Question about DeLonghi Nespresso EN660 Espresso Machine
En520 frother tube missing - DeLonghi Nespresso EN660 Espresso Machine
Hi, We have a Saeco Royal coffee machine and the milk frother doesn't seem to be working. Need some advice as to what could be the problem?
1- Royal Coffee is not an accurate model. I have to assume that you are having problem with the auto frother that is on the left side of the machine. The auto frother draws milk from the bottle and steams it into the cup.
2- The connection of the frother & the adapter is not right/air tight. The two O-rings on the frother must be pushed in all the way so the O-ring will not be visible.
3- The frother circular chamber for steaming is not clean. There should be no milk deposits visible at all.
4- The silicone tube puling milk from the bottle is connected to the body of the frother with an L-shaped connector. Make sure this connector is air tight fit.
Dec 20, 2016 | Saeco Coffee Makers & Espresso Machines
How to fix steam frother?
drain it turn it upside down and see if you can shake the clip out contact the manufacturers webiste and perhaps tech support can help you
Apr 21, 2015 | Saeco Vienna De Luxe Espresso Machine
Delonghi
For De\'Longhi En520.W Nespresso Lattissima Plus Coffee Maker Team De-Brewerz.com says:
1. Your coffee maker might suffer from water pump, water sensor or PC board failure. Claim the warranty if recently purchased. If you are in India then contact us @ www.De-Brewerz.com
Now you can order all De Brewerz Stuffs online in India @ www.fabkaart.com
Aug 29, 2014 | De'Longhi En520.W Nespresso Lattissima...
Delonghi problems
Try filling both water and the milk container with the correct decalcifying solution - just slit the 500 ml that results from the 1:1 mixture and - without the coffee capsule - press the cappucino button. Instead of cappucino you will get the decalcifying solution running through the entire system including the connector for the milk container (unlike the recommended decalcification method where you use the extra nozzle). Good luck - worked for my machine which only produced steam but no milkfoam...
Aug 02, 2014 | De'Longhi En520.W Nespresso Lattissima...
Delonghi problems
Try pressing all 4 buttons on top of the machine simultaneously after turning on the machine for a few seconds. That resets all volumes to the original factory settings.
The milk frother is not sucking milk from the cup... it appears that the steamer is working as if it is steaming the milk. Any ideas on why the frother tube is not sucking any milk up?
it is clogged with dried milk. Remove the frothing wand from the machine. now press milk froth. you should get a ton of steam blowing out of the hole where the frother used to be. Your frother comes apart for cleaning. pull the chrome tip off, pull the 90 degree fitting and the black milk suction tube off, if it is really dirty you can soak the disassembled frother in hot water with a cleaning tablet. ( the small ones you drop in the brew unit, not the big descaling tab.) also, there is a clear tube with a point on the end of it sticking out of the frothing wand. this is an air admittance oriface. it allows air to enter the hot milk stream and make it frothy and bubbly. if it gets clogged, you will get hot milk but no froth. Your machine came with a spare one in the parts kit.
Jul 04, 2011 | Miele CVA 4062 Stainless Steel
DeLonghi Perfecta ESAM5500 when trying to make a cappucino it wont **** up the milk any ideas thanks
Had this exact problem a few times on a cleaned well maintained milk jug top with an ESAM5500M. Delonghi 'repaired' it by sending a new milk jug frothing top.
It's caused by milk fat deposits, the frother part on the milk jug may look clean but deep inside it's not. I clean mine with pipe cleaners, detergent and hot water and still it wouldn't froth.
The problem re-occurs for me every 6 months or so. You could buy the milk fat remover solution to clean it. Personally I just boil the whole milk jug frother in detergent and the again in descaling solution, that's fixed this problem twice now, although I think it will eventually corrode the 'o' rings on the frother, still cheaper than buying a new frother part each time though.
If it still doesn't work after that, the only other reason for this problem I found mention of was caused by a broken rubber seal where the milk jug fits to the machine. It's most likely to be milk fat deposits inside the frother though.
Jan 25, 2011 | DeLonghi Coffee Makers & Espresso Machines
Our PrimaDonna coffee machine doesnt appear to be takeing in any milk from the jug to make latte's or cappuciono's, is there any way of sorting this out ?
Most common cause of this problem is a blockage in the milk jug. First thing you should try is soaking the complete jug top in a quality milk line cleaner (available from specialist coffee machine retailers) for at least an hour and then rinse thoroughly. Then try running a fresh cleaning solution through the jug instaed of milk. Good luck and post again if this doesnt work.
Nov 25, 2010 | DeLonghi Prima Donna Avante ESAM6700...
Power OK to base, but frother has no power
My frother was working several month without problems. I love that! Someday i try to turn it on - nothing. I opened the frother and found out the the thermal fuse was broken. The specification for that fuse is 108°C/5A 125V~. The fuse you found in the red wire - there is a transparen tube to protect the thermal fuse contacts.I replaced the fuse - it worked !
That means the frother was overheated. The fuse has done the job.
Dec 09, 2008 | Nespresso Aeroccino Automatic Milk Frother
DeLonghi Nespresso EN660 Espresso Machine Logo
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
