Question about Ford 555 backhoe
Wont start turns over no blown fuses - Ford 555 backhoe
I replaced the battery the negative and the positive battery terminals touched and their was a spark now the car wont start
if you have no power at all, like the engine wont turn over you have blown your fuse-able link on the positive cable thats the simple fix .you might have blown a ecu or a fuse in your fuse box allways start with the simple part first (fuses).
Jul 07, 2014 | 2001 Mitsubishi Mirage
1999 Mazda millenia Electrical issues
the first thing to do is to remove the wires your sister conected, tape them seperately, these wires are power and ground wires and power the light in the visor mirror , they can not touch, so make sure they are apart and not touching any metal surface, tape them, one at a time.
there must be a blown fuse, did you check all the fuse boxes? there is one inside and one under the hood. start with this .
May 05, 2013 | 1999 Mazda Millenia
2005 chevy wont start
If the battery has power go into the fuse box under the hood look for the ign fuse check if blown if u replace and it still pops the fuse may kneed starter
Apr 03, 2013 | Chevrolet Cars & Trucks
1992 chevy cavalier rs. dash lights stopped working. car wont turn over. changed a blown fuse under dash . but still wont start
If the fuse blew, it may have been a symptom of a larger problem with your electrical system. I'd suggest testing your spark plugs, distributor and alternator, as well as jumping your battery. If it's not cranking at all, one of those should be the problem. A voltage multimeter is the tool to use; Walmart and AutoZone have them for $10-20.
Aug 31, 2012 | Cars & Trucks
My rover 25 wont turn over, when i turn the key theres nothing but the car will bump start
When you say Bump start, are you talking about push starting your truck?That being the case, I would look at your fuses first, to see if any of them are blown. If you find any blown, just replace them, and try to start it again. Your owners manual should have the location of all your fuses, and what they do. Any that are labeled ignition (ign) would be a culprit if you find it's blown. If you don't find a blown fuse, you may be looking at a solanoid, or starter. Let me know what you find.Dennis
Feb 21, 2012 | Cars & Trucks
Stereo wont turn on
the fuse might of blown take it off and check the fuse
Nov 10, 2009 | Cars & Trucks
No sound from fuel pump
First if there is no sound coming from the fuel pump always look in your fuse panel for a blown fuse. If a fuse is blown for the pump if it is electrical you should hear the pump kick on when you replace the fuse and turn the ignition. If there is no sound and the fuse isnt blown then you have a faulty fuel pump.
Apr 07, 2009 | 1995 GMC Jimmy
Garden Logo
27 people viewed this question
Top Ford Garden Experts
Dennis Key
Dennis Key
donald boissonneault
fordexpert
Are you a Ford Garden Expert? Answer questions, earn points and help others
