Question about InFocus LP640 Multimedia Projector
Wont shut off replace bulb message - InFocus LP640 Multimedia Projector
Sanyo projector i change the bulb but it wont start up the bulb how to reset?
http://www.google.com.et/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0CBsQFjAA&url=http%3A%2F%2Fforums.cnet.com%2F7723-13973_102-398100%2Fdlp-twon-t-turn-on-blinking-green-lamp-light-then-shuts-dow%2F&ei=-VnbU_8Hg9XRBeWdgIgM&usg=AFQjCNGp5RYvSkK-2YKIqjHeH2oxVnzU-Q&bvm=bv.72197243,d.ZGU
Aug 01, 2014 | Sanyo Xga 4500 Ansi Projector
BULB REPLACEMENT
About 1 min's,but hear alot of clicking and see nothing after that.The board,call the Ballast board is also dead,require chaging.This board,help to ignite the projection bulb.
Jul 22, 2010 | JVC HD56G887 56" HDTV
Picture only comes in sometimes
Yes the bulb when it gets old and dusty it heats up and shuts off, sometimes it remembers and wont turn on. Replace the bulb and clean out the dust from all fans.
Apr 16, 2010 | Sony Grand WEGA KDP-65WS550 65" Rear...
99 jetta headlights wont turn on, replaced 4mo ago.
If the bulbs and relays are good, then the switch is faulty.
Sep 13, 2009 | 1999 Volkswagen Jetta
Projector shut down after replacing the bulb and wont turn on now
are any of the leds on the top of the projector lit? if so, which ones? red or green?
Apr 09, 2009 | Sharp Notevision PG-B10S Multimedia...
Panasonic dlp new bulb clean filter error message reset info not
For the Air Filter message, the filters are located inside the unit, if already cleaned, perform a reset of the unit, Press Hold, VOL - on set and TV/Video on remote for about 5 sec. If a Lamp timer reset message, try VOL - on the set and Mute, Move or PIP on the remote (try all three)
Mar 29, 2009 | Panasonic PT-50LC13 50" Rear Projection...
MY RCA 52 IN TV WONT TURN ON?
MOST LIKELY, THE PROBLEM
IS THE BULB USED IN THE SET?
BY THAT I MEAN THE HIGH INTENSITY REAR PROJECTOR BULB?
DO A SEARCH ONLINE AND THERE ARE COMPANIES SELLING THE BULBS AT A PREMIUM. YOU MAY WANT TO CONSIDER DUMPING IT.........
Mar 14, 2009 | RCA P52920BL 52" Rear Projection...
Tv plays for a few minutes then shuts down. the red light blinks.
You need reset the lamp timer after
replace the new lamp.In the remote control pres menu------setup------lamp timer----message do you replace a lamp appear----press yes----and ok.
Feb 14, 2009 | Sony KDF42E2000 42" HDTV
Projector suddenly shut down
you need to reset the lamp timer. turn it on, and press and hold the left arrow, right arrow, and power button until it resets.
Dec 17, 2008 | Mitsubishi ES100U Multimedia Projector
POST Replaced Bulb Problem, Error code = 32
This unit will not go into shut down because the lamp timer is not reset. The error you are getting means the lamp you put in is defective or it is not seated proplerly. Make sure the lamp door is on properly because there is a lamp door safety switch that must be depressed properly or the unit will shut down. When the timer needs to be reset you simply get a message on the screen that tells you so, it does not shut down. There are other things that will cause this problems such as the ballast or even problems in the light engine.
Apr 01, 2007 | Sharp 56DR650 56" Rear Projection HDTV
InFocus LP640 Multimedia Projector Logo
26 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
