Question about Adler Royal Office Equipment & Supplies
Change ribbon Royal 310PD - Adler Royal Office Equipment & Supplies
How to get into Royal 310PD calculator to change the ribbon
Good morning Norma.
Some searching about suggests this system has been around for a while. The Royal website has the ribbon at
royalsupplies com Looking a bit further, their collections of manuals doesn't include the 310PD, but the site says that if your product isn't listed, to call their help line at 888-261-4555. This is likely your best bet for finding some assistance from people who know the product.
Hoping that helps, and good luck!
D
Aug 20, 2015 | Royal Office Equipment & Supplies
My vintage Royal manual ribbon cartridge does not advance when typing., stuck in same position.
Usually lubriction, there are small pawls or teeth that move gears and pegs that fit into the ribbon. make sure you have the correct ribbon.
Oct 07, 2014 | Royal Office Equipment & Supplies
I have a royal 2000 typewriter the ribbon keeps getting tangled up.please advise
You may have the ribbon installed wrong. About 95% of typewriters with fabric ribbons wind to the outside but a few wind to the inside. Type with the ribbon off and watch the take up ratchet and installthe ribbon so it winds that way
May 02, 2011 | Royal Office Equipment & Supplies
I have a circa 1940's-50's Royal Desktop Typewriter. The ribbon that was already on it was rather worn and severely faded so I bought new ribbon for it. The only available ribbon was a red-black silk inked...
You have the ribbon on wrong. The ribbon dosen't feed off the spool but take up onto the spool. install the ribbon so that the moving spool is taking up the ribbon.
DickyO
Oct 16, 2010 | Royal MS 25 Typewriter
How to replace ribbon on Royal Apollo 10 elec typewriter???
The cover either pulls up straight or there is a release lever in the front part of the cover that pushes.
Dec 15, 2009 | Royal Office Equipment & Supplies
How to load ribbon and rewind ribbon.
The ribbon should reverse itself if it working properly. Just to the indide of each ribbon is a reversing that the ribbon should go thru, Move that arm away from the empty spool and type a few letters it should reverse. DickyO
May 31, 2009 | Royal Office Equipment & Supplies
Typewriter not working
Look at the ribbon. If only the top half is beig printed on then the ribbon lift is out of adjustment or the ribbon is in wrong
Apr 21, 2009 | Royal Office Equipment & Supplies
Royal ribbon glitch
watch the ribbon spools as you type to see if they are turning.
May 21, 2008 | Royal Office Equipment & Supplies
Royal Portable typewriter ribbon
Hi, I have a Royal Companion Portable from 1940's. I bought new ribbons at mytypewriter.com (select the "Royal Portable" ribbon). It fits. Anyway if it doesn't it's not an expensive mistake, but I researched this and apparently all vintage Royal Portables have the same standard ribbon. Worked out in my case. Good luck!
Apr 09, 2008 | Office Equipment & Supplies
Adler royal satellite 40 ribbon drive problem
Try holding the code key down and pressing the (.) period key. It is probably in the mullti strike ribbon mode.
Oct 18, 2007 | Royal Satellite 40 Typewriter
35 people viewed this question
Top Adler Royal Office Equipment & Supplies Experts
Electroboy
Electroboy
Kevin Michael
Kevin Michael
P Scarbs
Level 1 Expert
Are you an Adler Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
