Question about Dell 942 All-In-One InkJet Printer
Dell all in one 942
Looking for a parts list diagram. Had to take this printer apart and I found a loose part laying in the bottom of the printer. Dont know where it goes. About 1 inch long and has a profile similar to the symbol { with a tab on one edge. The material is made from is a soft rubbery semi-clear. Very flexible.
Can you help?
  • dgravlin Mar 22, 2008
    SAME PROBLEM, ON CLOSER INSPECTION, ALL ROLLERS AND GEARS SEEM TO BE IN PLACE AND ALIGNED, WHAT I HAVE NOTICED THOUGH, THERE LOOKS LIKE THERE MAY BE A HALL EFFECTS TYPE SWITCH ON THE CIRCUIT BOARD THAT IS TRIGGERED AFTER THE FIRST FEED ROLLER MOVES THE PAPER TO THE STARTING POSITION AND IN TURN REVERSES THE MOTOR TO ALLOW THE NEXT FEED ROLLERS TO THEN FEED THE PAPER AS IT PRINTS. HOWEVER THE HALL EFFECTS SWITCH, IF INDEED THAT IS WHAT IT IS, SEEMS TO BE TRIGGERED BY A THIN PIECE OF PLASTIC RUNNING BETWEEN THE TWO TABS ON THE CIRCUIT BOARD, PLASTIC WILL NOT INTERRUPT A MAGNETIC FIELD, IS THERE A METAL, OR SOME OTHER MATERIAL, PIECE MISSING FROM THE ACTUATOR ARM THAT WOULD TRIGGER THE ELECTRONIC HALL EFFECTS FIELD?????
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 57 Answers
Printer
Posted on Nov 12, 2017
SOURCE: Dell 942 All-In-One InkJet Printer
Yea i havent been able to print out my homework for like 2 weeks. i say dell printers suck. they should recall them. My printer just likes to turn on and off, thats it!
Posted on Jan 03, 2008
SOURCE: need help with printer dell 942 paper jam
Paper jams can be real or false. The all-in-one may report a paper jam when there is not any jammed paper, however, the solution to a real paper jam or a false paper jam is the same. Up-grading the printer firmware could also fix this kind of issue, however I would appreciate if you try the steps below before you up-grade the printer firmware.
To fix the paper Jam errors please try the following steps:
1. Confirm that no foreign materials are inside the machine.
2. Confirm that usable paper is set.
3. Confirm that the paper is set properly.
4. Confirm that recommended paper is used, and the number of sheets set does not exceed the required limit.
5. Disconnect the printer power cord as well as the printer cable form the printer.
6. Turn the printer upside down and shake the printer in order to remove any obstacle which is stuck inside the printer causing the paper jam error.
Open the printer cover and remove the cartridges and check carefully if there is any small piece of paper which is stuck inside, if so remove it carefully.
7. Disconnect the printer power cord and press and hold the power button on the printer for about 15 to 20 seconds( this will release the flee power) and reconnect the printer and check.
If the above mentioned steps do not fix the issue please up-grade the printer firmware form the Support.dell.com web site. However make sure that you do not turn off either your printer or computer when you are downloading and installing the printer firmware.
Should you require any further assistance regarding the printer or even for any other computer related issue please feel free to contact me I will be more than glad to assist you.
Regards
Malik Khan
Posted on Jan 31, 2008
  • 36 Answers
SOURCE: Dell AIO 942 Wont' Scan
try uninstalling & reinstalling the drivers....tht wld fix the issue...
Posted on Jul 22, 2008
proton77
  • 1183 Answers
SOURCE: free driver for Dell all-in-one 942 on Mac using XO
Hate to tell you this , but the Dell 924 printer driver is not made to support the MAC operating system
The printer would only work on windows platform that too on
windows 2000, xp and VIsta
http://tinyurl.com/38he2o
Thanks
Proton
Posted on Aug 06, 2008
SOURCE: Dell 926 Printer ink refill instructions
gently push a wooden cocktail stick in each hole and it will tell you. Presume the 926 cartridge are all the same and on mine the bottom left hole is yellow, bottom right is cyan and top is magenta
Posted on Oct 28, 2008
Where do i find my dell all in one center
Hi idavi1515, to "Update the Driver / Software."
