Question about Dedicated Micros Televison & Video
Configure network on a digital sprite 2 dvr - Dedicated Micros Televison & Video
5 Suggested Answers
  • 3 Answers
SOURCE: dedicated micro's digi sprite 2 picture frozen
over heating / bad cooling fan or hard drive
Posted on Aug 15, 2009
  • 11 Answers
SOURCE: Changing times and dates on sprite 2 dvr
Press and hold the menu button. If there is a password set up then you will need to enter it then press menu again. The first menu page has the time and date settings on it. Use the arrow keys to highlight the time/date box that you need to change then press the up/down arrow to adjust the value.
Posted on Jan 31, 2010
SOURCE: forgot admin password Dedicated Micros Digital Sprite 2 RS Video
You can't. You have to send it back to dedicated micros, unless of course you can use hyperterminal.
Posted on Feb 23, 2011
russ_hill007
  • 3187 Answers
SOURCE: sprite 2,digital recorder
Have you checked the system fans and hard drives as it maybe over heating. the fans don't last long around 15000hrs and stop cooling the system, that makes the hard drives over heat and the system board.... now I don't know why but if the system board goes over 40c inside the system will freeze up cameras pictures will stay on screen but frozen. but if a hard drive fault happens on slave the system will not record but the cameras will still be displaying movement but not record or say live just a red flashing power led. If it does these then change them. if the psu is at lower end of its life the voltage must be checked. the capacitors in side will need changing and the cooling fan you will need a 2200uf 25v/ 2x 470uf 16v/ 3x 3300uf 16v/ 1000uf 16v. and new 12v fan. you should easy spot the ones gone as the tops go rounded. This also may help you to stop problems happening as it has worked on mine. inside the system put a board in-between the hard drive/s and system board leave an inch gap at the end near to the fans. I have found this helps vent the heat out better. you could if you are able to fit some fans into the board. may help cool them down better. now for why the system fails at 40c. the system fails as there is not enough ventilation now normally here in the UK it is fine, but with temp's getting into the 30c's in the summer times, the systems need to be in tip top condition. so replace fans every 2 years and hard drives every 4 years. hope this helps some of you out.
Posted on Sep 14, 2013
How can I connect with a UK toll free number from outside the UK?
Some toll free numbers might not be used from abroad, just to to call as if it where a normal number, if it works: bonus!
if it doesn´t, then you'll have to ring a normal chargeable number
Apr 03, 2015 | Dedicated Micros DS2PD16-500 Digital...
Http 192 168
If you are trying to access the DVR server from outside your network, you need to use port forward, in that way you will use your DVR client to connect to the router's public IP, the router will be forwarding the port the video system use to the computer, just configure the computer's IP in the router's port forwarding configuration.
May 18, 2013 | Cisco Model EPC3925 8x4 Eurodocsis 3.0...
How to check the IP on Digital Sprite 2?
I have no idea what Digital Sprite 2 is , but one universal way to check an IP of a device is to put it after DHCP server and check that server's IP allocation table.
Most home routers have those DHCP servers built-in and functional, so maybe the real question here is "how to check the IP lease allocation table of my wireless router" :-)
May 25, 2010 | Dedicated Micros Digital Sprite 2 RS Video...
Forgot admin password Dedicated Micros Digital Sprite 2 RS Video
Feb 07, 2010 | Dedicated Micros Digital Sprite 2 RS Video...
Jan 19, 2010 | Dedicated Micros 4way 40GB DVMR wPPP w/...
Our DS2 DVR gives the same display on camera 1 and 2 and sometimes it keeps on switching from 1 camera to another. Upon restarting the machine it will become ok but after a day or two, the same problem...
I've seen this before and it was caused by a faulty video card. It was sent to Dedicated Micros for repair and worked fine after it was returned. Sorry there is no permanent solution without major repair that I know of.
Jan 09, 2010 | Dedicated Micros Digital Sprite 2 RS Video...
I want 2 configure a DVR from remote place and not from the intranet. kindly help me out in solving the issue
To configure the DVR from a remote location you can do it one of two ways:
Create a vpn connection through your router if it supports it or an external units to the remote location. This will make the remote location appear to be local to the dvr.
You can also setup the dvr's internal IP and port on your router through port forwarding. This way certain network access or traffic will be passed directly to the dvr from outside your local network.
Nov 12, 2009 | Dome 4 CCD CCTV Camera Surveillance...
Have Digital Sprite 2 with static ip. No network connection.
swap cords, is the lights on in the net jack on the unit, if no then maybe faulty
Jun 02, 2009 | Dedicated Micros Digital Sprite 2 RS Video...
Televison & Video Logo
27 people viewed this question
Top Dedicated Micros Televison & Video Experts
CoppellTVRepair.com
electracon
 Russ Hill
Russ Hill
Are you a Dedicated Micros Televison and Video Expert? Answer questions, earn points and help others
