Question about Samsung WA422PRHDWR 4.2 Cu. Ft. VRT Top Load Washer
Where is the samsung w422 vrt top loading washing machine circut board
  • 3 Answers
SOURCE: Samsung VRT washing machine
nF means that washer tried to fill but was unsuccessful. Water supply valves needs to be fully open. Lines may be kinked or screen by the hose hookup at the washer end may be restricting flow. Check to ensure the screens are cleaned by removing hose and pull screens and clean them then try the washer again
Posted on Jan 18, 2008
SOURCE: Samsung Front Load VRT
I've had that same code, the machine completely stops and you have to start over with the load, the repair man samsung sent out still cannot fix my problem. he says there is a defect on these machines, good luck!
Posted on Apr 22, 2008
  • 291 Answers
SOURCE: How do I remove Samsung VRT shipping spacers?
Most of these you can just tip back and brace the machine before reaching under the unit toward the back. If this model does not have a semi open base panel, you will have to remove the back backing panel to get to it. Good Luck, Appliance Specialists
Posted on Jan 03, 2010
Testimonial: "I ended up taking the back panel off, it was Very easy (Samsung support said to call a tech.go figure).2 screws & slide the back panel off & vuala!"
  • 1583 Answers
SOURCE: My Samsung vrt washer has
You may have a biofilm buildup in the tub that is too thick to be removed by splashing it with your cleaner. The owner's manual says "Clean the interior of your Washer periodically to remove any dirt, soil, odor, mold, mildew, or bacterial residue that may remain in your Washer as a result of washing clothes. Failure to follow these instructions may result in unsatisfactory conditions, including unpleasant odor and/or permanent stains on your Washer or laundry. Hard water deposits may be removed, if needed. Use a cleaner labeled "Washer safe". "
I take that to mean you'll need a bucket of soapy water, rubber gloves and a sponge or rag to manually scrub the tub and door. Don't neglect the gasket, especially around the edges. Run a rinse cycle to finish the job. If you still have odor, run a rinse with the sanitizer and the SilverCare option; perhaps the silver will take out the remaining bacteria on the outer tub. As a last resort, you may have to disassemble the machine to hand-scrub otherwise inaccessible parts in contact with wash water.
If you use well water or city water with little or no chlorination, you may have bacteria in the water lines to the washer. This may make the water itself stink. To check for this, shut off the external water supply valve to the washer, disconnect the hoses and place them in a large (5-gallon) bucket. Turn on the water supply briefly and sniff. If the water is bad, you'll need to run it at full rate into the bucket to flush the lines, then consider installing an anti-microbial filter in you household plumbing. Also, check the inlet strainers where the hose connects to the machine. If they are clogged or loaded with slime, this will slow the flow rate and make it easier for bacteria to hang on inside the hoses.
Another possibility is a bad reaction between a chemical contaminant in the water and your laundry detergent. You can test for this by stirring a bit of the detergent into the bucket of sample water.
Posted on Apr 04, 2011
trhall71
SOURCE: samsung vrt front load washer will not spin out, ( not working)
I have the same washer and mine wouldn't spin out all the way sometimes leaving the clothes very heavy and wet. My problem was that the drain hose from the washer that you put inside your drain pipe had created a suction preventing it to drain properly. It might be worth checking. I know for forking out so much money on the thing it sure can be finicky.
Posted on Apr 18, 2012
Why is my samsung vrt steam washer leaking from the bottem right model #WF331ANW/XAA
Locating And Repairing A Mystery Leak In A Front-Loading ...
? 3:55
www.youtube.com/watch?v=3D5q1ynWb-U
Jul 28, 2012 - Uploaded by SamuraiRepairman ... source of a leak in a front-loading washing machine and then mercilessly repairs it. ... LG Washer Repair & Diagnostic -Leaking Water from front & bottom ... Samsung Front-LoadWasher Disassembly - Washing Machine ...
Samsung vrt steam washer leaking - Fixya
www.fixya.com/support/t13638559-samsung_vrt_steam_washer_leaking
Jul 15, 2012 - Samsung vrt steam washer leaking - Samsung WF338AAB 4.0 cu. ft. ... I have a vrt ... I hope this helps.... Take of that little door on the front. Have a ...
Oct 29, 2015 | Samsung Washing Machines
Why won't my Samsung Front Load Washer Model # WA45H7000AW turn off automatically?
Samsung Top Load Washer WA45H7000AW/A2 ' Front ...
www.samsung.com > ... > Top Load Washers
Samsung Electronics Rating: 3.9 - ‎254 reviews - ‎$699.00
4.5 cu. ft. Capacity. Washer capacity has a direct impact on how much time you spend doing laundry. ... Top Load Washer with VRT (White) ... Owner's Manual.
Oct 16, 2015 | Samsung Washing Machines
Why is water level low for Samsung VRT Top-Load washing machine
You may have to get someone to change the water level that's at the top of tge washing machine...
Jun 29, 2014 | Samsung WF337AA Front Load Washer
Samsung vrt front loader turns on but shorts out (I think) when I press any other brtton
It seems like grounded or loose wire or heating element or control board grounded
Best way is to do step by step troubleshooting procedure to find problem
Dec 10, 2013 | Samsung 3.5 cu. ft. High Efficiency VRT...
My samsung vrt front loader will not drain or spin and showing nd code
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 28, 2010 | Samsung Washing Machines
Samsung WA422PRHDWR 4.2 Cu. Ft. VRT Top Load Washer Logo
51 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
