WHEN THE ON/OFF BUTTON IS PRESS FOR SWITCH-ON, A 'KIRK-KIRK' SOUND IS HEARD BUT THE TELLY DOES NOT SWITCH ON. WHAT COULD HAVE GONE WRONG?
    Brigadier General:
  • 3,917 Answers
If you have no indication of power(no lights,no clicks) the main fuse is a good place to start but if he is blown and is black in color you will have a shorted component ahead in the circuit and if you replace the fuse it will blow up as soon as you plug the set in,in all honesty since you are not too familiar with tv service you should be safe and seek the assistance of a servicer.
If you do not know enough about the high voltages in televisions - 25000 Volts is typical from the horizontal- line timebase then you should not even take the back panel off. Often the line timebase fails due to a power transistor going short circuit, this will probably blow a fuse on the internal printed circiut board. All the other supply voltages are derived from this one timebase. Some televisions also have a small mains transformer.
I have heard that it could simply be a faulty mains switch, which you could check with a meter on Ohms range. (TV not plugged into mains!).
Coils right steer clear of the Anode or Big wire w/rubber boot going to the CRT.(27.5KV) You may need a Horizontal output transistor if its a dead set. (Or flyback and or both).. If you are going to attempt repairing or tracking down get detailed instructions on discharging the CRT before poking around. These can retain voltage for years without being plugged in. (They will SNAP you good)!
Thanks for contacting fixya.
Posted on Jun 19, 2009
I have just brought ps3 and when i plug the leads into the tv ie red white and yellow leads i can not find the channel on my tv i have tried other tvs and same thing so i done away with the lead and just...
Hi, try not using the hdmi lead and plug the other lead back into the ps3 the normal av lead with the 3 color wires, now plug it into your telly now switch the ps3 on at the back so the red light is on at the front, now hold down the one button and it will bleep once then bleep twice and keep holding it down till it switches back off
so basically you switch it on at the back then press and hold down the on button until the ps3 turns itself back off, now what this does is reset the video mode so its not set to hdmi settings, now press the on button again and wait for it to come on if you still dont have picture on the telly make sure the video lead is fitted correctly and then get the telly remote and find one of the following buttons
av
source
input
or a rectangle with an arrow facing to the right.
once you have found this button make sure the ps3 is on and then press this button on the tv remote, you may need to press it more than once depending on how many inputs the telly has on it.
now when you press the button on the tv remote press it once then wait 5 sec before pressing it again just to give it chance to pick the signal up.
hopefully now you have the ps3 working through the normal av lead
let me know how you get on or if you need further assistance ok
please rate this solution as i have a whole page of unrated posts, thanks
Nov 28, 2010 | Sony Playstation 3 (PS3) Console
KDF60XF955 LCD Projection TV
No you didn't but sometimes when lamp goes out there is a fuse also goes with it. If the new worked for a short time or never worked then I woul look for an open fuse. I would need schematic to find. Are you can keep asking here until someone give more helpful info.
Jan 04, 2008 | Televison & Video
My plastation 3 works when i hook it up through the hdmi cable but not the regular cables that come with the consol. is there a setting i need to change?the cables are not broken nor are the hookups on my...
Ok, you need to reset the PS3 back to standard video settings by doing the following :
Step 1. Turn the PS3 off into standby mode (red light on)
Step 2. Press and hold the power button. It will beep when you first press it, then beep again 5 seconds later. Release the power button when you hear this second beep.
Step 3. Wait for the display to initialize.
Hope this helps
Nov 25, 2010 | Sony Playstation 3 (PS3) Console
I turn on tv. There is sound but no video.
hi, if you have a device plugged into the telly that gives you the picture such as sky or cable then the best thing to do is disconnect this device from the back of your telly then switch the telly and this device off at the mains, then re-fit all the cables making sure they are connected properly then switch it all on.
now check if you have sound also make sure the tells is on the correct input for that decice and also make sure the mute button has not been pressed on the telly remote or on the remote of the device you use to watch telly, if after doing all that it still dont work then the chances are something has blown on the amp in the telly.
