Question about Air Tools & Compressors
Difference between a Bostitch RN46-1 and RN46 coil roofing nailer
  • 3 Answers
SOURCE: Stanley bostitch coil nailer gun
check the safty shaft and see if something could be under trigger safty causeing it to fire.
Posted on Feb 20, 2009
comax
  • 154 Answers
SOURCE: Leak inside Bostitch N80 Nailer, won't drive nails
If the unit is leaking it most likley need a rebuild kit. Go to a Bostitch service center and ask for an ORK-11 kit. That is all the o-rings needed to do an over haul. Or just have them do it.
Posted on May 28, 2009
  • 7 Answers
SOURCE: constant air leak
Sounds like you need a repair kit or take to a tool company that installs the kit.
Posted on Jun 10, 2009
  • 87 Answers
SOURCE: instruction sheet or manual for Bostitch RN46-1 nailing gun
instructables. com
Posted on Jul 28, 2009
SOURCE: We have a Bostitch nailer that leak out of the end
you need oil....put oil in the mail fitting, just a little and it will go away. your o rings are dry and wont create a seal.
Posted on Mar 09, 2010
Ne to conver roofing nailer back to sequential fire
You need Bostitch part 105782 Sequential trigger assy.
One roll pin holds it in place, its an easy change
Jun 04, 2014 | Stanley Bostitch Rn461 Gun Coil Roofing...
New nailer double firing and jaming
Some trigger valves (tva6) are sensitive (defective?) however there are some things you can try to change how the gun acts. I have noticed that the brand of oil has an effect on the orings. Some brands will swell the orings, I like Paslode nail gun oil. Do not wash the gun with gasoline or wd40. Use diesel. Change the nail depth setting one position. Lowering the air pressure will make a difference. I find that most operators use too much pressure. A stronger safety spring under the trigger will separate the trigger and firing pin quicker. Finally you could use single fire trigger. Good luck
Jan 16, 2014 | Stanley Bostitch Rn461 Gun Coil Roofing...
Trigger is leaking air and trigger is not working on a bostitch coil nail gun
replace trigger valve assembly aka tva 6 you can get aftermarket ones fairly cheap that are just as good. it is fairly easy to do, usually takes about 10-15 min, lots of how to on you tube look under bostitch rn46 trigger
Oct 31, 2013 | Stanley Bostitch Rn461 Gun Coil Roofing...
How do i control the depth the nail shoots in a bostitch coil nailer
The bostitch nailer pictured along along with your question is a RN46 roofing coil nailer. It has a dial on the front of the nose for adjusting depth. Some older nailers (roofing nailers) do no have a means of adjusting so were set at the factory for best performance. The question of depth usually comes up when lower bumper fails and the nail is driven too deep. Easy test. Remove nails and find a very soft piece of wood. Dry fire the gun against soft wood and measure how deep the driver is entering the wood. Harder test. Remove the head and use any handy tool to push driver down to bottom. Measure how far the driver extends past nose (should be about 1/8 to 3/16). If more, replace the lower bumper. Good luck
Jun 21, 2012 | Stanley Bostitch Nail Gun
N12 Bostitch comp nailer, need a few inner parts. Where can they be located? An inside rubber piece fell apart.
I have seen these parts available on ebay. They are using parts from old Unicatch roofing nailer and Max cn55 coil nailer. I have an old craftsman lathe and cut parts from other nailers to fit. This is hit and miss and does not work as well as max parts. You can be creative or just buy parts from ebay. Good luck
Jan 12, 2011 | Stanley Bostitch N12 Coil Nailer...
How do you set the depth on a Bostitch N57c coil nailer besides lowering the air pressure
Hello. The only way to set the depth is to lower or raise the air pressure. The rn175, however does have a depth setting feature which you may find useful for your app. http://www.protoolreviews.com/reviews/air-tools/bosch-roofing-nailer-rn175
Jul 01, 2010 | Stanley Bostitch Coil Framing Nailer
My bostitch rn46 seems to double or triple shoot nails frequently. Am I not using the tool properly or could there be a mechanical problem with the tool?
if u are right nails for gun,then make sure when u put coil in and feed in front of firing pin the nails are straight with pin and connecting wires are not bent causing nails to fall out of alingnment.
Oct 02, 2009 | Stanley Factory Reconditioned Bostitch...
Have ism coil nail gun what nails do i use where can i get info about the nailer
Somewhere there should be a model #, I have never seen a ISM.
Most all bostitch roofing coil nails will fit there guns.
Below I posted there website where you can check the info on your gun.
http://www.bostitch.com/default.asp?TYPE=CATEGORY&CATEGORY=BOS_ROOFING_NAILER_STAPLER
Apr 07, 2009 | Stanley Bostitch Coil Framing Nailer
Air Tools & Compressors Logo
63 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
