Question about Kitchen Appliances - Others
Flame shooting out front of american range deep fryer
3 Suggested Answers
  • 8 Answers
SOURCE: flames in the exhaust of my american range deef fryer
Oil leaking into combustion area... needs ne pot. Might be under warranty...call factory with serial #
Posted on Feb 28, 2009
kebah
  • 684 Answers
SOURCE: pitco deep fryer flames coming out the fryer
Hi there.
The soot or carbon have probably build up inside the fire tubes, better check and have an authorized service technician clean them.
Make sure that the fryer is receiving the rated gas pressure and correct gas type as stated on the nameplate, this way, carbon or soot formation on fire tubes can be prevented
Regards.
Posted on Sep 13, 2011
I need a new drain valve for American Range fryer. Where can I order one, and what size is it?
American Range part number A80201. It's an NFS approved stainless ball valve, generally 1.25". If you Google American Range A80201 you can find it on line for less than $70. You must use an NSF approved valve to comply with health codes.
Sep 07, 2014 | American Range AF40 Deep Fryer
Why does my burners not ignite into a blue flame
The color of the flame can be affected by a few different things. here are three of them: 1. If there is a food substance contacting the burner where the flame comes out, this will give the flame an orange tint. 2. If the propane is being burned at a very high rate, the flame can become invisible in daylight-like conditions. 3. If the propane is being burned at a very low rate it can also have an orange tint. Hope this is clarifying.
May 24, 2014 | American Range AF45LP Deep Fryer
Help flames front of fryer
Hi there.
Try to check and clean if needed the fire tubes, soot may have build up inside blocking the flame path. Soot build up on fire tubes and burners are caused primarily by low gas pressure, assuming that the orifice size are correct with respect to the type of gas used.
Regards.
Sep 03, 2013 | American Range Kitchen Appliances - Others
When i set the thermostat to desired setting flames shoot to the front of the fryer
Hi Dan.
Check if the fire tubes are clean, exhust system must be operating well during fryer operation. There should be no fresh air directed at the flue stack of the fryer, only exhaust.
Regards.
Oct 26, 2011 | Pitco Frialator SG14 Deep Fryer
What is the problem when millivolt gas valve can not keep it pilot on?
Hi there.
Probably the thermopile is not receiving enough heat from the pilot flame to generate 500 to 750 millivolt to hold pilot flame. The thermopile may have soot or dirt on it so try to clean or the pilot flame itself does not give enough heat, try adjusting pilot flame. Or the thermopile could not generate the right amount of millivolt even if it is clean and receiving enough heat from pilot flame, so better replace the thermopile.
Check also the hi limit, it must have continuity across its terminal.
Regards
Sep 20, 2011 | American Range AF-25 Deep Fryer
Turn on the pilot , when turn on the burnes evreting off
Hi there.
Ensure that the gas supply pressure is sufficient and the thermopile should be free of soot or any form of dirt, also the pilot flame should heat up the thermopile efficiently.
Regards.
Jul 12, 2011 | American Range AF40 Deep Fryer
Pilot light will light but wen i turn to on position it does nothing
Make sure that the pilot flame is sufficient to heat up the thermopile and also make sure that the thermopile is free from dirt or soot.
Jun 03, 2011 | American Range AF45LP Deep Fryer
Trying to light the pilot light on deep fryer when i push button in it lights but when i let go of button pilot light goes out what am i doing wrong
If the pilot flame does not hold after releasing the button for at least 20 to 30 seconds, try to clean the thermopile and tighten all wiring connection on gas valve, thermostat and hi limit the repeat the process. The thermopile must be heated by pilot flame in order for it to generate small amount of voltage to open the pilot valve.
If this does not correct the problem, try replacing the thermopile.
May 24, 2011 | American Range AF45LP Deep Fryer
How can I convert from natural gas to LP?
change your gas get from natural to lp and use an lp regulator. you may have to adjust your air flow for proper flame
Sep 16, 2010 | American Range AF-25 Deep Fryer
Flames in the exhaust of my american range deef fryer
Is this a propane unit?If so the baffles get clogged with soot and burn.Let me know.
Feb 27, 2009 | American Range AF-25 Deep Fryer
Kitchen Appliances - Others Logo
24 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
