Question about Fish
Broken glass top for aquarium
T1073891
How can I prevent my Saltwater aquariums from accumulating so much salt on the outside of the tank.I have to clean saltwater build up at least every 3 days.I have a 125 Gallon and also a 55 Gallon Sal
I am no expert on saltwater tanks, but I am wondering what temperature you are keeping the tanks. The water evaporation rate of the tank depends on the temperature and humidity of the room the tank is in. Lowering the tank temperature to around 70-72 `F and increasing the ambient humidity to 60+% RH will reduce evaporation which will result in less salt encrustation.
Nov 28, 2014 | Fish
Can you fix the top rim of a 72 g bow front if the middle piece is broken?
if its only the top black plastic piece sure you can , id use superglue and let dry (hours not minutes) and wash it several times with water to clean residue off , (NO fish in tank or water ) if crack is to the top of actual tank < its possible with aquarium silicone but I wouldn't chance it id replace it
Mar 20, 2013 | Aqueon All Glass Aquarium Co. 72 Gallon...
What is an open aquarium stand?
An open aquarium stand is a standard stand that made of light materials (glass, metal) and can hold glass aquariums of up to 40 gallons. It has a rectangular shape.
Sep 09, 2012 | Fish
When do I need to use a glass shield for my aquarium lighting?
When you are using a metal halide a glass shield is a necessity. Metal halides get really hot and one drop of water could cause the bulb to explode. A glass shield would also filter out the UV rays.
Aug 21, 2012 | Fish
The light for my aquarium is broken and my fish won't eat. I can't buy a new light till tomorrow. What should I do?
If your aquarium light is broken you should place a lamp near the aquarium to use temporarily until you can buy a replacement light.
Aug 14, 2012 | Fish
Are all aquariums made out of glass? We want to buy an aquarium for our home but I don't know much about what to look for.
No. Although many aquariums are made of glass, some are made from acrylic plastic. While glass aquariums are cheaper per gallon and harder to scratch, acrylic versions weigh less and are harder to break. You need to consider all of the advantages and disadvantages of each and then make your decision.
Jul 31, 2012 | Fish
Can I make my own aquarium?
Of Course!
Here are some resources that will help you get started:
If you are feeling really adventurous, you can even build a recessed aquarium:
Jul 23, 2012 | Fish
What are my different glass options for a DIY aquarium?
You have a few different options when assembling an aquariumout of glass. The most popular and massproduced is annealed glass which is also known as plate or sheet glass. The less common types of glass are called toughenedand laminated.
May 14, 2012 | Fish
Is glass or acrylic better for a saltwater aquarium?
There is no definite winner here. It is truly a matter of choice. I think the main argument against acrylic isthat it scratches easily. It also is much lighter than glass so will therefore requirea much lighter stand. However, it isimportant to note that glass is heavier so it tends to support more. Essentially, it comes down to the ofyour tank. If you have a small tank, Isuggest acrylic. If you have a largetank, I suggest you get glass.
May 14, 2012 | Fish
My glass aquarium cracked. How can I fix it?
There are a few steps to take to fix a cracked tank:
  1. 1. b>Move the fish to a backup tank with cleanwater
  2. 2. Wipe the crack with white vinegarto clean the glass and let it dry completely. This will allow the silicone tostick.
  3. 3. Line the crack withaqua-marine safe silicone gel
  4. 4. Let the gel dry completely(usually overnight) before returning the fish to the water
May 13, 2012 | Fish
Fish Logo
401 people viewed this question
Top Fish Experts
Richard Lindsey ...
Tom Chichester
ThothMer
ThothMer
Level 1 Expert
Are you a Fish Expert? Answer questions, earn points and help others
