Question about HP DeskJet 842c InkJet Printer
Want to determine the amount of ink left in cartridges?
I have been able to view the amount left on other printers, but can't figure out how or if I can on this printer.
  • 71 Answers
On your PC - Go to My Computer-, Click Control Panel, chose Printers -Faxes , click HP deskjet etc, Maintenance and then chose Start Status Monitor.
Posted on Jun 19, 2009
    President:
  • 3,085 Answers
Try the HP Toolbox
Ink cartridges will not move in place error # 1200
Lexmark X4270 Error 1200 Fix - Click here for document link
1. Unplug printer from wall and remove power supply.
2. Unplug any phone lines or USB cords connected.
3. Remove printer attachments, paper trays and phone.
Figure 1 - Printer paper holder and completed print tray
4. Lift the front cover of the printer and remove the white rubber bar by pulling the blue lever on right towards you.
Figure 2 - Top view of printer showing the white rubber feed bar with purple attachment
5. Remove the screws underneath the front cover (6 screws), back of printer (2 screws), and bottom of printer (1). View the images below to find where to remove the screws.
Figure 3 - Top view of printer showing which screws to remove.
5. Cont...
Figure 5 - Bottom view of printer. Image on left is cover to screw. Gently remove ribbon cable to reveal the gold screw beneath
6. Flip the front cover open and gently lift the top of the printer cover. Keep front cover open.
7. Remove the ink cartridges out of their carriage.
Figure 6 - Displays ink cartridge carriage with ink cartridges removed.
Caution: Electrical hazard. Keep hand and metal pieces clear of board or any other electrical wires or parts.
NOTICE: The ink cartridges are all the way to one end. If the X4270 is plugged in, the cartridge carrier is stuck and doesn't move. After further investigation a noticeable small black plastic lever is preventing the ink cartridges from moving. Photo below shows lever up and down (cartridges already moved in image below).
Figure 7 - Shows inside of X4270 and the lever that causes error #1200. Image on left displays lever up. Image on right displays lever down.
8. Push lever down clockwise so it is flush with plastic wall. Refer to image on right in Figure 6.
9. Lift the front cover open (if not already open) and plug in the X4270. Cartridges should move to center as if preparing for replacement.
10. Unplug the X4270 and remove power supply.
11. Remove bottom assembly carefully.
Figure 8 - Displays bottom assembly with lever and spring
Note: The cause of this problem is the spring slides out of place over time, probably because of ink shed on one end of its loop and loop attachment.
Figure 9 - Displays loop attachment
12. Place spring in loop attachment and use hot tip of heated tool to melt top of loop attachment to prevent further errors. Melt top of loop attachment similar of that to a mushroom top.
Figure 10 - Displays fix for jammed carriage.
13. Reattach the lever to the bottom assembly and slide back into place inside the X4270.
14. Plug in and check if operational.
15. Reassemble X4270 using steps 3-7.
Jan 31, 2011 | Lexmark X4270 All-In-One InkJet Printer
It wont print and everytime i try to print it says error #1200
Figure 2 – Top view of printer showing the white rubber feed bar with purple attachment
5. Cont…
Figure 5 - Bottom view of printer. Image on left is cover to screw. Gently remove ribbon cable2_bing.gif to reveal the gold screw beneath
7. Remove the ink cartridges2_bing.gif out of their carriage.
Figure 6 - Displays ink cartridge2_bing.gif carriage with ink cartridges removed.
NOTICE: The ink cartridges are all the way to one end. If the X4270 is plugged in, the cartridge carrier is stuck and doesn’t move. After further investigation a noticeable small black plastic lever is preventing the ink cartridges from moving. Photo below shows lever up and down (cartridges already moved in image below).
9. Lift the front cover open (if not already open) and plug in2_bing.gif the X4270. Cartridges should move to center as if preparing for replacement.
