Question about Sharp Aquos Televison & Video
The tv in my conversion van wont turn on. I try end putting new batteries in the remote but still nothing. I tryed turning the tv on manually but it just wont turn on! The DVD player works fine and when the van comes to a short stop the light on the tv turns on but then off. Please help. I have a 10 year old daughter and we're going on a long car ride.
  • 3 Answers
SOURCE: wont turn on
I have a good DSC-P92 unit that i had for the last 3 or so years. i was able to use it last around May 2006. but on June. I had problems trying to power it on when in CAMERA or VIDEO mode but have no problems trying to power it on in PLAY or SETUP mode. It does the same thing (power off) when you turn it on in PLAY but then switch to CAMERA mode. I've tried all the solutions that has been suggested so far but none worked. until i figured it seems to be a power draw problem. since it works fine in PLAY mode but not in CAMERA mode. the difference is, CAMERA mode needs the lens motor to work in conjunction with all the other functions at the same time. hence the larger power draw. the short of it is... as with any other electronic device that uses batteries. the terminals get corroded or coated with gunk (similar to car batteries) in my case. what i usually do is i use a pencil eraser (the one that sits on top of the pencil, mongol usually is best) and erase the terminals. usually it is good enough. but in this case. i also had to make sure the terminals are in a good raised position (for solid contact) and i also gently scraped the terminals with a screwdriver for good measure. after that. it worked liked new. by the way. make sure you are using a NEW good topped up, rechargeable battery. sometimes the old batteries just wont do it no more. Hope this helps everyone.
Posted on Sep 11, 2006
SOURCE: unable to turn on video mode without remote. I dont have remote
Who the hell builds a TV w/o a AUX or video button on the TV.... i hate this darn sylvania...
Posted on May 29, 2008
SOURCE: Tv won't turn on
I had a similar problem when there was a power outage or the lights went briefly out. I unplugged the TV and left it for a few days/weeks and then plugged it in and the TV worked. I think newer TVs should be treated like a home computer and put them on surge protectors.
Posted on Jul 08, 2008
fixyadude1
  • 57 Answers
SOURCE: RCA remote
Could it be possible that the remote needs reconfigured? If none of the buttons work, the it could possibly be that you need to re-enter the TV code back into the remote.
Posted on Sep 24, 2008
  • 50 Answers
SOURCE: my tv will not shut off with the remote control
What type of tv was it and did you try to reprogram the remote?
Posted on Jul 10, 2009
Just opened up a panasonic TC-L32C3 from its box, pluged it in and the remote (with brand new batteries) wont turn it on. I am able to turn it on manually and went through the initial on-screen set up...
Yes,the tv manual controls board infered signal light from the LED diode,to the tv have problems.Take the tv back where u bought it and exchangce it for another new tv.
May 21, 2011 | Televison & Video
The power and lamp light keep flashing, and the T.V itself wont turn off unless unplugged,
The tv projection lamp life are over.Ur tv require a new projection lamp replacement.U used a remote,tries to turn the tv off?Might have dead battery in ur remote?Tries to push the manual button on the tv on and off see if that work.Than it is the remote.
Nov 23, 2010 | JVC HD52G887 52" Television
Cannot turn tv on or off remotely. Tv works fine after turning on manually.
Take the remote control aparts,take some Q tips dips it in with some rubbing alchahol.Clean the remote control PCB board,putting it back together again,wait like 20 mins.Put in new batteries.The remote now should work again.If not it garbage,because it CPU chip is dead.Try website like Remotes.com to buy an exact remote to ur original remote.
Nov 18, 2010 | Quasar VV2007 20 in. Combo
My remote doesn't seem to be working to my Naxa TV. I have put in new batteries. The TV comes on with the "green" light in front. But when I click remote "pOWER" nothing happens ??? Thanks
If you replaced the batteries and can turn on the TV manually, then the button is probably not making proper contact with the remote. Try opening up the remote and placing a small piece of tin foil where the power button is, close the remote up and it should work.
Aug 03, 2009 | Televison & Video
Unable to get fan to respond to remote Hampton Bay 54
these fans must be reset as follows remove the battery from the remote manually turn off the wall power switch put the batteries back in the remote turn on the wall power switch press the remote buttons...if this doesn't work let me know
Jun 01, 2009 | Universal Remote Control Hampton Bay...
Vizio 50 inch plasma -- remote not working
You can also try to take out the batteries and push all of the buttons with the batteries out of the remote. Then put the batteries back in and push the power button on the remote. If this doesnt work press the two TV buttons at the same time and the remote should be fine.
Sep 14, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Televison & Video Logo
15 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
