Question about Hitachi CLE-960 Remote Control HL02121
The button to press for tv to come on
I am staying at a friends and can't get the t.v to come on. Is there a certain button I press along with the standby button. I just want to watch it but I must have to press more than one button at a time and I am frustrated now. Please can you help me
How do you program RCA Systemlink 3 RC303-C for Television Model F27255BC
Without codes:
  1. Turn on TV.
  2. Press and hold CODE SEARCH until all device buttons light, release button.
  3. Press TV button. TV button will stay on.
  4. Press POWER repeatedly until TV turns off.
  5. Press ENTER.
With codes:
  1. Turn on TV.
  4. Using number keypad enter code for TV.
  5. Press ENTER.
Nov 17, 2016 | RCA Televison & Video
Red Light Won't Stay On
1. Remove batteries from remote to "zero" it, then reinsert batteries
2. Turn on TV (RCA?)
3. Press and hold CODE SEARCH button until indicator lights
4. Press and release TV button. Indicator will blink and remain on
5. Enter code from list in instructions
6. Point remote at TV and press on-off button. TV should turn off
7. Use remote to turn TV on again and press CH+. If TV responds you're all set; if not, repeat the process with the next code
Nov 19, 2012 | RCA CRK76TE1 UNIVERSAL REMOTE - With...
How do i program my rca remote to my 42 inch samsaung tv
you can try a code search
  1. Turn on the tv you want to program.
  2. Press and hold both the button for the component along with the power button until the light comes on and stays on.
  3. Press the play button every 5 seconds until the device turns off. A bank of ten codes is being sent each time.
  4. Press the rewind/reverse button to see if it turns off/on again. Wait 2 seconds and press again until it turns back on. You may have to do this up to 10 times until it searches through the bank of ten codes sent.
  5. Press and hold the stop button until the light goes off. This saves the code.
Mar 03, 2011 | RCA 3-Device Universal Remote
I need to re tune my samsung tv but have no remote any ideas?
you can always use the button on your Tv itself.
ie menu = Menu
Channel up/down = take you up and down
volume = goes left and right.
follow these steps
Menu,
channel down button to CHANNEL
press the volume button along
channel down button to AUTO STORE
press the volume button to Start the scan.
right now you have your telly tuned in. What you could do it get an old sky remote off a friend/ neighbour. or buy from argos etc ( a lot cheaper then getting a replacement samsung one)
press the following buttons on the sky remote to program it to work with your samsung tv.
TV,
RED + SELECT
TV.
0060
try the volume if this works press SELECT to save this code if it doesnt press Tv then try the volume again. repeat this step until the volume works your telly. once it doest dont forget to press the SELECT button to save.
Now you will be able to change your volume use the number keys. if you also press the HELP button on the sky remote this will also change your AV / SOURCE I hope this post helps you out. When it does please leave a thumbs up for me Please
Cheers Little Dish Fitter
Sep 21, 2009 | Samsung LN-S3251D 32 in. LCD HDTV
I had a controller working with a certain t.v. and want to program it on a new samsung tv i just got, instead of using the old tv
You can try finding the code by doing a power scan as follows to see if one not associated with your tv will work: With the TV on press and hold the TV button on the top left of the remote until all buttons light up across the top. Now preess the small red tv button-the topTV button on the left of the remote should stay lit. Now press the channel up button slowly until the tv shuts off. If it does press the channel down button and then the channel up button. The tv should now turn on. If it has press the pound sign and release. The tv button will flash three times. Now try powering the tv on and off. You should be sucessful. Remember to put the remote back into SATmode. Thanks for using Fix Ya. Let me know if you need further assistance.
Feb 02, 2009 | DISH Network IR Remote Control
Lost remote programing directions
Great News!! We can program most Philips Universal Remotes with Automatic Code Searh. Here's how it works on most of our remotes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
The above assumes that you want to store the VCR you want under the VCR but, Cable codes under the CBL, etc
Note: if the device does not have a chat channel at a button, you should Play (VCR only) or Power instead.
Here is a Code List on PDF that shoud be universal for most remotes. It worked for me.
http://www.remotecodelist.com/remot...ps-Magnavox_PM525S.pdf
Hope this helps you out, good luck.
Nov 27, 2008 | Philips Magnavox Learning Universal Remote
Insignia TV code for RCA Universial Remote Control (RCR450)
If its a four digit code remote. I may be able to help.. Try these...0171, 1204, 1326, 1517, 1963, 2002..
Good luck
Nov 11, 2008 | RCA 4-in-1 Universal Remote Control
Philips universal remote control SRU 1060 code for toshiba tv
Try with this.
Turn on the tv.
Press and hold the CODE SEARCH button until the red indicator stays on,then release the Code search button.
Press and release the desired mode button ( tv,vcr,etc. ) The red indicator blinks,then stays lit.
Enter the 4 digit code from the code tables.0517,0419,0512,0613,0719,0112,0506,0111,0618,0627,0437,0041,0094,0802,0313,0715,with one of this codes your tv can operate.
With your device on,press CHANNEL UP .If the device responds,no further programming is required.
Good luck
Oct 09, 2008 | Televison & Video
HI MY FRIEND sreeki.
Try this site:
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
It's the manual for a Phillips remote control. The codes should be rather universal. Otherwise, there is a way to program it without using a code.
Hope this helps :)
Jun 14, 2008 | Philips Magnavox Learning Universal Remote
Ge 94948 universal remote instrutios for progaming t.v.
Hiya this is how i got mine to work.Manually turn on the tv.
Press and hold setup on your remote till the light comes on and stays on.
Then press the tv button then release. The light will flash then continue to stay on.
Now press and release the power button waiting 2 seconds before you press it again until your tv switches off.. you may have to press it for awhile.
Once your tv cuts off press the mute button and now your remote is set for your tv.
Feb 19, 2008 | GE RM24948 Remote Control
Hitachi CLE-960 Remote Control HL02121 Logo
24 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
