Question about American Range AF-25 Deep Fryer
Baffles clogged with soot deep fryer - American Range AF-25 Deep Fryer
Deep fryer ignites but burner flames will not enter cylinders
Hi there.
Fire tubes may be clogged with soot. Have a technician inspect and clean the fire tubes for soot deposits/ build ups.
Check also if there is no air or ventilation directed on flue as it will push the flames back to the burners.
Regards.
Aug 12, 2013 | DCS Gas Deep Fryer 40 Lbs Double Basket...
Deep fryer catching on fire
From the video it appears many things could be wrong. The baffles and burner tubes could be clogged, the burner itself can be clogged, the flue is blocked, or this unit is using the wrong type of gas, ie: propane on a natural gas fryer.
Recommended steps for troubleshooting.
1. Verify proper gas type. Natural or Propane.
2. Check Burners, tubes, and baffles, clean all soot and debris from them.
3. Check for and remove any obstructions from the flue.
Apr 27, 2013 | Kitchen Appliances - Others
My Pitco fryer is shooting large flames out of the door. . . . HELP!
Hi there.
You should inspect the fire tubes, it is a tunnel under the fry tank where the burner flames suppose to travel to heat up the oil. Your fire tubes may be clogged with soot or carbon that's why flames cannot go thru the fire tubes. Fire tubes must be free of soot or carbon deposits.
Soot build up on fire tubes can be prevented by keeping the gas pressure at standard as much as possible, low gas pressure produce yellow flame or poor flame quality and in turn will produce soot.
Also, make sure that no air or ventilation is directed towards the flue riser, otherwise, the same will result, flames rolling back towards the door.
Regards.
Aug 05, 2011 | Pitco Frialator 35C Deep Fryer
Soot coming from flu
Remove the burners and clean the burner orfices and baffles,also check the vent cap on the pressure regulator that sits on the back of the fryer.Let me know.
May 14, 2009 | Pitco Frialator 35C Deep Fryer
My imperial IFS-40 is burning the door
Is this fryer propane?It sounds like the baffles in the tank are clogged.If you remove a burner shine a light in the baffle,if you see alot of soot use a shop vac and clean it out.Let me know.
Apr 23, 2009 | Imperial IFS40 Deep Fryer
We have a dean deep fryer model SR42GNS on start it makes a big boom and a large blue flame comes out of stack on top?
is the fryer propane or natrual gas?It sounds like the orfices,burners or baffles may be clogged and needs cleaning.let me know.
Apr 08, 2009 | Frymaster Dean 2424G Deep Fryer
Flames in the exhaust of my american range deef fryer
Is this a propane unit?If so the baffles get clogged with soot and burn.Let me know.
Feb 27, 2009 | American Range AF-25 Deep Fryer
Dean SR152GN Fryer
Is the unit propane?If so the baffles may be sooted up and need to be cleaned.This usually causes blowback.
May 19, 2008 | Dean SR14E Deep Fryer
Fire from lower ports
is this unit propane?if so the baffles are clogged,you need to remove the burners theres 2 bolts that sit on top of them.loosen the bolts,remove the burners and clean out the baffles.clean the burner orfices as well.this should do the trick.
Dec 25, 2007 | Vulcan EF3 Deep Fryer
American Range AF-25 Deep Fryer Logo
26 people viewed this question
Top American Range Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dan Webster
Dan Webster
Mike
Are you an American Range Kitchen Appliances - Other Expert? Answer questions, earn points and help others
