Question about Oklahoma Sound Wireless Mic for Pro Audio PRA-7000
Once i disconnect the ac the wireless mics do not work.The power lite is on and fr lite on, no sound.
MY VIDOE CAMCORDER WILL NOT RECORD SOUND WHEN I ATTACH A MIC
You need to connect your mic to an amplifier first and then to camera. Orherwise mic has not enouth power output. Zoom h4n might work but its expansive. Or u can buy wm-v1, wireless mic, it'll work just fine. Or buy mic with power already built in, like Rode VideoMic.
Apr 12, 2012 | Canon VIXIA HF R20 Camcorder
Have an Aiptek HD 12 1080p with Azden wireless mic system. no sound with wireless mic, but sound works on camcorder without the wireless.
you need to use a mono-to-stereo cable, the azden is a mono output mic by the aiptek is a stereo input and you are shorting out the phantom power with a mono plug in a stereo jack.
- DL
Sep 06, 2011 | Aiptek Cameras
Computer not recognizing USB camera. Only the orange lite comes on. Not the blue one
Camera devices light is indication of functionality. The device least displaying media result with computers is indication of program incompartibility or maladjsutment. Once the camera has been connected to the computer or as builtin with recent devices, navigate throught the programs on the computer to ascertain the computer camera media displayers.
Feb 14, 2011 | Minox 60653 Digital Spy Camera/mic...
My front panel headphone& mic connecting pcb have only 7 slots and the cable is named as 1)LINE OUT FR,2)LINE OUT RR,3)LINE OUT FL,4)LINE OUT RL,5)MIC IN(R),6)GROUND,7)MIC POWER(L) how can it connect...
FR stands for Front Right, FL for Front Left, RR for Rear Right and RL for rear left. These are speakers connections. You need a convertr cable to connect your headphones with your PC. After getting cable, connect it with FR and FL or RR and RL pair. Your headphone will be working. Similarly get the cabl for Mono to Stereo Mic and you can connect your mic too. (ehteshamhusain@gmail.com)
Jul 14, 2009 | Computers & Internet
Leadsinger sub mic, modle LS 3222. Green lite flashing but no sound. any help?
We had this problem too. Can you perform any functions with the duet mic? We couldn't, just had the light flashing. Turns out the light is supposed to flash (never is solid). Check the connections to the sub mic pack in the back of the main mic. Ours was loose. Once that was plugged in properly, we turned everything off and started again. All was fine.
Good luck.
Nov 29, 2008 | LeadSinger Wireless HiFi Remote Duet Mic...
Buzzing/humming sound when mic is inserted while on AC power
if its not usb mic you will have the humming
if it is a usb mic the port that you connected to needs a mic to be further away from comp your picking up a static charge from comp to mic
May 26, 2008 | IBM ThinkPad T30 2366 Notebook
My Nintendo microphone
My Nintendo ds lite also would not respond to voices. I have brain age 2 and Zelda. In the Zelda options there is a mic test. This will show a graph bar that measures your voice. Well the mic was not working at all for either game. I simply took out the battery and held the power slide for a couple seconds. Amazingly the mic works now for both games. I do not know if moving the power slide is significant, but on computers to de-static them you remove all power sources(battery and ac adapter) and hold the power button for 10 seconds.
Oct 30, 2007 | Nintendo DS Console
Nintendo ds lite microphone doesnt work
I fixed the MIC on my DS LITE very easily, after first replacing the MIC with a new one and finding that it still did not work (not an easy thing to replace either)! The internal MIC signal is routed to a contact at the front edge of the DS, which allows the internal MIC to be disconnected when an external MIC is connected. If this contact (which is normally held closed by the springy nature of the contact) gets dirty, then it effectively goes open circuit, disconnecting the internal MIC signal. You can use a cotton bud and a little WD-40 (contact cleaner) to clean the contact (clean the two pins next to the 3.5mm jack connector) to restore the electrical contact. Takes 5 minutes and is a LOT easier and cheaper than replacing the MIC or paying someone to repair it!
Oct 30, 2007 | Nintendo DS Lite Console
Oklahoma Sound Wireless Mic for Pro Audio PRA-7000 Logo
69 people viewed this question
Top Oklahoma Sound Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Oklahoma Sound Audio Player and Recorder Expert? Answer questions, earn points and help others