Go to this "Website Link," below, for Dell 942 All-In-One.
Fill-in all information required.
Ie: Brand Name, Model #, and Operating System...
"OS" are: XP, Vista, and Windows 7
Select the [Drivers] you need from the "List."
"Download the Drivers."
!"Take a moment to rate the help."
Thanks paul7of9
Cick here: http://search.dell.com/results.aspx?s=gen&c=us&l=en&cs=&k=+Dell+942+All-In-One&cat=sup&x=6&y=8
Mar 21, 2011 | Dell 942 All-In-One InkJet Printer
PARTS LOOSE INSIDE HOW DO TAKE IT APART WITH OUT BREAKING?
You don't. Dell printers are made to be disposable. Nicer machines can be worked on limitedly but really all consumer grade ink printers are disposable. Sad I know. I would reccomend staying away from Dell, Lexmark, IBM and Kodak as they are all made by Lexmark. Generally not the highest quality machines with expensive ink. New Canon machines that take the CLI-221 cartridges are very nice along with most new HPs.
Oct 29, 2010 | Dell 942 All-In-One InkJet Printer
I am trying to download the Owners Manual for Dell Printer 942
You may want to try these:
Dell 942 in pdf
Dell 942 in HTML
HTML needs to be downloaded and saved on your computer. Once you have it extracted, it will appear like a Help program.
Note: disable your Pop-up blocker temporarily if you can't open the link.
Nov 02, 2009 | Dell 942 All-In-One InkJet Printer
I cant let my Dell all in one 942 go wast just because i am now
I guess you are out of luck though...google coughed up this.
"I found a reference that seems to indicate that the 942 is a rebranded Lexmark p6250. If that's true, give this drivera shot. You may have to manually add the printer and choose the driver from the list."
http://downloads.lexmark.com/cgi-perl/downloads.cgi?category=Drivers&ccs=229:1:0:462:0:0&searchLang=en&os_group=Mac%20OS%20X
Aug 03, 2009 | Dell 942 All-In-One InkJet Printer
I have a MAC and want to use a DELL AIO 942 printer
It is very tricky but I think that i may have a inkling here... Dell does not make any printers n the ones they sell are just rebranded Lexmark printers... I referenced my database & found that the Dell 942 is a rebranded Lexmark p6250... now from the following link select your Mac OS version n download the driver file
http://downloads.lexmark.com/perl/downloads/downloads.cgi?ccs=229:1:0:462:0:0
Lemme tell you this is a practical assumption but I have a feeling that this might work so would you be kind enough to lemme know if this worked for you...
My fingers are crossed :-)
Feb 12, 2009 | Dell 942 All-In-One InkJet Printer
I am trying to install my Dell 942 printer to my new dell sx and cannot find the disc. The printer is not listed in a manuel format and am trying to find compatible software
The Dell website under the support area will have the software/drivers you need available for download. Hope this helps & please remember to rate my answer. Thanks.
Jan 10, 2009 | Dell 942 All-In-One InkJet Printer
Dell 942 printer
Here is the link for the drivers & application for AIO 942 printer:
http://support.dell.com/support/downloads/driverslist.aspx?os=WLH&osl=EN&catid=-1&impid=-1&servicetag=&SystemID=PRN_ALL_A942&hidos=WW1&hidlang=en&TabIndex=
All you need to do is go to above link & download & run the upgrade/patch first. It will uninstall the drivers for the printer & thn download & install the drivers.....once the drivers are installd, you will get the aio center.....do let me knw if ny further help is required...
Jul 21, 2008 | Dell 942 All-In-One InkJet Printer
Dell 942 All-In-One InkJet Printer Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
