Question about Ford 555 backhoe
Shutdown & wont start turnsover no blown fuses ford 555d
3 Suggested Answers
  • 29 Answers
SOURCE: #7 fuse blown
Posted on Oct 02, 2008
roniecon
  • 6927 Answers
SOURCE: heat & a/c stopped working wont blow any air
Check the blower motor relay next to the blower motor,it could be a blower module,but it is the problem.
Posted on Apr 16, 2010
My ford kuga has no electrics and will not start nor does the central locking system work !! Have you any idea why?
First check the battery voltage with a multi meter the voltage should be around 12.53 v if it is lower then 12v the cars Bsi unit wont wake as the Canbus electronic system is power hungry.
If the Battery voltage is correct then check the main fuses under the engine compartment and then check the interior fuses for a possible blown fuse. As the main system function are not working then the cause will most certainly be a blown higher amp fuse 30 amp / 60 amp which protects the starting and charging circuits.
Sep 05, 2015 | 2011 Ford Kuga 2.0
My fuse box is blown
you need to check battery supply most important. if the battery low voltage, cause no start. if the battery ok & strong energy. maybe the drive away protection control if this is the problem you need to bring to BMW dealer to replace control & ENCODE the control unit using SSS.
Oct 05, 2012 | 2006 Toyota Camry
Car shut down directly after turning on and now wont stard we have found that one of the 20 amp fuses is blown could this be the problem on my ford taurus 05 model
Yes, it probably blew soon as you started the vehicle. It depends on what the fuse is for.
Try replacing the fuse, and see if that helps anything.
(if no fuses available, take a fuse of equal amperage from something you can live without (ie. radio, cigarette lighter) and try it in the spot of the blown fuse.)
hope this helps!
Jan 07, 2011 | 2005 Ford Taurus
Ii have ford escape 2004 i cant start my engine. what is the problem theft signal in my dash board is going fast
I have the same issue I found my engine fuse blew it is located under the steering wheel on left hand side near floor it is a 10 amp fuse . Check this and see if it is blown replace it and try to start it. If it does start be sure to get it looked at right away I waited to long and now I just keep blowing that fuse and it wont start ,it is going in the shop as we speak ... good luck
Nov 01, 2010 | 2004 Ford Escape
My 1996 Ford Windstar Will Not Start....
Take all the fuses out and check them one by one and re install them and replace the blown fuse .
Tap on the relays to unstuck them .
Clean the batery terminals with sand paper .
Check the rear light and brake bulbs and sockets.
Vitally
Sep 03, 2009 | 1996 Ford Windstar
1997 ford contour wont start gets spark and fuel
Change out ignition moduel, tighten all grounds.
Aug 11, 2009 | 1996 Ford Contour
Jump wont work. 80 amp fuse blown under hood. where does fuse go
that is the alternator and vehicle power supply fuse, did u jump this wrong? u will need to replace this fuse before the car will start.
Mar 20, 2009 | 2001 Kia Sephia
Garden Logo
Top Ford Garden Experts
Dennis Key
Dennis Key
fordexpert
donald boissonneault
Are you a Ford Garden Expert? Answer questions, earn points and help others
