La76931 i.c pin details - Televison & Video
What is protection pin in la76931 7n ic
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Circuit diagrams of SMPS section of many popular brand devices are given. Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Oct 17, 2015 | Televison & Video
Can any of these ic use la76931s 7n or la76931k 7n instead of la76931 7n
I'm not sure what you are asking. LA76931 seems to be a TV model. What IC are you asking about?
Jun 02, 2015 | Televison & Video
HOW TO ENTER THE IC LA76931K 7N 5AZ9 SERVICE MODE FOR ADJUST THE PICTURE
If you wish to get some details, check the site linked here. Surf the site in "MOSAIC" view. It will make surf easy.
Service mode details to many popular brand TVs are given in detail. Check the site with patience.
Jan 24, 2014 | Televison & Video
La76931 DE 57V9
If you wish to get more details, and the schematic diagram of this IC based TVs, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window. Check the audio attenuation pin voltage. It should change according to the volume control setting. If no change is noted, check and replace the IC.
Oct 15, 2013 | Televison & Video
Ic la76931-59y4 remote service code
To know, how to enter its service mode, by using remote control, check this link. http://electronicshelponline.blogspot.com/ It has details to get into service mode to many brand TVs. Pull up previous posts there, either by its left side bar, or, view it in 'Timeslide' option.
Jun 20, 2013 | Televison & Video
BPL i short model television it's using La76931 ic problem is single horizandal line i cahange la78040 vertical ic but not cure.
Did you check if 24v supply is coming to the chip ( through a fusable 10 ohm resistor ) ?.Look for dry solder on the sync chip ( 24 pin or 40 pin IC ).
Mar 11, 2011 | Televison & Video
Pin details of LA 76931 J 7 M IC
http://www.ic2ic.com/search.jsp?sSearchWord=LA76931
Jan 31, 2011 | Televison & Video
Pin diagram of ic la76931
Please find the link below for your data sheet.
click on data sheet
Dec 31, 2010 | Televison & Video
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
Electro Med Services...
