Question about Kenwood KDC-255U - CD Receiver
No pre out setting
The subwoofer setting do not show up only stard bass treble and mid
mixmaster
  • 626 Answers
SOURCE: loss of settings
Here ya go;
Posted on Oct 31, 2007
SOURCE: i need to put the subwoofer levels in the radio
go to standby mode. then hold your bass boost button in and the menu should pop up. scroll through until you find th aux setting and use your volume control to set it to on. then the option should be back.
Posted on Oct 02, 2009
SOURCE: LPF and Sub Woofer settings missing from menu
I had the same problem and I just worked it out. Its because your pre-out is not switched to 'subwoofer'. It will be on 'rear' instead. Go into the menu when its in standby and change the SWPRE option to subwoofer and then your subwoofer options will be back in the menu !
Posted on Dec 18, 2009
  • 6 Answers
SOURCE: my subwoofers randomly cut out while driving. in
First and easiest check is wiring, make sure all your connections are tight on all the amp terminals and the speaker terminals. Next, try to see next time the amp cuts out if it feels abnormally hot; it could be cutting in and out on high-temp overload. Also you may look into running a temporary RCA input from your headunit to the amp, a loose connection from your source will cause an issue. Let us know!
Posted on Mar 30, 2010
  • 19 Answers
First of all, how hard are you running them. And what system, wattage, and amp do you have. If you have a 2 or more channel amp, and you are bridging it. STOP, doing so does add power to the subs, but it also can add power that the subs cannot handle, and an amount of heat the amp cannot handle. So your amp could be over heating... good luck
Posted on Jun 07, 2010
How do I adjust the treble and bass on sony str-dh520?
See EQ Mode on page 59 of the owners manual to set the bass and treble for the front speakers, presumably for 2 channel mode. For multi-channel mode there are several pre-programmed audio modes listed starting on page 43 and music mode starting on page 44.
https://docs.sony.com/release/STRDH520.pdf
Mar 02, 2015 | Sony STR-DH520 A/V Receiver
What are the best settings for bass , treble and mid in order to get the best sound
There are no hard and fast rules for setting Bass, Midrange and Treble on your radio. Depending on the type of music you are listening to with your radio, it can / will determine your sound settings. To attempt to set the sound settings on your radio, select the sound settings and set all of them to 0. ( Bass,mid,treble ), then start playing your usual music. With the music playing move the treble setting in single incriments 1,2,3,4 and so. A comfortable setting is usually a 5 out of a total number of 6. Then move over to Midrange and repeat process. A 4-5 out of 6 is usually comfortable. Finally comes the Bass. You do not want to overpower your speakers with too much bass as this will damage them over time. Repeat the usual process and listen carfully for any baffling or distortion as you move through the numbers. A comfortable bass setting is usually 2-4 out of 6. Again I must stress that there is no hard and fast rule for settings. It boils down to the type of music, and what your ears tells you sounds good. What sounds good to me might not be enough for you, or vice versa. I hope this helps! Cheers!
Mar 30, 2011 | Pioneer DEH-4300UB Car CD/ MP3 Player
Thanks for the answer - If we have 3 controls as Bass, Mid and Treble. If we keep those in 12 O Clock position, will the output level be equal. In using the Bass and Treble control only (if we have...
If all are in 12 o'clock position they are "flat" (nothing has been added or subtracted foam input signal) If you only have bass & treble, yes adjusting will affect "mids" but Mids change can go both ways dependent on increase or decrease of Bass and /or treble. By increasing bass you will pull some mids up also. By increasing treble you'll subtract some mids.
Mar 17, 2011 | Audio Players & Recorders
In most of the Amplifiers we have only Bass and Treble control (Bass works on 100 HZ and Treble works on 10KHz - approximately). In some Amplifiers we have Mid range control also. What is the frequency...
The frequency of mid range control is about 1KHz. The bass and treble are usually enough to set the tone of sounds and music, and if the customer has high quality speakers connected to the amplifier it is almost unnecessary to modify any tone. In my opinion you are right that x-band equalizer became less important now.
Thank you.
gylacz
Where are the bass,treble,mids,high on a basic EQ.I have an 12 band stereo eq.what #'s are the bass,etc.
Bass will be anything below 300Hz, mid will be 300Hz to 5KHz (Voice), above 5KHz will be Treble.
Nov 01, 2009 | Audio Players & Recorders
Can't adjust bass and treble
The only adjustments available on the unit are Volume and Bass (Subwoofer Level). There are no Mid-Bass or Treble adjustments.
Sep 20, 2009 | Jasco GE 98903 2.1 Speakers
BASS,TREBBLE,MIDS SETTING
Hello 1rocknroller,
Press the mode button repeatedly to select BASS, TREBLE, SUBW, BALANCE, FADER, DEFEAT, AND VOLUME. When subwoofer mode is set to off, it's level cannot be adjusted. If DEFEAT is set to ON, the player returns to factory defaults. Turn the volume control to adjust the setting. If no adjustment is made within 5 seconds after selecting, the player returns to normal mode.
Hope this helps.
May 29, 2009 | Alpine CDA-9856 CD Player
How do I set up the equalizer for a Honda CRV?
BETWEEN BASS AND TREBLE YOU WILL HAVE WHAT IS KNOWN AS MID RANGE, JUST PLAY WITH IT UNTIL IT IS WHAT YOU LIKE
May 04, 2009 | Car Audio & Video
I need to find out what buttons control the bass and treble
Press in on the volume control repeatedly to step through the menu of audio functions. The
first option is Volume, followed by subwoofer (only if the subwoofer feature is currently
activated), Bass, Treble, Balance, Fader and back to Volume. When adjusting audio functions,
the unit will automatically exit audio control mode after five seconds of inactivity
If you need the user's guide, click her to download.
Feb 21, 2009 | Jensen MP7610 CD Player
Mar 24, 2008 | Kenwood Sirius KDC-MP825 CD Player
Kenwood KDC-255U - CD Receiver Logo
26 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
