Question about GE Advantium 120 Convection/Microwave Oven
Door sticks, not aligned
Checking to see for this model, if there is a way to adust the door handle so you do not have to pull so hard to open it. I have been reading that the door has to be replaced. Is this a warranty or recall issue
MicrowaveSvc
  • 9047 Answers
SOURCE: door handle
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Aug 24, 2008
  • 13 Answers
SOURCE: Door is hard to open
you can solve this yourself by removing door pins and straighting the hinges
Posted on Jan 02, 2009
VtToolMan
  • 704 Answers
SOURCE: I would like to purchase a replacement white door
Here's link for searspartsdirect.com that has the part you're looking for. You can shop around the web for the best price with other suppliers.
White door handle, Part #WB15X335
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=JVM1350WW01&productCategoryId=0123370&brandId=0432&modelName=MICROWAVE&diagramPageId=00001&componentDescription=CASE,%20DOOR%20&%20CONTROLS&documentId=E2136282&backToLink=Return%20to%20Sub%20Components%20list
Hope you found this helpful and best regards!
Posted on Aug 06, 2009
fathitkf
  • 1871 Answers
SOURCE: The microwave turns on when the door handle is
Hello :
If there is any resetting button , then press it to reset your Microwave oven . If that didn't solve the problem , then I recommend you to replace it if that's possible or just take it to the service since you still have to guarantee .
good luck .
rate please !
Posted on Mar 23, 2010
jsrock516
  • 5911 Answers
SOURCE: pLASTIC AROUNG SCREW POINTS HAVE BROKEN OFF AT
The door handle can easily be replaced on MOST microwave ovens by removing the inner door panel that goes around the perimeter of the glass. The following link explains how to access and replace the door handle:
http://www.fixya.com/support/r3696942-microwave_oven_door_handle_replacement
The average cost for a replacement handle usually runs about $20 - $40. Replacements may be purchased at the websites listed in the link I provided. The part number for the model number you provided is WB15X322. You can view an exploded view of your microwave door here:
http://pcappliancerepair.com/model-display.php
The door handle is a simple repair that can be done with the door in place, or with the door removed. You do not have to uninstall the oven if this is an over the range model.
If you have any questions, please post back and let me know. I hope this helps you
Posted on Apr 27, 2010
How to fix the door button on panasonic microwave t6648fx?
Clean the inside edge of the door and oven where it contacts the door. Grease or oil is preventing the door to swing open.
Aug 28, 2014 | Panasonic Microwave Ovens
The door sticks and will not open automatically when you push the button to open the door - you have to manually open the door.
Clean the door swith housings and re align the door.
That should do it, any other problems will become apparent when you examine the door switch holders.
Nov 03, 2010 | Amana AMC4080 800 Watts Microwave Oven
Replace handle on Ewave microwave
you'll have to remove the molding and the handle clips in to place and also has to screws that hold it in place, after that reassemble the door outside trim.
Jan 19, 2010 | Microwave Ovens
The push to open door handle on the model #KCMS 122Yal-0 (1995) built-in microwave sticks and won't open without pulling on door from underneath applicance
It may be that the push button, cam lever or door latch (or all three) have some grease accumulated on them that's making it sticky to open.
Or the rear surface of the push button or the face of the lever may be so worn that the door latches don't get pushed up all the way anymore.
These door opening parts are all located behind the control panel and pretty easy to get to so you can observe them as you press the button. That way you can figure out which is bad.
At our site, we have a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
You should enter your model number without the dashes: KCMS122YAL0
Nov 08, 2008 | KitchenAid Microwave Ovens
T993 - Positive Lock Switch ?
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find an authorized Panasonic servicer here. You can order Panasonic parts here.
Sep 27, 2008 | Panasonic NN-T993SF Microwave Oven
Microwave oven comes on when the door is open, we then put what ever we are heating up and turn the oven on. After it times out and goes off the microwave oven turns on again when we open the door to...
It sounds like either a bad door switch or door switch mount, or a sticking relay on the control panel.
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a problem on the control panel.
Otherwise, I would recommend that you contact your nearest Panasonic-authorized servicer.
Aug 19, 2008 | Panasonic Microwave Ovens
MICROWAVE TURNTABLE
Does it turn for just a moment or does it keep turning?
If it's just for a moment, that's normal.
If it stays on, either your top or bottom door switch is sticking or it's door switch mount is loose or broken.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. Other times, it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
What is your brand & model number? We may have the service manual you can download free.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 20, 2008 | Goldstar MV-1501 Microwave Oven
Microwave oven does not heat
Found brand & model in your other thread:
> Whirlpool Gold Microwave Model GH7155XHS
Did you see the door switch file at my site I pointed you to?
With the door shut, you gently loosen the door switch mount screw nearest the switch that is not aligned properly.
Then pull back slightly on the door switch mount, and while holding it back, retighten the screw.
The door switch mount is also called the latch board. On the exploded view, it looks like there may only be one screw.
You have to look it over and figure out how to adjust it based on the way it's constructed and which way it needs to go.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Jun 20, 2008 | Microwave Ovens
I have a GE Profile Microwave and the handle is broken....
I have the same issue. The Handle broke off my GE Microwave Oven (Model JVM1190SY 001). GE does not sell the handle seperately from what I can tell. I just ordered a new door. It's rediculously expensive. I tried to replace the handle with a nice drawer pull but couldn't find a size pull to match and I broke the plastic cover trying to get access to the screws for the handle, which is why I decided to buy the new door. Hopefully installation is not that difficult. This oven was manufactured in 2001, seems the handles have a 7 year life span.
May 28, 2008 | GE JVM1190SY/WY/AY/BY Microwave Oven
GE Advantium 120 Convection/Microwave Oven Logo
16 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
