Question about Kenmore Sewing Machines
Need to know how to wind bobbin on kenmore 148.274
SOURCE: brother xl 3030 - how to wind bobbin
did you get it figured out? I can scan or fax you the manual.
Kim
Posted on Feb 14, 2009
SOURCE: can't wind bobbin kenmore 16221 sewing machine, no manual
On the right side of the machine there is a large knob at the top. Pull that out and you can wind your bobbin. Don't forget to push it back in so you can sew :)
Posted on May 02, 2009
  • 1116 Answers
SOURCE: my kenmore sewing machine won't wind the bobbin
Not all models are the same.
You will have to refer to the manual to see what needs to be engaged or disengaged.
On some machines, this is loosening the center knob on the handwheel and moving the bobbin pin to the right or the winding knob to the left.
There are threading/bobbin winding guides sewusa.com where you may find your model or one that is similar.
Posted on Mar 21, 2010
  • 3 Answers
SOURCE: Sears Kenmore Sewing Machine Model 385. 1254180 Bobbin Won't Wind
The winding sound is the rubber O-ring against the spinning pulley (back of hand wheel) - do not let this continue, it will wear out the O-ring.
I had the same problem and I found the shaft bushing of the winder dry and needed lubed. Use oil or spray lithium grease and it should work fine. Spin the bobbin shaft by hand (not the hand wheel) to get it freed up after oiling.
You can oil from the top and should take off the side case to clean the excess oil from the O-ring. The shaft bushing is a tight fit and any dry oil will get sticky and prevent winding.
Posted on Nov 05, 2010
SOURCE: BOBBIN WINDER WON'T WIND
bobbin wont wind on sewing machine
Posted on Dec 08, 2010
Digital display shows bobbin wind. Bobbin wind spindle moves slightly. When depress foot pedal, stitches for only a minute- stops. Cannot select any stitches as menu display remains on bobbin wind.
try putting a bobbin on to wind and then take off again, make sure when you do that the bobbin holder clicks back into the sewing position not the winding, you might need to give it a little push in the right direction then see if it sews ok for you. if not may need a service call.
Jul 20, 2017 | Sewing Machines
How to get it off bobbin wind
This is covered in the user manual. If you haven't got one search online for "user manual + your make & model". You should get several decent hits like. http://homeappliance.manualsonline.com/manuals/device/sewing_machine
Aug 08, 2015 | Sewing Machines
I do not know how to thread my kenmore 385 sewing machine. I also need to know how to thread the bobbin.
They have threading diagrams for Kenmore 385 models here.
http://www.sewusa.com/Sewing_Machine_Threading_Diagrams.htm
Scroll down until you get to the Kenmore section.
I think they include bobbin winding etc.
Hope this helps!
Oct 30, 2010 | Sewing Machines
My kenmore sewing machine won't wind the bobbin on. The motor runs but the bobbin is not engaged.
Mar 21, 2010 | Kenmore Sewing Machines
Bobbin winder will not wind
The bobbin winder will not activate to turn the bobbin or the thread will not wind onto the bobbin spool?
Sewing machines vary in the method used for bobbin winding.
You can find threading and bobbin winding guides at sewusa.com.
If the winder is broken, you can get it repaired or check into getting a Sidewinder Bobbin Winder as an auxiliary for winding the bobbins, which would be less expensive than the repair.
Mar 13, 2010 | Kenmore Sewing Machines
Machine won't make a bobbin. I can hear something whiring, but nothing turns to make the bobbin.
There are many models of Kenmore and without a model number, I cannot answer.
Refer to the manual for the bobbin winding setup.
If you do not have a manual you may be able to find a threading/bobbin winding guide sewusa.com - you will need a model number.
There may be one guide that serves several models.
Feb 23, 2010 | Kenmore Sewing Machines
Apr 03, 2009 | Kenmore Sewing Machines
Winding the bobbin
sometimes with older machines you need to add a little tension on the thread your winding from with your finger. It sounds like its coming off the spool too fast to keep up with bobbin winding.
Mar 31, 2009 | Kenmore Sewing Machines
Can't wind bobbin kenmore 16221 sewing machine, no manual
Dec 22, 2008 | Kenmore Drop-In Bobbin 16231 Mechanical...
Kenmore Sewing Machine model # c877.15
I have a Kenmore as well ,I hope that this will work for you ,too bad that I don't live close to you otherwise I would give a hand. This is the way I fill the bobbin on mine. Mine is located on the top right ,I put the thread into the bobbin hole leaving a small piece of thread hanging for me to hold when I begin the winding, I pull the wheele out to stop the needle from moving while winding, when I am done just push it back in .I run the thread from the spool into the top left it looks like a U turn with a screw go around that without winding just pull it into the bobbin hole. press the foot control and it will begin winding .
Jul 17, 2007 | Kenmore 15208 Mechanical Sewing Machine
Sewing Machines Logo
35 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