Click Here for the Documents
May 03, 2010 | Lexmark X4270 All-In-One InkJet Printer
I get a 1200 error when trying to fax
5. Remove the screws underneath the front cover (6 screws), back ofprinter (2 screws), and bottom of printer (1). View the images below tofind where to remove the screws.
5. Cont…
NOTICE: The ink cartridges are all the way to one end. If the X4270 isplugged in, the cartridge carrier is stuck and doesn’t move. Afterfurther investigation a noticeable small black plastic lever ispreventing the ink cartridges from moving. Photo below shows lever upand down (cartridges already moved in image below).
Figure 7 - Shows inside of X4270 and the lever that causes error #1200.Image on left displays lever up. Image on right displays lever down.
9. Lift the front cover open (if not already open) and plug in theX4270. Cartridges should move to center as if preparing for replacement.
Note: The cause of this problem is the spring slides out of place overtime, probably because of ink shed on one end of its loop and loopattachment.
12. Place spring in loop attachment and use hot tip of heated toolto melt top of loop attachment to prevent further errors. Melt top ofloop attachment similar of that to a mushroom top.
Feb 16, 2010 | Lexmark X4270 All-In-One InkJet Printer
Cartridge error 1203
Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Posted by LEH at 5:39 AM
Labels: Lexmark x
1 comments:
MarCrazy said...
Lexmark X4270 Error 1200 Fix - Use link below to see how to fix
Text version below use link above to see pdf with images.
5. Cont…
February 27, 2010 10:27 AM
Feb 06, 2010 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Error 1203
or
Labels: Lexmark x
1 comments:
MarCrazy said...
5. Cont…
Feb 02, 2010 | Lexmark X4270 All-In-One InkJet Printer
Changing Ink Cartridge
Easy solution:
Press The index sheet button and the scan button at the same time.
In the printers window 'set up' will appear. using the left right arrows proceed to 'Ink cartridge replacement'.
Press 'start'. The ink cartridge holder will align itself in the middle of the space where it is easy to remove the cartridges.
I am disgusted with Epson making this so diificult to figure out. Once you know..then you know. but no amount of guesswork would have come up with the solution
Please rate!! Thanks, Prem
Jan 28, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Cartridge error No. 1203 - LexmarkX7170 All-In-One
or
Labels: Lexmark x
1 comments:
MarCrazy said...
5. Cont…
13. Reattach the lever to the bottom assembly and slide back into place inside the X7170
15. Reassemble X7170 using steps 3-7.
Jan 21, 2010 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Ink or printers problem
Most likely the ink cartridges for this printer have a chip on them. This chip tells the printer how much ink is left and when it is low or out, you must replace the whole cartridge otherwise if you just refill it, the chip will still report the same amount of ink as it doesn't go by the actual ink level inside the cartridge, it determines the ink level by calculating approximately how much ink has been used while it was printing. So it doesn't matter how full the cartridge is, unless you replace the cartridge or reset the counter on the chip somehow, it will still display the calculated amount not the actual amount.
Jun 10, 2007 | Compaq Armada M700 Notebook
Not printing
The printer determines the amount of ink left in the cartridge by counting the number of ink "shots" when printing, head cleaning etc. This information is stored in the "chip" on the cartridge. Thus, it is not an actual measurement of the ink left, but an estimate calculated by subtracting the total shots from the original full ink quantity. This estimate can sometimes be grossly in error, usually due to a cartridge replacement not being carried out correctly. However, for all four cartridges to be suddenly out of ink is odd. The cheapest way to check this out is to buy a chip resetter on e-bay (currently one for sale at £3.25). Reset all your cartridges to "full", and see if the printer will now recognise them as full. If so, you can buy a new set OK. If the printer still says the cartridges are empty, post a new comment to this effect and we can provide further help.
Nov 17, 2006 | Epson Stylus C86 InkJet Printer
HP DeskJet 842c InkJet Printer Logo
96 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
