Question about Exercise & Fitness
Technogym 900 km miles change - Exercise & Fitness
How to reset change oil soon light
Oil Life Monitor Resetting (KD, KE)
Description
The engine oil life monitor will indicate when to change the engine oil and the engine oil filter - usually between 5 000 km (3,000 miles) and 12 500 km (7,500 miles) since the last oil change. Under severe conditions, the CHANGE OIL message may be displayed before 5 000 km (3,000 miles). The vehicle must not be driven more than 12 500 km (7,500 miles) or 12 months without an oil change.
The engine oil life monitor will not detect dust in the oil. If the vehicle is driven in a dusty area, be sure to change the oil every 5 000 km (3,000 miles) or sooner if the CHANGE ENGINE OIL message is displayed.
Reset the oil life monitor when the oil has been changed.
Resetting Procedure
Press the INFORMATION SKIP button on the DIC control panel in order to display the OIL LIFE LEFT message.
Press and hold the RESET NO button until the display shows 100% ENGINE OIL LIFE.
Jan 29, 2016 | 1999 Cadillac DeVille
How do I change the mileage from kilometers to miles on my 2009 Ford Fusion?
I km = .62 miles.
10000 km = 6200 miles.
Check car manual to see if the display can indicate miles in lieu of KM's
Sep 25, 2015 | 2009 Ford Fusion SEL
At what mileage should the timing belt be changed on a citroen berlingo
What does your owners manual say?
60,000 miles/36 km
75,000 miles/45 km
90,000 miles/54 km
Not more than 90,000 miles or
6 years
If it breaks,the valves get bent
Call a dealer or stop by & ask
May 10, 2014 | 2010 Peugeot Partner HDi
Technogym Runrace displaying belt movement halted message
I've got the same problem mate - technogym say you need to have an engineer to call round but it will be expensive...
Feb 01, 2014 | Technogym Deck, 52"
We have two commercial treadmills of your company with following details: 1- Technogym Run Exc 700 (Serial # D447ELNAL0000UKS) 2- Technogym Run Exc 900 (Serial # D4492LNAL0000USS) Now problem...
Might be the top panel monitor is faulty Also check that the treadmills are set into km not miles can effect the volt of treadmill and cause errors on treadmill Tip go on to techno gym site and look for display reset something like that and give that a try
Oct 08, 2013 | Exercise & Fitness
How do i change the language on technogym top 600 machines
use your owner manual, go to the menu, and proceed according.
or download from www.fitness.manualsonline.com
or www.retrevo.com
God bless you
Jul 27, 2013 | Sears Technogym 600xt Pro Recline...
How to repair technogym 900 trradmill board
if you are talking deck belt board is LUBE first with silicones or wax. see your instruction manual. or download from www.fitness.manualsonline. com 2) if you talking about for repair control board electronic see the diagram attached. I will NOT recommend to repair anything from the board unless you are expertise in advanced electronic. replace by new ones or by some tech.God bless youb630d050-7352-402b-af89-57697605fee9.gif3541b76d-f608-4834-b80a-882c897cb96c.jpg
Apr 02, 2013 | Exercise & Fitness
Alfa romeo 147 flashing dasboard
This is so you can set it, just set or reset the time on the clock and it will stop flashing, same thing with the km,move from km to miles and back, if you want km then set to km but if you want miles then go to miles but you must select through it, good day.
Feb 19, 2012 | Alfa Romeo Cars & Trucks
I want to buy a technogym treadmill and i would like to check how many km were runned on it
Press 369 simultaneously the enter the password 2501 which will get you in the service menu than pres 1 go to operating data and you will see then go to tot km press enter and you will see info needed
Apr 11, 2010 | Exercise & Fitness
2002 Jeep Grand Cherokee Limited pre form service needs to be erased
Service Interval
When this feature is selected a service interval between 2,000 miles (3,200 km) and 6,000 miles (10 000 km) in 500 mile (800 km) increments may be selected. Pressing the STEP button when in this display will select distances between 2,000 miles (3,200 km) and 6,000 miles (10,000 km) in 500 mile (800 km) increments.
Reset Service Distance (Displays Only if Service Interval was Changed)
When this feature is selected the current accumulated service distance can be reset to the newly selected service interval. Pressing the STEP button when in this display will select "Yes" or "No."
Nov 02, 2008 | 2006 Jeep Grand Cherokee
Exercise & Fitness Logo
47 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
