Question about Garden
Rover 4 stroke lawn mower wont start - Garden
2 Suggested Answers
  • 211 Answers
SOURCE: my lawn mower will not turn off
Hi
From under the flyweel comes a wire(probably black).check it.It is connected with the off position of the trotle.
best regards savumihai71
Posted on Dec 22, 2008
I have a Rover Push lawn mower. Type 02031, Serial Number 0254990, Briggs and Stratton Quantam40 XTRA. My son has put two stroke petrol mix into this 4 stroke mower. Is this a problem?
Your mower is likely to throw out clouds of blue smoke, just as a 2 stroke engine does.
The spark plug may become oily and fouled, misfire and splutter/stall.
However, it's not a really serious problem and you're not going to cause any permanent damage. The easiest solution is to get a tube and syphon the 2 stroke mix out of the mower's fuel tank.
Mar 03, 2017 | Briggs Garden
How much oil do i put in my Honda / Rover GCV 160 lawnmower model no, 3591160. 4 stroke
Hi oil capacity 0.58 US qt (0.551) Equals :1.00 pint dry US (pt dry/ volume & capacity
Nov 05, 2016 | Honda Garden
Older (probably 20 years) Rover mower 4 stroke (not self propelled) - no spark at spark plug (no it's not the plug) - appears to be an electrical issue - how can I source electrical components ?
Hi if U have a mower repair shop near U I would get the coil tested any good mower shop should have a tester also get the condenser checked & buy a new set of points U have to remove the flywheel to get to the parts .....good luck
Apr 20, 2016 | Garden
Air gap setting for 4 stroke rover mower model no 30694
I cant seem to get your model number to work for me but under Rover push mowers it looks like they use Briggs and Stratton engines so if true Air Gap: 0.203/0.305 mm (0.008/0.012 in.)
The way I do it is fold a piece of printer paper one inch folds four thickness, wrap around flywheel, roll the flywheel around so the magnet is pulling the coil up tight to the flywheel,the four thickness of the printer paper is your air gap, then tighten the screws . Pull on the paper as you rotate the flywheel to remove it. Dont forget to check that the little wire is plugged in other wise it wont shut off. Replace the spark plug and spark plug boot/wire as well as the flywheel cover and it should start up.
Mar 16, 2016 | Garden
Lawn mower not running well
Try changing the fuel and air filters. Also drain the fuel tank and refill with fresh fuel.
Feb 23, 2015 | Briggs & Stratton Garden
2-stroke or 4-stroke?
Well, if it has an oil drain plug and/or a fill plug for oil, It's a 4 stroke. If it has an odd shaped muffler/resonator, it's a 2 stroke.
Oct 14, 2014 | Garden
Mower wont start
chech to see if plug bad make sure you are getting spark if it is spray some starting fluid in it see if it starts if it does checkfor water in gas if no rebuild carb should run
Jul 03, 2014 | Garden
White smoke coming from 4 stroke lawn mower
It is most likely oil. Probably passing past the rings on the piston. I use 2 stroke oil in all my mowers / small motors whether they are 2 stroke or 4 stroke (based on advice from a small motor repairer) since the 2 stroke oil helps lubricate the bore and even though there is some minimal smoke usually on start-up. Depending on how bad the smoke is you can try a heavier grade oil and I would recommend using a 25:1 2 stroke mix if you want to extend the life of your small motors.
Jan 31, 2013 | Garden
I got hold of a sanli 350 lawn mower 4 stroke the people gave me a bottle of 2 stroke oil with the mower is this the right oil to use
No No No No!!! If your mower is definitely a 4 stroke then do NOT put 2 cycle engine oil in it (and I hope they didn't either). Drain out whatever's in there completely and put standard 30 wt. oil in there. Not 10W30, but straight 30 weight. Use synthetic even if you want longer engine life.
Aug 21, 2011 | Toro Lawnmower 20099 Mower Mowers Lawn
Rover lawn mower is not working
Make sure you get a spark, Clean the gas tank, maybe even go as far as cleaning the carb, make sure everything is like new and start it up.
Jun 21, 2009 | Garden
Garden Logo
12 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
