
  4. Install pressure regulator valve and spring.
  5. Install oil filter adapter using a new gasket, tighten oil filter adapter attaching bolts to specifications.
  6. Install front cover on engine. During front cover installation, ensure inner pump gear is properly engaged on crankshaft sprocket.
Jan 29, 2011 | Chevrolet Lumina APV Cars & Trucks
I have an UT15520A expand-it 10" pruner attachment
I just tried to order that part from Gardner and the part is no longer made and none are in stock... Boy this is bad, this is the one part that wears out
This is the message I got....
Part is No Longer Available (and none in stock)
Nov 10, 2010 | Homelite Expand - It 10" Pruner Attachment
Truck stuck in accessory
The sector gear attached to the igintion hind end is stripped out. A new sector gear is needed along with the key cylinder too. The sector gear rides on a rack that has a rod attached to it that moves the contacts to the electrical ignition switch at the bottom of the coluum
Mar 28, 2010 | 2000 Ford F150 Flareside SuperCab
Windshield wipers dont work back window i can hear the motor but wont work
the best thing to do is remove the back cover off the lift gate and you can see what part exactly is not moving the wiper. The unit in one whole entire unit which the motor attached to the gear box. The motor is good but the gear box assembly attached to the motor can be worn out leaving the motor turning and the gear is not working to move the wiper. junk yard its the best place to get a replacement for cheap or new will run 65-70 bucks at autopartwearhouse.com. Rachet with long extention set its all you need to replace the unit you can do it your self removing the old unit replacing with new one.
Aug 25, 2009 | 1997 Chevrolet Blazer
The white gears on my royal vf1000mx is broken. I need to order new gears or new shredder to attach to my basket. need info about who to contact or how to fix this problem. Thank you very much. Lee
call a repair company and find out labor cost. (You probably would not get it back together and timed) nor will anyone sell the gear at reasonable price. compare cost of replacement. you should also consider how much use you have had out of the cutter head. They so wear out, the more staples,paper clips and glue the faster they wear out
May 07, 2009 | Royal Office Equipment & Supplies
Schwinn Solution FS AL 26 Men Mountain Bike Logo
56 people viewed this question
Top Schwinn Cycling Experts
Michial Gueffroy
Tony
michael
michael
Are you a Schwinn Cycling Expert? Answer questions, earn points and help others
