Question about Haier 14.3 lb. Washer/Dryer Combo
Haier HWD 1600, error 7
Error 7, will not run
    New Friend:
I had this washer for almost 2 yrs and you'll end up fixing things here and there. Well after some heavy research this error was supposedly the control box or some computer chip/loose connection. After taking apart all the pieces and reassembling, still err7 comes up. Turns out our daughter liked to open the door and pull down on it, causing a misalignment. There's lock that 'clicks' when you start a load to lock the door and I'm guessing there's a sensor that takes 5 seconds to detect if the door is closed properly. Our door was misaligned so the sensor tripped the circuit after 3 seconds of the water starting. I just press the door more with my knee and start the load. After 5 seconds I let go and all is well.
Posted on Feb 08, 2015
2 Suggested Answers
SOURCE: My Haier HWD 1000
Had a leakage and motor problem up until an hour ago.
Repairman advised me not to twist the screw in, but to first push in the screw as you would a regular plug. Once all the way in, turn it shut like a screw. I tried it and it worked! ...I'm still getting a washing machine pan.
Posted on Jan 22, 2011
My Haier HWD 1000 won't plug in without popping the outlet. It's Not the outlet, everything else works fine in it. and the washer pops ANY outlet.
sound like a wiring problem that keeps tripping it out poss water in wiring or a loose wire somewere have it checked by someone
Oct 13, 2014 | Haier Washing Machines
Hello, i am using Haier washer dryer HWD-D1200TXVE that is 1 year old, after a full cycle (pre-wash) the machine gave an error 12 and did not perform drying because water was not drained. I opened the...
Look up the mfg website and see if they have a troubleshooting page or a support group. It may still be a warranty item check that as well
Oct 20, 2013 | Washing Machines
I have a haier hwd 1600 that is giving a error code 13 what does that mean and can i reset the machine or do i have to call a service tech
I service this machine before. There is no service manual for any Haier products.
You might want to change these parts out in the unit: Main PCB board, Heater Element, Thermostat and the Condenser.
Mar 25, 2013 | Haier HWD1600 13-Pound Combo Washer Dryer
Hwd-c1000txveme-u error code 8
The only reference to 'E08' I have is that there is a problem 'water level exceeds protection value'. Water level detection may not be operating correctly and requires a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jun 24, 2011 | Haier HWD1000
I brought a Haier washer/dryer combine Model HWD-1500 I brought the display. The only problem I have it didn't come with the manuel. Could you help me find one
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C
Mar 15, 2011 | Washing Machines
My Haier HWD 1000 is brand new. First time use and water is pouring out of bottom as it tries to fill the drum. Please send help!!!!
There is a button and debris trap on the front bottom right of machine.
Little door says push. Open it and undo the large screw plug.
Remove debis if any. Screw the plug closed until it is very tight.
Check for leaks on next wash cycle.
(Also check intake hose connections at back of machine.)
Dec 01, 2010 | Haier HWD1000
Error code 7
The error code 7 is in fact a motor error.
The motor that drives the spin cycle has become faulty. The only solution now is to get an engineer in to fix it or get it sent away to get repaired.
Sep 08, 2008 | Haier XQG50-11 Front Load Washer / Dryer
Haier 14.3 lb. Washer/Dryer Combo Logo
415 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
