Question about Panasonic Toughbook CF-30 Notebook
Cf30 no wireless device detected - Panasonic Toughbook CF-30 Notebook
    Novelist:
    Scholar:
  • Panasonic Expert
  • 121 Answers
On the Panasonic Toughbook Model CF30, there is
a Wireless Switch located on the front side of the
unit when the cover is open and the unit is facing you.
The switch is on the right side of the handle near the corner
of the unit. Please make sure that switch is turned on.
Then check the device manager under Windows to
see if the device shows up, even with a yellow question
mark or yellow exclamation point. If it shows up in yellow,
then you are simply missing the drivers.
If it does not show up at all, then your CF30 might be
like several of my units that I purchased recently.
My CF30's had both a built-in GPS and a built-in
Cellular Modem Interface but as a consequence no WiFi.
I simply added a small USB WiFi no larger than a
wireless Mouse Transceiver and the USB cover could
close over the mini USB WiFi. $30 cost, problem solved!
Good Luck!
Regards,
Richard - Montreal Based
Panasonic Toughbook Authorized Dealer since 1989.
Posted on Feb 08, 2016
I CAN'T ACCESS TO INTERNET
try to know if phone can detect wireless device, if it can, then see to it that you know the password of the wireless device that your phone has detected because mostly of the wireless device or what we call the wifi are password protected.
Jun 22, 2011 | LG Cell Phones
Error code cf30 in toshiba 3511 what its mean and how can fix it
(CF30) - Reference plate detection voltage abnormality: The output
value of the color auto-toner sensor against the reference plate
is out of a specified range at the light amount correction during
an auto-toner adjustment or when a print job has finished.
Your color auto-toner sensor and reference plate are located under the input tray cover on the left side of the copier when you are facing it. It is on a bracket that hangs down into the copier and sits close to the revolver inside the machine. It is an optical sensor and if either it or the reference plate get stained with toner it will give you this error message, you may attempt to clean them with rubbing alcohol.
This error message may also occur if the solenoid that drives the reference plate is faulty so you will need to check that as well.
I would sincerely recommend that you get an authorized toshiba technician to take a look at the machine for you as this is a fairly difficult problem to fix right.
Sep 29, 2010 | Toshiba E-Studio 3511 Color Copier
Gps does not work on panasonic cf30 toughbook. no error message
Hi please try this solution, GPS software, usually containing maps of varying detail level, makes using a GPSmag-glass_10x10.gif for recreational purposes fun. This software enables you to see street-level or aerial maps of your neighborhood. For some GPS receivers that do not have a screen, it is necessary to use computer software to read the signals it has picked up.
  • Purchase software that is supported by both your computer and GPS. The system requirements should be clearly marked on the box.
  • Step 2
  • Jul 28, 2010 | Computers & Internet
    Are the recovery disk for the cf29 and cf 30 the
    I had a look on a few places that where selling recovery discs, i could only see cf29 discs, no cf30.
    It may be worth giving it a go
    Jul 20, 2010 | Panasonic Toughbook CF-29 Notebook
    I hava a hp 13" laptop that wont show wireless option in the internet properties. I have a wireless Lan Mini PCI card, but it is not being detected. Is there away to re enable the wireless?
    Hi. Please check first if your computer was able to detect the device. You can look for this device in control panel then click system then click device manager. Your wireless adapter should be present under network adapters. f computer was able to detect the wireless adapter. Try to turn off/on the wireless switch. Usually, wireless switch is located infront of the laptop or on the side. You can also try pressing Fn + F5 key to disable/enable wireless network card.
    Jun 13, 2010 | HP Pavilion TX1000Z 12.1" Touch Screen...
    Belkin f5d7051 not detecting
    ivegot the same problem, it worked previously and then randomly it stopped working. I have reinstalled windows 7 and it is still the same, i cant install itand cant detect the usb adapter. Have you found the solucion? Please email me to marcos15eliseu@hotmail.com
    Jul 27, 2009 | Belkin (F5D7050) (F5D7050VSNPDQ) Wireless...
    Wireless on/off button doesn't detect wireless card.
    drivers possibly or if its a switch then a bad switch
    Apr 30, 2009 | Acer Aspire 6920 Notebook PC
    Wireless internet drivers
    check in device manager, is your wireless card detected in device manager ?
    if not, it's look like your wireless card is defective.
    if yes but there is question mark, you need to re-install wireless driver.
    if yes, and it isnot detect any network, is wireless card in your device manager enable ? if disable, right click on wirelees card and choose enable.
    if step above not working, try to enable using wireless switch .
    Jul 05, 2008 | Acer Aspire 5000 Notebook
    I cannot detect my wireless
    Right click on My Computer and go to device properties and see if the wireless card is listed in the devices.
    If not you will have to install the drivers for the wireless network device. You can find them at there website.
    Mar 14, 2008 | Computers & Internet
    Panasonic Toughbook CF-30 Notebook Logo
    60 people viewed this question
    Top Panasonic Computers & Internet Experts
    Oloyede Monsuru
    micky dee
    Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
