Question about Ovens
No Power Just got this appliance yesterday.Plugged it in and nothing happened--tried a different outlet, still nothing.Is there anything I can do or should I send it back?
  • 109 Answers
I would contact the manufacturer firstly and if no joy, conatct a service/warranty agent.
The Oven should be repairable under warranty.
Posted on Jun 19, 2009
If you switch oven on it trips main power. what can cause that
Probably close to 50 things could cause that, but here are a few of the most common: Bare wire in a harness of the oven, causing a short-circuit in the line. Faulty plug on the power cord. Outlet in the wall is damaged. Loose wire in the outlet box, causing a dead short. Bad wire between the outlet box and the main breaker box. Weak breaker, or a breaker that isn't heavy enough to handle the load of the oven. (especially, if you just bought a new oven, it may need a larger breaker to handle start up.) Use a fused multi-meter (voltmeter) to check for these issues, and do not try to fix it if you are not familiar with electrical work. It could cause a fire, or give you a deadly shock.
Feb 12, 2017 | Ovens
Breaker fine--power at the appliance. Nothing showing on the display. Is there a reset somewhere?
ovens use your houses power in a different way than most of your other appliances (especially any you'd ind in the kitchen) they must have two power feeds to them , a normal (quickie checker) type of power tester that most home owners have/use will not indicate accurately that appliance is receiving its proper power , that's the simplified version here's the technical version:
ovens require split phase power , 240 volts this is double whats available in a normal wall outlet , this is why oven plugs look different than any other in your home , also why you use extreme caution around them!!!!!!! if your oven doesn't light up even on the inside (oven) then im gonna lean towards you not having all the power it needs coming to it (lots of reasons this could be) aside from hauling oven over to
nighbors to plug it in there home (joking don't do that) for testing it , im gonna say you need to consult a qualified service technician on this one, they have the tools and knowledge to diagnose the problem
Sep 17, 2015 | Ovens
Oven is two weeks old. Town had a power outage we reset at breaker but still just beeps once and nothing happens
power outages cause power surges when the power comes back on
this surge generally manages to fry the power/control board
I suggest that you get the services of the service centre to come out and check it out.
May 30, 2015 | Bosch 27" Double Wall Oven HBN56
Kitchen aid microwave door error
Try unplugging it to reset. Also, check your circuit breaker...as an additional check point. This will shut power to the outlet as well as the microwave completely.
Mar 05, 2014 | Ovens
The light of the easy bake won't turn on
Take a working lamp and plug it in to the electric outlet you plugged the oven into and make sure it's ok.
There is nothing in the instructions if a light-bulb is used, it does say heating element but there is nothing on how to change anything.
The instructions don't tell you anything but how to use.
If you can return it, do it as fast as you can. If you can't you are going to have to call Hasbro.
1-800-327-8264
So sorry I couldn't be more help.
If you don't get somebody that owns this to respond just post it again, if you don't want to return it and want someone who has it to respond.
Because the door does not open, has no door, the only place I would think of is the bottom might have a access panel.
Have someone see if it has a panel that can be opened and look inside for a bulb and check to see what size and wattage, then make sure you use a appliance oven bulb.
Apr 02, 2013 | Ovens
Belling BI60F oven blown fuse?
Not really. there would be a short circuit somewhere. possibly the element or somewhere in the connections.
Jun 04, 2012 | Ovens
My Gas Oven has no power at all. The electric panel shows nothing. Please help! Thanks
check the circuit breaker on your electrical panel to see if it has tripped.
If you can move the oven, make sure it is plugged in. if it is, try unplugging it and plugging a lamp in. If it lights up, contact an appliance repair shop.
May 13, 2011 | Ovens
My MV1608WW microwave oven stopped working a while back. I have had it a couple of years. The power came on and lights, but nothing on the key pad worked. I had it unplugged for several months and...
The electronics inside the unit may have just needed to be reset by removing power to it. I can't tell you whether or not it's safe to use. If you are unsure I would suggest having it checked out by an electrician or appliance tech first.
Apr 07, 2011 | Ovens
Whirlpool double oven RPD275PD Error codes E6 (red) and F2 (green) with lock icon in between them.
you either have a bad control board or key panel but you can't get parts for this oven anymore,you'll have to replace the oven or you can try this because it sounds like the board is bad,either you or you get someone in to remove the board,you make a diagram of the wires,take out the board and send it out and have it rebuilt,it usually takes 10 to 14 days to get it back,then you reinstall the board and wire it.i've done this on older thermadore stoves,has the clock ever gone blank or anything crazy like that?if so then you know it's the board but i just googled it and these guys rebuild it for like 160 bucks and that ain't bad
https://www.appliancetimers.com/appliance?model=gbd307pdt7
call them,give them your model number or you'll have to replace the oven,this is why they told you to kill the power to it to see if the board would reset,you can try that again,leave the power off for like 5 to 15 minutes and try it but unfortunately they don't make your parts anymore.good luck
Nov 30, 2017 | Whirlpool RBD275PD Electric Double Oven
Blowing circuit breaker
If you live in Rancho Cordova, CA and need appliance repair service call us at 916 823 3070 or visit our website Rancho Cordova Appliance Repair 916 823 3070 Rancho Cordova CA
Sep 02, 2017 | Cadco OV-250 Electric Single Oven
Ovens Logo
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
