Question about Culligan Under Sink Water Filter
Cullingan under sink water drain - Culligan Under Sink Water Filter
Frigidaire gallery dishwasher model#DGHD2433KF1 water droplets remaining on top lower water not draining all the way leaving an odori
Two things to consider....clean water or dirty water?
Clean water usually indicates the fill valve is not shutting off all the way and the fill valve is "weeping" water in all the time = new fill valve time!!
Dirty water usually is not a dishwasher problem but more of a plumbing issue. Often the sink drain that carries the sinks water outside is not fast enough and some of this sink water is backing up into the drain hose and filling up the dishwasher through the drain hose. The drain from the sink to outside needs attention as this type of a problem indicates a slow house drain for that sink.
The dishwasher drain line should be clamped to the top underneath part of the counter before entering the sink drain plumbing, this may help the water from coming back inside the dishwasher.
Jul 20, 2012 | Frigidaire Dishwashers
Draining slowly
try by taking of the trap under sink, and clearing it out ! its the U shaped pipe under sink drain. this is where most of the sinks plug up. unless you have a plugged up drain pipe. do the drain trap first. if this does not solve all of problem, put some good drain cleaner down sink drain. good-day ! and have a merry christmas.
Dec 23, 2011 | Elkay Plumbing
Simpson Aquarius washing machine 7kg: water
SOUNDS LIKE A PLUMBING PROBLEM WITH DRAIN PIPE .YOU COULD FIT NONRETURN VALVE TO DRAIN FROM WASHER BUT THAT WOULD NOT STOP SINK FROM OVER FLOWING
Jan 08, 2010 | Washing Machines
Dishwasher water keeps backing up into kitchen sink then taking a long time to drain from sink
Yes, your sink drain needs cleaning -- it's clogged. Pour some bleach into the sink drains and let it sit for a couple of hours. Flush out with boiling hot water.
If this improves the situation but not completely solving the drain problem, try it again.
If that doesn't solve the problem, remove the P-traps on the sink drains under the sink and clean them out.
If that doesn't work, let me know -- we'll try something else.
May 05, 2009 | Dishwashers
Poor Draining of Vessel Sink
have the plumber pop an opening on the side of the drain pipe under the sink. and add a indoor vent.
Apr 10, 2009 | Advent KRAUS Amber Rectangular Glass...
WATER LEAKS UNDER THE SINK WHEN DISHWASHER IS IN
Check the connection to the drain tailpiece from the dishwasher under the sink and make sure the clamp hasn't slipped off and is tight. Check the drain hose from the dishwasher and be sure it's not split or damaged. Check the drain spur on the drain tailpiece and see if it's corroded or leaking. Check the trap under the sink as well and make sure it's not leaking.
Mar 27, 2009 | Jenn-Air Dishwashers
There is gum stuck somewhere in my dishwasher drain line. The water won't go down. I took the inside apart and can see the hole where the drain water goes. I disconnected the drain hose under the sink. I...
ther e is noo easy fix, short of replacing the drain line( if indeed thats where the clog is)although you checked the hose from the under the sink, did you check with in the hole where the sink conection is made??and try disconnecting the drain hose from the d/w itself and blow toward sink..
Jan 25, 2009 | Dishwashers
Intake drain light flashing
1. Unscrew air gap which is on the counter-top next to sink.
2. Unscrew drain clamp under the sink which s connected to the air gap.
3. Use a wire hanger to push down debris clogging the drain.
4. Screw clamp and air gap back in place.
5. The dishwasher should work. Routinely clean out air gap every half year.
Jul 30, 2008 | Miele Dishwashers
Water running out from under the washer
sounds like two seperate problems. firsst water running from under your machine might be a bad seal, or water could be backing up the drain line. i would guess that it is a plumbing problem because of theissue with water in the sink. have a plumber snake out the drain lines and the problem with the washer should disappear.
Jan 21, 2008 | Speed Queen AWS52NW Top Load Washer
Culligan Under Sink Water Filter Logo
24 people viewed this question
Top Culligan Tools & Hardware - Others Experts
Jim London
Jim London
Bill Boyd
Are you a Culligan Tool and Hardware - Other Expert? Answer questions, earn points and help others
