Question about Marshall MXL-V69-MEDT Microphone
V69 mic has a buz or hum. could this be caused by an old vac tube? What tube is best for V69 used for vocal recording?
  • jerry679 Jun 19, 2009
    I'LL TRY CHANGING THE TUBE AND GET THE TUBE # YOU SAID. I'LL GET SEVERAL TUBES TO FIND WHAT I LIKE BEST
    THANKS
    JERRY MORGAN
    President:
  • 2,923 Answers
Replacing the vac tube is a good idea.
Try the tube nos. 5751 and 6072. but the 6072 definitely brought the most noticeable difference. In some cases the 12AX7 (which is the original). More aggressive and could sometimes suit the source better. But if you don't like it, you may try the 6072.
Hope it helps and have a great day!
Posted on Jun 19, 2009
Humming sound when I record
Sounds like it might be feedback from another source or perhaps a loose connection. Try moving the microphone away from power sources or anything that might cause feedback, such as speakers etc.
Apr 24, 2012 | Samson Meteor Mic - USB Microphone
Help...my mxl v69 vac tube mic records well until the end of a song that has a sustained ending. Like it will record an open chord strum, but as the sound of the acoustic guitar starts fading away the mic...
I would see if the Phantom Power is OK.
Check with a voltmeter between pins 2 & 3 on the feed cable.
Should be around 40 Volts.
If not, check it on another mixer.
Now you know.
Peace-
Nov 27, 2011 | Marshall MXL-V69-MEDT Microphone
I want to record vocal voice trhought mic on psr 9000
You could record short "samples" to be used in building new voices, however, it does NOT appear that you can record a vocal song with the PSR9000. The Tyros II and III have the capability to record vocals but the PSR9000 and Tyros I do not..
When playing back an arrangement, you can re-sing the song and have the vocal harmonizer track the arrangement.
Jul 29, 2010 | Yamaha Music
I recently heard that the EV-757 was the best mic ever made for vocals. What compares to it or even surpasses it in the new line of EV mics? Also, are the new ones American made like the old ones?
Don't know if I'd go that far. Microphones (like other gear) has specific design characteristics. The EV757 is a great mic and is best suited for female vocals (or Art Garfunkle). I paid $190 in the early 90's ($390 retail). I like dynamic mics for their ruggedness and no ned for phantom power. A condenser mic like a Neumann U87 cost $3,000 but faithfully reproduces. "Best" can only be used in conjunctioon with "for a particular purpose"
Jul 09, 2010 | ElectroVoice...
I was just wondering if its best to record seperate tracks at different times of if its ok to mic my guitar and mic the vocals using two inputs but recording at the same time?
Whichever works best for you is best. You can always lay down a scratch track for each like this and then lay down another track to replace whatever you didn't like using the scratch track as a guide. Erase the scratch tracks that you don't need before you mix down. I hope this helps.
Nov 26, 2009 | Fostex Mr 8hd CD 8 Track Recorder with CDr
Art Tube MP Project Series preamp how to set up comp to record
USB option does not work at all q as they said....Their use manual only makes marketing...It is not nice.
if I ask simple step by step. What is problem with it?
I fed up to use USB option ( no rec signal ) on this unit cause I have been told, better to use Yamaha mix device....
best.
V.
Sep 29, 2009 | Dual ART DPS II Preamp System with Tube...
NT3 or NT1A?
Either mic will work for piano, vocal and guitar.
Jan 02, 2009 | Rode NT3 Professional Microphone
Tascam DP-02cf
You've got two inputs on the DP-02 so you can record two sources at once.
Depending on how you want the electric guitar recorded (mic the amp, or direct line in) you can in the first case plug your guitar mic into one of the mic inputs on DP02 and plug your vocal mic into the other mic input. You also have the option of plugging the guitar directly into the DP02 (using the hi-z input - I believe it is labelled 'guitar' or something on the DP02. I any event I believe it's the one on the left). This way you only need one mic for use recording the vocal part.
To avoid any 'bleed' between channels you can use the headphones while recording this way and you'll avoid having the unamplified guitar sound coming through over the vocal mic.
Once you have the mics or guitar and mic plugged into two inputs, you need to assign the inputs to a channel (track) to record on. You do this by pressing the select button for the input and then pressing the select button for the track where you want to record the input. Do this for both inputs so that they are recording on different tracks. Then arm the tracks for recording by pressing the record button for each track and the lighted buttons will flash above each armed track. Then just press play and record and you'll be recording. You can go back and redo it as many times as you like and record over what is there, or preserve a take and assign a new track (or tracks) for another take. You've got 8 to play with.
Hope this helps.
bd.
Sep 01, 2008 | Tascam 2488 Portastudio Multitrack...
Can not record vocal and guitar at the same time
The monitoring switch should not affect the recording at all. Maybe you have a defective mic?
Does it record from the line input if you set it to Line In mode?
Mar 27, 2008 | Samson G-TRACK USB RECORDING MICROPHONE...
Marshall MXL-V69-MEDT Microphone Logo
Top Marshall Audio Players & Recorders Experts
Michial Gueffroy
Tom Chichester
James Kovacs
James Kovacs
Are you a Marshall Audio Player and Recorder Expert? Answer questions, earn points and help others
