Question about Plumbing
Pacific hydrostarpacifichydrosra whole house water pressure booster pump with stainless steel housing item # 69303. It worked for 1 day and then quit.. It will not reset.It has a full prime and good feed. The overheat light comes on as soon as it is plugged in. The switch is on, I have pushed and pushed and held the reset.Iam in a remote location in Mex. returning it is not possible. If I cant fix this myself it goes in the dump. Craig
  • 6 Answers
SOURCE: i have a flotec water pump that sits on top of my
if the pump is working correctly, it can either be, need more water to prime it, or something in the well, such as low water, plugged filter, etc....sometimes when you have a system that is intermittently used, it can take 20 or 30 minutes of continuous priming to get it to pull, enough water to maintain the prime.
Posted on Apr 06, 2009
  • 3 Answers
SOURCE: My Grundfos JPS4 1 HP Pressure Booster Pump keeps coming on for a
Definately sounds like a leak in the pipes from the pressure side of the pump onwards, even the smallest leak will cause it to turn on to regain adequate pressure.
Posted on Jul 09, 2009
  • 523 Answers
SOURCE: gould 1/2hp submergible well pump cycles on and
My first thought was that of a water logged tank which causes short cycling, from your notes the tank is good (the tank may be partially water logged though) If the tank is ok and your getting short cycling (and the switch is good) I would guess your check valve down the well has failed. As the pump creates pressure then shuts off the water may be going right back down the well causing the pump to cycle again. This could also account for the poor water pressure as the check valve may be stuck slightly open allowing the system to loose pressure but only allowing a small amount of flow by when running. There could be a leak within the pumps drop-pipe and your loosing pressure through this leak. I expect you'll have to have the pump pulled.
I hope this may have helped,
Tom
Posted on Oct 12, 2009
  • 10 Answers
SOURCE: jet pump does not pump water
I had a similar problem and as a last resort took the pump apart and cleaned it and the jet. It's a very old pump but works ok now.
Posted on Oct 24, 2009
SOURCE: Winterizing a well pump and pressure tank
If this is the pump I am thinking of, it should drain if you disconnect the hose to the pressure tank.
The other option is to place a "T" connection on the intake to the pump, between the pump and well. Place a garden hose valve on the new branch. After you drain your system, attach a 2' hose to the new valve and place the other end into some antifreeze. Run the pump to draw some antifreeze into the unit. This will protect it from freezing and rust over the winter.
Posted on Apr 26, 2010
I recently purchased the Pacific Hydro 1-1/2 HP Whole House Pressure Booster Pump #69303. My water pressure from my municipal provider is 30psi. Do I have to reduce this pressure before it enters the...
I would consult a qualified plumber who will know about the coding for your area with regard to water pressures. They will be able to advise you.
Make sure any plumber is approved and carries the proper identification.
Jan 06, 2015 | Garden
Installed Delta 16955-SSSD Stainless Steel Victorian Single Handle Kitchen 16955-SSSD a couple months ago. About a couple weeks ago experienced low flow for about 4 hours then started working fine. Now...
Remove spay head from the end of the sprayer hose and turn the water on. If you have good pressure without the head, call Delta and ask for a new spray head. If you still have low water pressure without the spray head attached, call Delta and ask for a new ceramic disc cartridge free.
Sep 01, 2010 | Delta 16955-SSSD Stainless Steel Victorian...
House pressure water pump has to be reset to
it sounds like a relay for the auto shut off ....http://www.smarter.com/water-pumps/grundfos-mq3-35-3-4-hp-pressure/pd--ch-47--pi-11277834.html
Jan 16, 2010 | Grundfos MQ3-35 3/4 HP Pressure Booster...
I have an MQ3-45 Booster Pump which trips sometimes at night and when this happens it is extremely hot in the area around the inlet end - s/steel housing and for about 12 inches along the inlet and output...
can be an little leak in suction connection. when such a pump gets air in it it wont reach the switchoff pressure and keeps running with no flow over it. all the energie will be turned to heat.
Jan 02, 2010 | Grundfos MQ3-45 1 HP Pressure Booster...
My Kenmore 13593 dishwasher has stopped washing properly. It seems like the spray nozzles are not spinning. Almost as though there is not enough pressure or their is an internal leak. I have plenty of...
Look for plugged screens in the pump area... House water pressure has nothing to do with washing pressure as house water only fills, then the dw pump takes over...
Sep 20, 2009 | Kenmore 13593 Stainless Steel Built-in...
Leaks water out of the back
Well, I am no plumber but I would think that 108 psi is a bit high for your plumbing system. I have this pump installed in my house and have the max pressure set at 50 with a PRV on the outlet side of the pump.
Mar 24, 2009 | Grundfos MQ3-45 1 HP Pressure Booster...
Mira cold feed only power shower
Hi davecross,
I'm Harvey, the Master Plumber.
Your question is:
water pressure not great would a external pump help. Depends on your situation. If you live in a house with a well pump then turn up the pressure. If you have city water and the pressure is lacking then either install a house pump after the meter or if it is just the shower you're worried about then a booster pump on the shower line is the ticket. Be aware that useing the booster may reduce the pressure at the other faucets in the house while it's being used. The house pump will not exhibit this. You will likely need a local pro to help you with installation. Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you, Harvey, your Master Plumber
Sep 09, 2008 | Home
Plumbing Logo
107 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