make sure you double check all the leads going into the telly to rule out a faulty lead causing you the problems
Jul 13, 2010 | Televison & Video
On which channel on tv set can i see the wii image the remote control switches the console on & off but we can't do anythying further despite of our connecting it correctly
hi, once you have plugged the wii into a socket on the back of the telly you then switch the wii on and then get your telly remote then depending on how you have it plugged in would depend on what button to press, if its the rectangle scart lead fitting type then you need to press one of these buttons.
av
source
input
or a picture of a rectangle with an arrow facing to the right
so find these buttons on your remote and press it now depending on how many inputs the telly has would depend on how many times you press the button you may need to press it up to 5 times so bare this in mind, if it is scart lead then if you look on the back of the telly where you plug the lead in it should tell you if its av1 or av2 or av3 if it tells you this then thats how many times you need to press the button.
if your using the 3 color leads then these will be under one of these buttons.
source
input
or the rectangle with the arrow
or video button
or button that says ext
once you have found these buttons give it a press until you see the picture.
then to get back to your tv you keep pressing the button till you get the tv picture or press a button that says tv.
let me know if you have any problems ok
Jul 10, 2010 | Nintendo Wii Console
Have ps3 that was working fine, unhooked it from one tv to another and proceeded with holding the power button 5 seconds til it beeped twice and still have blank screen
hi, if the ps3 was working fine on the other tv and you have not dropped it or anything like that then this would point towards their being a fault with the lead of the connection in the back of the telly.
what you should do is unplug it all again and refit all the leads in the back of the ps3 making sure they are pushed in far enough then plug the lead into the back of the telly making sure you push it in far enough, then switch the telly on and then switch the ps3 on if the telly dont change to the correct channel as soon as the ps3 comes on then you need to get the telly control and put the tv on the correct channel.
now depending on how many inputs the telly has would depend on how many times you press the button on the control, the button you need to press is going to be on of the following its either av, input,source,ext,aux, or a picture of a rectangle with an arrow running from left to right, now once you have found this button make sure your ps3 is on with a game in then press the button on the tv remote then wait couple of seconds it may say something like av1 on the telly if this dont show the ps3 then press it again it should then go to av2 and keep going until you see the game on the ps3 you need to keep going until your telly is on the right input channel.
once you have done this your ps3 should be working again.
May 25, 2010 | Sony Playstation 3 (PS3) Console
Hdmi channel not showing PS3 only sound
might be problem with PS3 rather than telly. Try another HDMI cable in case something wrong with yours. You can try and reset PS3 video output by holding power button down (when in standby mode) until it beeps, them use original cable and see if that shows up on your TV. If so reconnect HDMI cable Ps3 will detect it and change settings back to HDMI then see if the TV picks it up.
Dec 11, 2008 | Televison & Video
BLANK TV
hi, what you need to do is find the source button or av button on your remote control as it sounds like its changed source this causing your problem. As you probably know your telly has many inputs for dvd vcr cable or sky but these plug into one of the inputs in the back of telly. Usually the problem is just that your on the wrong input channel like av1 instead of av2 or rgb their are many inputs so you might need to press this button 2 or 3 times till you get the right channel, i dont mean 1 to 9 channels i mean input channel like rf input or av input. This depends on what your getting the signal from if its cable and its plugged in via scart lead then it will be an av input but you might have av1 av2 av3 av4 this depends on your telly.
If your still having problems then give me a shout back ok best to check all the leads are in the telly correct as this will cause the problem your having ok.
Let me know how you get on ok or if you need further help
May 14, 2008 | Philips 32PFL5322D Television
Getting sound when in telly mode
You have to use the switch on the pro - logic simulation. Your remote button might say sound or PII(with an icon). Usually if you continue to press the buttion you will cycle this different presets, ie. Music, Movie, Cinema, etc. These are optimized for the type of media your using, but try them all and see what works.
Jan 04, 2008 | Sony DAVHDX265 System
Volume turned off
try manually turning the vollume up on the telly itself if this dont solve the problem try pressing the av button on the controll in case that has changed as sometimes this will stop the sound make sure the controll is working but other than that their should be no reason why you get no sound unless its something inside the telly that has gone wrong if this doesnt solve your problem take it to repair shop and they should tell you for free what is wrong with it hope this is some help
Oct 24, 2007 | Polaroid FLM-3232 Television
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
