Question about Grilling
Jenn-Air conversion kit natural gas to LP model 720-0100
What size dose the ore fuss need to be?
3 Suggested Answers
SOURCE: jenn air propane grill conversion
It is inconceivable to me that large manufacturers like Jenn-Air and Nexgrill can jointly make and sell an expensive grill and then completely abandon the consumer. I purchased an Jenn-Air 740-0142 LPG and like so many wanted to convert to nautural gas which requires a larger gas orifice. I spent a month on the internet and phone calling Jenn-Air and finally Nexgrill who actually manufactured the unit in China. The Jenn-Air and Nexgrill serial numbers are the same. the 740 prefix is LPG and the 750 prefix is natural gas. After three calls to Nexgrill I found a manager who actually acknowledged making Jenn-Air but declined selling me parts for it as I believe they have product liability concerns. I call back as a Nexgrill owner and finally ordered natural gas orifices at $10.00 each. The shipment never showed up. Calling back again I was told that they really didnt really have any orifices in stock but could sell me the entire replacement gas valve for $28.00 which I purchased. The valves actually arrived on the shipping receipt was from The Grill Services in City of Industry 909-718-6128 www.grillservices.com . Part number 750-0141/142/593/594.
Forget about pirates in Somalia... we have them right here. Shame on you Jenn-Air and Nextgrill.
Posted on May 31, 2009
  • 4736 Answers
SOURCE: Is there a conversion kit
Matt, I am not aware of one. Nor, whether it's approved or not, by the manufacturer, Nexgril.
My best advice is to contact their Customer Support Dept @ 800-913-8999
Keep in mind, it you are able to convert it, the gill will no longer get as hot as it does with propane.
Propane burns hotter than Natural Gas in an outdoor environment.
I hope this helps you and Happy Grilling!! Thanks for choosing FixYa.
Posted on Jul 28, 2011
Need help on converting my jenn air from natural gas to Lp! the location of the new orifice's and what size goes where??? I bought a conversion kit from AppliancePartsPros! Stove Is a Jenn air jdr8895aas
give the kit to the gas fitter that you will get in for the job
gas conversions are not a DIY job as it is not just the jets but the positioning of the air shrouds for correct burn
Jul 19, 2017 | Jenn Air Kitchen Ranges
My Dewalt D51825 leaks air from the piston rod. Bumper seems to be okay Can any one help?
Air leaking from nose of gun indicates air getting past bulkhead orings. Bulkhead is white plastic frame inside of gun. Replace gold colored vinyl orings with like size buna orings. Remove cylinder from bulkhead to find two bad orings. Also replace trigger valve or vinyl orings within valve including the two orings on the firing pin. Good luck.
Feb 01, 2017 | Dewalt Air Tools & Compressors
I need a tool for turning inner orings on my micro-lathe. The oring size is a buna 012 to give an idea of the size. The lathe I am using is made by Taig and has a tool holder.
You may use a high speed boring tool that is resharpened for the width of the o-ring. And back relieve up the boring bar so as not to hit your part bore 3_15_2014_8_58_02_pm.png
Mar 12, 2014 | Tools & Hardware - Others
Air leaking behind trigger
I have noticed that Dewalt uses some vinyl orings in the trigger and the interior of the nailer that fail with time no mater if the gun is used or not. Vinyl orings will soften over time and will need to be replaced. I use buna or viton orings available from many suppliers including (oringsandmore.com). You will need to carefully measure for correct size. I use 2mmx 1.5mm orings on the trigger stem. Good luck
Dec 20, 2012 | Dewalt D51321 3/4" 1 3/4" Heavy Duty Coil...
I am trying to convert a Jenn-air model # PRD3630NP from LP to NG I assume this model is convertable becouse it has a convertable reg on it. Do thay make a kit to do this or is it just a matter of ins
Jenn Air use to make a kit that had the proper orifices for the burners and the valves. The regulator is adjustable for the conversion by simply reversing the main screw. It was intended to be convertible. However, since the model is discontinued, you can no longer purchase the kit (or the backsplash). Apparently Jenn Air believe that when they stop making a product, no one will ever need a part for it again (cough, cough).
Good luck trying to track down a kit. I've tried everywhere in the country and a few shops in Canada. I have a gas appliance expert who thinks he can accomplish the conversion by getting a few of the parts from the LP model and then modifying the rest. The orifices are basically the same, only the LP diameters are different. Theoretically, the ports could be filled and redrilled, but the hardware store was fresh out of 1.07mm bits, so I'll pass on trying this on my own.
If anyone has a LP model they want to convert to natural gas, I'll gladly swap parts.
Jul 25, 2012 | Jenn-Air Kitchen Ranges
Thermal Cut-Off Fusible Link P-75173Pentair MiniMax 100
you are fixing the symptom check gas pressure and gas line size heater is running too lean and hot if gas ok check burn tubes for obstructions
Jun 04, 2012 | Pentair MiniMax 100 Aboveground 100,000...
Is there a conversion kit for Jenn-Air Model No: 720-0061-LP to convert from LP to Natural Gas?
Jul 28, 2011 | Grilling
Installing a new fuel pump lock ring will not seat unless I remove the oring then it seats easily, also the tab on the module does not line up with the slot on the tank did we get the wrong pump... 1999...
Sounds like you may have got a pump for the same vehicle but different engine size. However on the oring you need to lube it sometimes to get it to seat. At times I have used the old oring instead of the new just because it wont seat. Check your engine size and the application for the pump you bought see if its the same. Sometime they come with an universal adapter you have to manually splice into the harness.
Oct 10, 2010 | 1999 Chevrolet Silverado 1500
Air is coming out by the trigger and causing it not to drive nails. The air only comes out when the trigger is compressed. How do I fix this?
Remove the trigger by removing the roll pin and check that there is an oring installed on the trigger plunger. The plunger is a white plastic part and requires a small oring about 1/4 " in size. You can buy orings at Lowes Lumber in the plumbing department, about one dollar for package of ten. That should take care of leak when trigger is depressed. Good luck and post again if you need more help.
Jun 16, 2010 | Hitachi NV45AB2 Roofing Coil Nailer
Grilling Logo
55 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
