Question about Makita BMR100 Radio
Volume doesn't work on only one channel on Lasonic LTA-260
I have two 260X3 MK11 amps, they stopped working they are 8 years old
Check fuser, power supply filters, and all electrolytic capacitors, look at the top of these caps for swelling check for dry solder on the circuit boards, check output transistors and scorched resistors
Nov 09, 2013 | Sonance Sonamp 260 MKII 2-Channel...
I plug in my lasonic blaster g31 when I put up the volume it turn off what is it
From the description the audio outputs are cutting out due to bad connections, or semiconductor failure. Check to make sure there are no shorts in the speaker wiring, if no change! take it back to the place of purchase for exchange or repair.
Jul 07, 2012 | Lasonic Ghetto Blaster i931 Boombox
Sound comes out of left channel only in my Lasonic L-30K boombox
Check the speaker wire for proper contact, swap speakers around to rule out the speaker, if okay suspect the left audio output chip.
Jun 15, 2012 | Lasonic L-30K Cassette Boombox
I have Onida TV Model 21 inch , I accidentally enable the features of volume lock, hotel mode and channel lock and I cannot reset the same. Due to this, I cannot increase volume of telivision
MIGHT WORK IF YOU:
Turn off tv with remote, that is standby, then turn off tv with switch or unplug from wall. Wait a few minutes until led lights go off on tv. plug tv back in. try pushing vt on remote and power button on tv at same time.
If this doesn't work try contacting a local retailer, they always have a list of codes for their salesmen.
Jan 07, 2012 | Televison & Video
I have an RCA TV converter box, model DTA800B1. I don't have the box or instructions, I am attempting to conneect it to an RCA TV with a built-in DVD player. I would appreciate the code that the TV...
There are a lot of possible RCA TV codes programmed into the DTA800B1 remote.
Try the following three digit codes: RCA 000, 001, 005, 072, 073, 074, 075, 076, 077, 078, 135,
138, 140, 144, 150, 156, 159, 162, 163, 169, 171, 178, 229, 246, 249, 260, 274, 275, 293, 302 in order.
To program the remote. Turn on your TV manually and press PGM (to the left of the zero in the number pad section). The LED should light and stay lit. Type in the first 3 digit code and press OK (in the center of the arrow keys near the top). See if the gray volume up/down keys work to change the volume. If it doesn't work press PGM again and enter the next code.
Note that the converter box remote will only turn on and off, switch the input from Channel 3 or 4 to AV in, adjust the volume and mute the TV. It will not control any of the DVD functions. Your original TV remote will not control the converter box.
The manual for the DTA800B1 is available here: http://www.1800customersupport.com/productdocuments/DTA800B1_RCA.pdf .
I hope this helps.
(who has the DTA800A which is the model without the analog pass-through.)
Sep 17, 2011 | RCA Televison & Video
I am having problems with the volume knob. The
That is a dirty pot switch.. The volume adjusting pot gets dirty.. Two things to try..
1.) With the unit off - spinn the volume min to max many many times at a rapid pace.. This sometimes will displace the debris in the pot..
If that does not work --
2.) Get some "tuner cleaner" in a spray can.. At Radio Shack or a similar store.. Lay the radio on its back so the volume knob is facing up.. Pull the knob off carefully.. Use short controlled bursts of the spray.. A few sprays and spin the knob min to max several times and repeat..
Good luck..
PLease dont forget to rate for your free question..
Aug 20, 2009 | Lasonic TRC-931 Cassette Boombox
Q2770 problem
search on its manual if if has a LOCK feature! if it is lock then it would be fixed on a single channel. Lock feature was designed to prevent children from playing with your TV channels and volume and everything on the remote!
Nov 17, 2007 | Prima CV2011 TV
Lasonic -Digital Media Player
Hi Londie,
I will be happy to assist you. Please contact us at info@lasonic.com
Regards,
Tech Support
Lasonic,Inc
Oct 23, 2007 | Lasonic VP-01SBK Digital Media Player
The player does not recognize the hard disk after converting to NTFS.
check and see if the harddrive settings are set to master. this will solve the problem
Nov 07, 2006 | Lasonic HV-670
Makita BMR100 Radio Logo
Top Makita Audio Players & Recorders Experts
Gil Shultz
Are you a Makita Audio Player and Recorder Expert? Answer questions, earn points and help others
