Question about Hotpoint NVL333EY Electric Dryer
IT RUNS BUT DOES NOT PUT OUT HEAT - Hotpoint NVL333EY Electric Dryer
  • 6,784 Answers
Check the following to combat this issue.
Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Posted on Jun 20, 2009
I have a ep08g11b fredrich and on heat it runs all night and when i try to put it on energy saver it blows cold air.
Doesn't this unit only have electric heat, fan and cooling where the energy saver mode is only controlling the cooling? I think it does not do energy saving mode with heat.
Jan 14, 2018 | Dishwashers
I have a airwell GC-30RCC when put on heat the fan on the indoor unit wont kick in it works fine on cooling and plain fan mode but not on heat mode the red fan light is on too
How do you get it to kick in ?.Fid you spin it by hand ,if that's what you did and fan runs then you have a bad capicator. If fan runs fine in cooling and not in heat then you have a bad board
Jun 01, 2017 | Heating & Cooling
1987 S10 Blazer runs good then won't start
sounds like the starter is being heat soaked . put a heat shield between the starter and the engine block
Mar 13, 2014 | 2004 Pontiac Grand Prix
Runs no heat
Check for 220v will not heat with only 110v
Nov 24, 2013 | Roper REX4634KQ Electric Dryer
Dryer want heat runs but want heat i put ignitor in still want heat what could it be
It is probally the thermal fuse or one of the safety fuses. They are easy to check and replace. Here is a link that should help http://appliancehelponline.com/gdryertroublevideo.html
Sep 14, 2010 | Whirlpool LGR5636L Gas Dryer
My heat pump runs most all the time i will set the thermostat on 70 when it gets to 70 it still runs I can kick it back down to 69 and it kicks off.I can put it on 72 when it gets to 72 it still runs, I...
therostats have what is known as off-set deflection , or simplely put the plus or minus of the temp range which the heat turns on or off this setting is adjustable on many thermostats i usually set for 3 degrees if it is set for 1 or 2 it will run all the time refer to owners manual to see how to set this in program
Jan 06, 2010 | Honeywell Programmable Thermostat Heater
Runs no heat
heat coil is probably your culperate
Jul 23, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Furnace runs on heat, air conditioner does not
If you have a Gas furnace in the Attic then the answer is yes. The outside condenser will not run if in fact you have a gas furnace.
Feb 11, 2009 | Ruud Central System Air Conditioner
Hotpoint NVL333EY Electric Dryer Logo
266 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
